Yate-qt4 latest version anyone?
Postby yenz » Mon Oct 15, 2012 10:26
Hello everyone!
New here and new to Sabayon, and was just wondering how to install the latest version of the VoIP client Yate-qt4 and if anyone has already done it?
I have have attempted to compile from source but without success. I couldn't figure out which compilation tools to install to get it to compile successfully.
Any pointers in the right direction will be great!
Yenz
yenz
Re: Yate-qt4 latest version anyone?
Postby micia » Mon Oct 15, 2012 11:16
Hi, welcome to the Sabayon forums.
Manual compilation or installation of any application in Sabayon is unsupported and discouraged, if you want to go on that way, keep in mind that you are on your own :mrgreen:
The proper way to do it is either using portage or entropy, I see that 4.1.0 version is available in portage.
Anyway, since the very latest version is unavailable in portage the only way you can get it now is by manual compilation, again, keep in mind that this way is discouraged, error prone and possibly dangerous.
To install this application manually (which is unsupported :roll: ), by looking at the source tarball, especially the README file, it looks like any regular source distribution, you just need to install GCC:
(as root)
equo install gcc
Compile it using the usual steps:
./configure
make
Then install it:
(as root)
make install
micia
Postby yenz » Tue Oct 16, 2012 2:59
Thank you very much for the quick reply! I will give that a go and see what happens...
yenz
