Blender 2.49 [Solved]
Postby Luca13 » Mon Jul 23, 2012 16:48
After the last update blender is updated to 2.63, but i need 2.49 becouse some addonds i use are only for this version.
Is possible retrieve the 2.49 version ?
Thanks in Advance
Luca
Luca13
Re: Blender 2.49
Postby svantoviit » Mon Jul 23, 2012 21:27
You should be able to downgrade it with Portage.
(If you haven't used Portage yet, check the wiki before issuing any command: HOWTO: The Complete Portage Guide)
emerge -a =blender-2.49b-r2
equo rescue spmsync --ask
equo mask media-gfx/blender
svantoviit
Re: Blender 2.49
Postby Jomiel » Mon Jul 23, 2012 22:43
Or you could download the tarball and install it localy on your /home.
Here is the link http://download.blender.org/release/
cheers
Jomel
Jomiel
Re: Blender 2.49
Postby svantoviit » Mon Jul 23, 2012 23:03
Jomiel wrote:Or you could download the tarball and install it…
It's not a supported practice to install software outside a package manager.
svantoviit
Re: Blender 2.49
Postby Luca13 » Tue Jul 24, 2012 13:54
I have try to install with emerge but i get error on compiling, otherwise i have downloaded binary linux bersion and it work fine after installing libjpeg.so.64
emerge =media-libs/jpeg-6b-r9
Thanks at all for yours help :D
Regards
Luca
Luca13
