Failed to load module "pk-gtk-module"& "canberra-gtk-module"
Postby tek640 » Mon Jul 30, 2012 20:20
I have install Android SDK and after installation, when try to run Android SDK i get this error message:
Gtk-Message: Failed to load module "pk-gtk-module"
After that i follow another guide (http://osarena.net/hacks-guides/dokimas ... x-sas.html) to test firefox os and i get this:
Gtk-Message: Failed to load module "canberra-gtk-module"
In both situations the applications worked fine.
(Sorry for my english) :oops:
tek640
Re: Failed to load module "pk-gtk-module"& "canberra-gtk-mod
Postby adsicks » Thu Aug 09, 2012 12:39
Is your configuration files for your SDK pointing to the right location? And are the packages actually installed? For instance, are they custom installs in .../local/ and pkconfig thinks they are somewhere else. I had a problem with other SDK's like that and I had to get the environment variables from pkconfig to find the so's...
adsicks
Postby tek640 » Thu Aug 16, 2012 18:34
I follow this guide to install Android SDK and i made the specific changes for gentoo. I install the SDK through Rigo package manager. The SDK installed in directory /opt/android-manager....
tek640
