Significant noise in multiple apps with kernel 3.6 [Solved]
Postby aquarius » Mon Oct 29, 2012 18:22
after upgrade to kernel 3.6 something is wrong with the sound. Namely there is significant noise in multiple applications.
Affected applications: vlc, skype, xnoise.
Not-affected applications: xbmc, flash, wine.
Switching back to kernel 3.5 resolves the problem.
I have 2 sound "cards" in my laptop.
According to alsamixer they are: HDA Intel PCH (primary) and HDA Nvidia (probably on GPU with HDMI output).
According to lspci:
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
01:00.1 Audio device: NVIDIA Corporation GF116 High Definition Audio Controller (rev a1)
I'm using only Intel's one.
So, I assume the noise is a kind of kernel/alsa+kernel issue.
Is there any solution for it?
Or maybe I should report a bug?
Thanks in advance
Gnome2 is dead! Long live... E17!
System76 Gazelle Professional:
Intel Core i7-2670QM
Nvidia GeForce GTX 560M
16GB DDR3 SDRAM
750GB HDD + 120GB SSD
15.6" Full HD LED-Backlit Matte Display
powered by Sabayon amd64 E17
aquarius
Re: Significant noise in multiple apps with kernel 3.6
Postby aquarius » Fri Nov 02, 2012 9:23
I've checked e17 amd64 daily iso. It comes with kernel 3.6. And there is no noise in vlc and other apps.
Same kernel, same architecture, same VM, same apps... Why live CD (daily iso) is fine, and my installation is not :?:
16GB DDR3 SDRAM
aquarius
Postby aquarius » Tue Nov 13, 2012 8:56
Upgrade to linux-sabayon-3.6-r3 fixed the problem.
Marking as solved.
16GB DDR3 SDRAM
aquarius
Re: Significant noise in multiple apps with kernel 3.6 [Solv
Postby jmparhan » Tue Nov 27, 2012 13:35
I have exactly the same problem. Running the latest Sabayon 10 KDE iso with kernel 3.5-r7.
Noise lasts about 10 to 20 seconds when I start a video with VLC. Haven't noticed it in other apps yet.
Could be a problem with the Intel sound card driver, I have the following sound card:
Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02)
Will try upgrade to 3.6-r3 to see if it fixes the problem.
Edit: Still annoying noise when starting to watch a video in VLC after kernel upgrade...
jmparhan
Postby jmparhan » Thu Nov 29, 2012 1:25
Tried to get some workarounds for the problem, ended up disabling my whole sound card, and then destroyed my installation by trying to uninstall pulseaudio. Never try that!
After a re-install from the original live dvd I used last time, and for as far as I know no different setup choices all seems fixed. Clueless but happy.
jmparhan
