Configuring SLiM
Configuring SLiM
Postby Johnny Who » Sat Sep 15, 2012 14:39
I have recently replaced gdm with slim in order to save memory. I have enabled the default user login and my username, but I the default session is the login shell (it logs me in a terminal). I can select the seesion with F1, but I would like to make log me in the session I used last time. For instance, I am using gnome, and I want my next login to be automatically gnome, if I use mate, I want it to log me into Mate automaticaly the next time, etc. How do I configure it?
Note: It reads the available sessions from sessiondir.
Johnny Who
Re: Configuring SLiM
Postby Fitzcarraldo » Sat Sep 15, 2012 21:58
I'm no expert in SLiM, but I don't think it is possible to configure SLiM to boot by default the X session you selected last time using F1. At least I can't see an option for that listed in the SLiM Manual.
However, the global default X session is defined in the file /etc/env.d/90xsession. for example:
XSESSION="Xfce4"
so you could try using a Bash script to write the current value of the environment variable XSESSION to the file /etc/env.d/90xsession when you shut down. The script would have to be put in the directory /etc/local.d/, have the suffix ".stop" and be executable. For example, you (as root user) could create the file /etc/local.d/xsession.stop containing:
#!/bin/sh
echo 'XSESSION="'$XSESSION'"' > /etc/env.d/90xsession
and make it executable:
# chmod +x /etc/local.d/xsession.stop
Check if the initscript local is in the default runlevel:
# rc-update | grep local
It should be in SL if I recall correctly but, if it isn't, you can add it:
# rc-update add local default
I cannot test this myself, as I only have one DE (Xfce) installed on the machine on which I am using SLiM. So I'm not sure if it would work. You'll have to try it and see.
