man misusing less after 2012/11/12 update
Postby dontregister » Wed Nov 14, 2012 0:22
running man man on sabayon kde i686:
$ man man
There is no -l option ("less --help" for help)
-  (press RETURN)
Is this a problem I can fix or is it a packaging problem? If the latter, can anyone tell me how to roll back a package? (and which package, less or man?) I can't find out how in the equo --help.
Thanks
dontregister
Re: man misusing less after 2012/11/12 update
Postby dontregister » Thu Nov 15, 2012 23:54
I could really use some help, man is where I get most of my C documentation, which I need for my classes. I don't always have internet access.
Here's the versions:
$ man --version
man 2.6.2
$ less --version
less 452 (PCRE regular expressions)
[removed extraneous lines]
$ equo query installed /man- | grep Installed -B 1
>>      @@ Package: sys-apps/man-db-2.6.2 branch: 5, [__system__]
>>         Installed:     version: 2.6.2 ~ tag: NoTag ~ revision: 0
>>      @@ Package: sys-apps/man-pages-3.42 branch: 5, [__system__]
>>         Installed:     version: 3.42 ~ tag: NoTag ~ revision: 0
>>      @@ Package: sys-apps/man-pages-posix-2003a branch: 5, [__system__]
>>         Installed:     version: 2003a ~ tag: NoTag ~ revision: 4
>>      @@ Package: virtual/man-0 branch: 5, [__system__]
>>         Installed:     version: 0 ~ tag: NoTag ~ revision: 0
If there's any more information that is needed, please ask.
dontregister
Postby Fitzcarraldo » Fri Nov 16, 2012 10:59
Please file a bug report. To do that, click on the link 'Bugs' at the top of this page.
Postby King_DuckZ » Fri Nov 16, 2012 18:31
I think you just need to wait for a fix. The bug is well-known and a quick search on the internet shows that most distros are affected (eg: http://lists.opensuse.org/opensuse-bugs ... 01021.html). I'm also waiting for upstream to come up with a fix.
King_DuckZ
Postby Fitzcarraldo » Sat Nov 17, 2012 18:17
^It's working for me in Gentoo, so a fix must already be available.
Postby Johnny Who » Sat Nov 24, 2012 18:57
It affected me too. It `s annoying, but hasn` t anyone noticed that you can read the doc by pressing the left arrow?
Johnny Who
