Gscan2pdf - how to install? [Solved]
Postby desputin » Sat Sep 22, 2012 16:19
I saw that the great program gscan2pdf is not in the repository. Could anyone here tell me how to install it?
The source:
http://sourceforge.net/projects/gscan2p ... pdf/1.0.6/
I installed all dependencies necessary but I'm still getting:
Warning: prerequisite Config::General 2.4 not found.
Warning: prerequisite Log::Log4perl 0 not found.
Warning: prerequisite PDF::API2 0 not found.
Warning: prerequisite Readonly 0 not found.
Warning: prerequisite Sane 0.05 not found.
Warning: prerequisite Set::IntSpan 1.1 not found.
Writing Makefile for gscan2pdf
so that probably doesn't sound too good...
I also found .ebuild files for gentoo here:
http://gpo.zugaina.org/media-gfx/gscan2pdf
Can I install them? And if yes, how?
best regards
desputin
desputin
Re: Gscan2pdf - how to install?
Postby Fitzcarraldo » Sat Sep 22, 2012 17:19
1. More complicated way, using Portage.
First, as root user in a Konsole/Terminal window, use the preparatory commands listed in the post Re: Atheros Wired Connection Problem. Then do the following:
layman -a triquetra
emerge -1v gscan2pdf
2. Easier way, using Entropy.
Click on the link 'Bugs' at the top right of this page and file a request for the package to be built and added to the Entropy repository. Wait a week or so and hope it will be added to the Entropy repository.
Postby desputin » Sat Sep 22, 2012 20:38
Hello Fitzcarraldo,
thank you!
2. Sound's perfect! Where exactly do I add a bug/Program request? could you give me a link?
desputin
Postby Fitzcarraldo » Sat Sep 22, 2012 21:27
Click on the link 'Bugs' at the top right of this page.
Postby desputin » Sun Sep 23, 2012 0:38
desputin
Postby desputin » Wed Sep 26, 2012 0:03
Thanks again!
After installing some more dependencies, restarting and retrying your commands, I successfully installed gscan2pdf and it works!
I hope that someone will build the package anyway. I can't understand why this program hasn't been added a long time ago as in my opinion it's one of the best and most useful programs that are out there.
desputin
Postby Fitzcarraldo » Wed Sep 26, 2012 1:45
desputin wrote:it's one of the best and most useful programs that are out there
I agree, and have had it installed on my main machines since end 2007.
:!: Please mark the thread as solved. See the link in my signature for the precise method of doing that.
