Problem with MATE
Problem with MATE
Postby Elynx » Mon Sep 24, 2012 4:28
I think when i downloaded the version Mate of sabayon linux that are very interesting but the realy its other.
Mate is not very complete and this is a green version now, he has some bugs that the developed team are solved and i prefer others alternatimves for example: Xfce4 because is more faster or LXDE, that are very minimalist with openbox, fluxbox or other Windows Manager.
My problem is that i dnt want have mate on my system and i wan to remove will posibble and install fluxbox or xfce4.
Any help?
Im new on linux, and i want help!
Very thanks!
Greetings!
Elynx!
Elynx
Re: Problem with MATE
Postby wolfden » Tue Sep 25, 2012 7:23
if you are new, I'd suggest just downloading a new iso file of your choice and installing that. Other wise you will need to use the package manager to remove and add, which you will want to look at something like:
http://wiki.sabayon.org/index.php?title=Remove_Mate
Postby Elynx » Wed Sep 26, 2012 5:36
Thanks for your answer man!
See ya!
Elynx
