Pb with grub-mkconfig
Postby manifesto » Sun Oct 07, 2012 21:10
grub-mkconfig is not working properley since some time.
Actually it is not setting root= or real_root= on linux line.
So on boot it is stopping after initramfs boot asking for root device. I enter it (/dev/sda9) and it's going ok.
I could add it manually in grub.cfg but it is annoying me.
I have several distro and it is working for non sabayon one.
sabayon ~ # grub-mkconfig -o /boot/grub/grub.cfg
Generating grub.cfg ...
Found background: /boot/grub/default-splash.png
Found linux image: /boot/kernel-genkernel-x86_64-3.5.0-sabayon
Found initrd image: /boot/initramfs-genkernel-x86_64-3.5.0-sabayon
Found linux image: /boot/kernel-genkernel-x86_64-3.3.0-sabayon
Found initrd image: /boot/initramfs-genkernel-x86_64-3.3.0-sabayon
Found Arch on /dev/sda10
Found Debian GNU/Linux (wheezy/sid) on /dev/sda7
Found Ubuntu 12.04.1 LTS (12.04) on /dev/sda8
done
For exemple result is :
sabayon ~ # egrep -w linux /boot/grub/grub.cfg  | grep /boot | grep -v menu
linux   /boot/kernel-genkernel-x86_64-3.5.0-sabayon ro pcie_aspm=force i915.i915_enable_rc6=1 resume=/dev/sda6
linux   /boot/kernel-genkernel-x86_64-3.3.0-sabayon ro pcie_aspm=force i915.i915_enable_rc6=1 resume=/dev/sda6
linux /boot/vmlinuz-linux root=/dev/sda10
linux /boot/vmlinuz-3.6-0.towo-siduction-amd64 root=UUID=012cd020-c11c-4728-8945-5a2f837927b7 ro quiet
linux /boot/vmlinuz-3.2.0-31-generic root=/dev/sda8 ro quiet splash $vt_handoff
The 2 first line are sabayon (without root arg which fail to boot) and others (in order arch/siduction/ubuntu) which have the root=... that boot ok.
Result is :
menuentry 'Sabayon GNU/Linux, with Linux x86_64-3.5.0-sabayon' --class sabayon --class gnu-linux --class gnu --class os {
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        set root='hd0,msdos9'
        if [ x$feature_platform_search_hint = xy ]; then
          search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos9 --hint-efi=hd0,msdos9 --hint-baremetal=ahci0,msdos9 --hint='hd0,msdos9'  2d8fd1f1-27b0-4a48-a4ff-fc9ce87c31bc
        else
          search --no-floppy --fs-uuid --set=root 2d8fd1f1-27b0-4a48-a4ff-fc9ce87c31bc
        fi
        echo    'Loading Linux x86_64-3.5.0-sabayon ...'
        echo    'Loading initial ramdisk ...'
        initrd  /boot/initramfs-genkernel-x86_64-3.5.0-sabayon
I did custom this line from /etc/default/grub :
GRUB_CMDLINE_LINUX="pcie_aspm=force i915.i915_enable_rc6=1 resume=$(swapon -s | grep '/dev/sd.[0-9]' -o)"
As it finds the boot device (mdos9 above) why doesnt it add the root line ??
manifesto
Re: Pb with grub-mkconfig
Postby Fitzcarraldo » Fri Oct 12, 2012 8:25
I suggest you file a bug report. To do that, click on the link 'Bugs' at the top right of this page.
Postby paddlaren » Wed Nov 21, 2012 13:12
Hi!
I have the same problem on one of my machines. It is a Acer eeePc.
This is also the only machine adopted for Window 7 (i.e. the only machine not home made) with UEFI or EFI boot. It cannot boot on a standard ISO Linux so I had to install sabayon the Gentoo way (and I liked it). There where some initial problems but after a full reinstall and I had to make a replay (Sabayonish emerge --empty-tree).
The entire system but the linux-args in grub.cnf is working properly as it seems.
@manifesto, Did you file a bug report for this?
paddlaren
Users browsing this forum: No registered users and 7 guests
