Install software (gtkpod) from source code? [Solved]
Postby ratcheer » Tue Jul 31, 2012 18:55
I am having a lot of trouble with gtkpod. It always crashes when I try to add a directory with m4a files, and the m4a plugin is enabled:
*** buffer overflow detected ***: gtkpod - terminated
gtkpod: buffer overflow attack in function <unknown> - terminated
Report to http://bugs.gentoo.org/
After much research, I think I have discovered that this is a bug in gtkpod that can be resolved by installing the very latest version from the git source. However, as a Sabayon newbie, I don't know where to start. If there is Sabayon (or Gentoo) documentation for doing such a thing, could someone point me to it?
Or, if anyone has a better solution for my problem, I would appreciate that, too.
Thanks,
Tim
ratcheer
Re: Install software (gtkpod) from source code?
Postby sabayonino » Tue Jul 31, 2012 19:03
you can find gtkpod-9999
http://gpo.zugaina.org/app-pda/gtkpod
Dottout Overlay
Sync Portage tree and overlays
# emerge --sync
# equo install git
# layman -a dottout
Umasking 9999
# emerge =app-pda/gtkpod-9999 --autoumask-write
# etc-update
Select -5
Install gtkpod
then
# equo rescue spmsync
Good Luck !
Postby ratcheer » Tue Jul 31, 2012 21:45
Thanks very much, sabayonino. I will take a look.
Tim
ratcheer
Postby ratcheer » Thu Aug 02, 2012 20:29
Latest status - A gtkpod developer is helping me with the problem. It turns out that hundreds of my m4a files can be added to the library, but certain ones make it crash. When it crashes, nothing gets added in the end.
The files that make it crash can play just fine with vlc, so it is just something about them that crashes gtkpod. I have sent the developer some samples and he says he is examining them bit by bit.
I am marking this thred as solved, because I don't think I'm going to try to build it from source code.
Tim
ratcheer
