VLC & SMPlayer Audio Gone – Amarok-YouTube-Clementine OK
Postby tonyawards » Mon Jul 09, 2012 5:57
Two days ago I opened vlc to play an mp4 audio/video file, it worked for about 3 sec. And then mysteriously the audio output just stopped. With vlc, the file is playing, there is progress in the time bar, I can get video, but no audio.
Amarok plays mp3s fine, with data display, and appears normal
Clementine plays ok (audio from both mp3 and mp4 files works).
SMPlayer app opens but won't play anything (no mp4, no flv), no audio and no video(?).
I have opened alsamixer in yakuake terminal and reset it to the nvidia/conexant card many times trying to debug this (each time I go back in it is back to PulseAudio, but doesn't work either way), and made sure nothing is muted (except it continues to reset s/pdif to 'mm', but I don't believe I have digital anyway.
Current settings in the kmix mixer are basic, and I really never touch them:
    Playback and capture show only 'built in audio analog stereo' as an option.
    In the 'Audio Setup' I have alternated GStreamer and vlc as the phonon preference in the Backend tab, when the problem started it was set to GStreamer and this has seemed to make no difference either way.
    PulseAudio Sound Server is the only option in Phonon for Device Preference playback (and almost everything else as well), Audio Hardware Setup tab has 'Analog Stereo Duplex' and 'Built-in Audio Analog Stereo' selected.
    And, for some reason, now when I plug in headphones to the mini-jack, they don't silence the laptop's speakers (but the phones do work) – I have to manually select 'headphones' in the Phonon 'Connector' Audio Hardware Setup tab dropdown to kill the speakers.
I really do not recall if there were any updates prior to using vlc since the last time, I may have updated to KDE 4.8.4 with that week's batch of other included updates in between vlc uses, but I can't be sure.
I reset all prefs in vlc to default settings (which is basically where they were before, not really customized) with no effect. Also reinstalled vlc and phonon-vlc. When I ran kbuildsycoca4 afterward I got a strange output, though:
# kbuildsycoca4 –noincremental
kbuildsycoca4 running...
kbuildsycoca4(10873) KBuildSycoca::recreate: Recreating ksycoca file ("/var/tmp/kdecache-root/ksycoca4", version 205)
kbuildsycoca4(10873) KConfigGroup::readXdgListEntry: List entry Actions in "ServiceMenus/krename_all_nonrec.desktop" is not compliant with XDG standard (missing trailing semicolon).
kbuildsycoca4(10873) KConfigGroup::readXdgListEntry: List entry Actions in "ServiceMenus/krename_dir_rec.desktop" is not compliant with XDG standard (missing trailing semicolon).
kbuildsycoca4(10873) VFolderMenu::mergeFile: VFolderMenu::mergeFile: "/etc/xdg/menus/applications-merged/sabayon-sabayon.menu"
kbuildsycoca4(10873) VFolderMenu::mergeFile: VFolderMenu::mergeFile: "/etc/xdg/menus/applications-merged/ggz.merge.menu"
kbuildsycoca4(10873) VFolderMenu::mergeFile: VFolderMenu::mergeFile: "/etc/xdg/menus/ggz.menu"
kbuildsycoca4(10873) foldNode: "Directory" and "ggz.directory" requires combining!
kbuildsycoca4(10873) VFolderMenu::pushDocInfo: Menu "applications-kmenuedit.menu" not found.
kbuildsycoca4(10873) VFolderMenu::processMenu: Processing KDE Legacy dirs for <KDE>
kbuildsycoca4(10873) VFolderMenu::processKDELegacyDirs:
kbuildsycoca4(10873) VFolderMenu::loadApplications: Looking up applications under "/usr/share/applications/"
kbuildsycoca4(10873) KConfigGroup::readXdgListEntry: List entry Categories in "/usr/share/applications/sulfur.desktop" is not compliant with XDG standard (missing trailing semicolon).
kbuildsycoca4(10873) KConfigGroup::readXdgListEntry: List entry MimeType in "/usr/share/applications/sulfur.desktop" is not compliant with XDG standard (missing trailing semicolon).
kbuildsycoca4(10873) KConfigGroup::readXdgListEntry: List entry Categories in "/usr/share/applications/google-earth.desktop" is not compliant with XDG standard (missing trailing semicolon).
kbuildsycoca4(10873) KConfigGroup::readXdgListEntry: List entry MimeType in "/usr/share/applications/google-earth.desktop" is not compliant with XDG standard (missing trailing semicolon).
kbuildsycoca4(10873) KConfigGroup::readXdgListEntry: List entry Categories in "/usr/share/applications/rigo.desktop" is not compliant with XDG standard (missing trailing semicolon).
kbuildsycoca4(10873) KConfigGroup::readXdgListEntry: List entry MimeType in "/usr/share/applications/rigo.desktop" is not compliant with XDG standard (missing trailing semicolon).
kbuildsycoca4(10873) VFolderMenu::loadApplications: Looking up applications under "/usr/share/applications/kde4"
kbuildsycoca4(10873)/kdecore (services) KServicePrivate::init: The desktop entry file  "/usr/share/applications/kde_x-sulfur.desktop"  has Type= "MimeType"  instead of "Application" or "Service"
kbuildsycoca4(10873) KBuildServiceFactory::createEntry: Invalid Service :  "/usr/share/applications/kde_x-sulfur.desktop"
kbuildsycoca4(10873) VFolderMenu::loadApplications: Looking up applications under "/usr/local/share/applications/"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/calibre-gui.desktop" specifies undefined mimetype/servicetype "application/ereader"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/calibre-gui.desktop" specifies undefined mimetype/servicetype "application/oebps-package+xml"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/calibre-gui.desktop" specifies undefined mimetype/servicetype "application/x-sony-bbeb"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/calibre-gui.desktop" specifies undefined mimetype/servicetype "text/fb2+xml"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/installfont.desktop" specifies undefined mimetype/servicetype "fonts/package"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ark_part.desktop" specifies undefined mimetype/servicetype "application/lha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ark_part.desktop" specifies undefined mimetype/servicetype "application/maclha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/amarok_append.desktop" specifies undefined mimetype/servicetype "audio/*"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/ark_servicemenu.desktop" specifies undefined mimetype/servicetype "application/lha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/ark_servicemenu.desktop" specifies undefined mimetype/servicetype "application/maclha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "kerfuffle_clilha.desktop" specifies undefined mimetype/servicetype "application/lha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "kerfuffle_clilha.desktop" specifies undefined mimetype/servicetype "application/maclha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "video/x-quicktime"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "video/mkv"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/aiff"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-pn-aiff"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-realaudio"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-basic"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-pn-au"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-8svx"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/8svx"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-16sv"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/168sv"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "image/ilbm"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "video/anim"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "image/x-png"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "video/mng"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-real-audio"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-pn-wav"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-pn-windows-acm"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/mpeg2"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-mpeg2"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/mpeg3"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "audio/x-mpeg3"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/gstreamer.desktop" specifies undefined mimetype/servicetype "x-mpegurl"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/kde4/k3b.desktop" specifies undefined mimetype/servicetype "application/x-iso"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "windowsexethumbnail.desktop" specifies undefined mimetype/servicetype "application/x-msdownload"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/k3b_create_audio_cd.desktop" specifies undefined mimetype/servicetype "audio/*"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "amarok_collection-playdarcollection.desktop" specifies undefined mimetype/servicetype "Amarok/Plugin-disabled"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "video/x-flc"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-ms-asf"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-ms-wax"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-real-audio"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "application/x-flac"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "misc/ultravox"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-pn-aiff"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-pn-au"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-pn-wav"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-pn-windows-acm"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/vlc.desktop" specifies undefined mimetype/servicetype "application/x-extension-mp4"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/clementine.desktop" specifies undefined mimetype/servicetype "application/x-ogm-audio"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/k3b_write_iso_image.desktop" specifies undefined mimetype/servicetype "application/x-iso"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/k3b_write_iso_image.desktop" specifies undefined mimetype/servicetype "inode/ISO-image"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "videopreview.desktop" specifies undefined mimetype/servicetype "video/*"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/lib64/libreoffice/share/xdg/writer.desktop" specifies undefined mimetype/servicetype "application/x-doc"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/lib64/libreoffice/share/xdg/writer.desktop" specifies undefined mimetype/servicetype "application/vnd.lotus-wordpro"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ffmpegthumbs.desktop" specifies undefined mimetype/servicetype "video/*"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/kde4/ktorrent.desktop" specifies undefined mimetype/servicetype "application/x-torrent"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ark_dndextract.desktop" specifies undefined mimetype/servicetype "application/lha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ark_dndextract.desktop" specifies undefined mimetype/servicetype "application/maclha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "fontthumbnail.desktop" specifies undefined mimetype/servicetype "fonts/package"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/firefox.desktop" specifies undefined mimetype/servicetype "text/mml"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/kmail_addattachmentservicemenu.desktop" specifies undefined mimetype/servicetype "all/all"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/calibre-ebook-viewer.desktop" specifies undefined mimetype/servicetype "application/ereader"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/calibre-ebook-viewer.desktop" specifies undefined mimetype/servicetype "application/oebps-package+xml"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/calibre-ebook-viewer.desktop" specifies undefined mimetype/servicetype "application/x-sony-bbeb"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/calibre-ebook-viewer.desktop" specifies undefined mimetype/servicetype "text/fb2+xml"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "video/x-quicktime"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "video/mkv"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/aiff"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-pn-aiff"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-realaudio"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-basic"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-pn-au"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-8svx"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/8svx"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-16sv"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/168sv"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "image/ilbm"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "video/anim"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "image/x-png"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "video/mng"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-real-audio"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-pn-wav"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-pn-windows-acm"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/mpeg2"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-mpeg2"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/mpeg3"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "audio/x-mpeg3"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "phononbackends/vlc.desktop" specifies undefined mimetype/servicetype "x-mpegurl"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/zzz-gimp.desktop" specifies undefined mimetype/servicetype "image/pcx"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/zzz-gimp.desktop" specifies undefined mimetype/servicetype "image/x-gimp-gbr"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/zzz-gimp.desktop" specifies undefined mimetype/servicetype "image/x-gimp-pat"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/zzz-gimp.desktop" specifies undefined mimetype/servicetype "image/x-gimp-gih"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/zzz-gimp.desktop" specifies undefined mimetype/servicetype "image/x-psp"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/k3b_create_data_project.desktop" specifies undefined mimetype/servicetype "all/all"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/bluefish.desktop" specifies undefined mimetype/servicetype "text/x-javascript"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/bluefish.desktop" specifies undefined mimetype/servicetype "text/x-perl"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/bluefish.desktop" specifies undefined mimetype/servicetype "text/x-php"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/bluefish.desktop" specifies undefined mimetype/servicetype "application/x-cgi"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/bluefish.desktop" specifies undefined mimetype/servicetype "application/x-python"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/kde4/ark.desktop" specifies undefined mimetype/servicetype "application/lha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/kde4/ark.desktop" specifies undefined mimetype/servicetype "application/maclha"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/kde4/marble.desktop" specifies undefined mimetype/servicetype "application/gpx+xml"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/krename_all_nonrec.desktop" specifies undefined mimetype/servicetype "all/allfiles"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "plasma-kpart.desktop" specifies undefined mimetype/servicetype "KParts/Part"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/kde4/amarok.desktop" specifies undefined mimetype/servicetype "application/x-ogm-audio"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "kfontviewpart.desktop" specifies undefined mimetype/servicetype "fonts/package"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "/usr/share/applications/calibre-lrfviewer.desktop" specifies undefined mimetype/servicetype "application/x-sony-bbeb"
kbuildsycoca4(10873) KBuildServiceFactory::populateServiceTypes: "ServiceMenus/ark_addtoservicemenu.desktop" specifies undefined mimetype/servicetype "all/all"
kbuildsycoca4(10873) KBuildSycoca::save: Saving
localhost #
To sum up - -
Not working (AFAIK): vlc audio output (video ok), SMPlayer (audio & video both not working), downloaded .flv, mp4, etc. files (video, yes – audio, no)
Working: Amarok mp3s, youtube/Firefox/web-based flash (video & audio both ok), startup & shutdown system sounds, Clementine (for both mp3 and mp4 audio)
Sound Card: HDA nVidia & Chip: Conexant CX20549 (Venice) - in my HP Pavilion dv6000.
Software versions: PulseAudio 2.0-r1, alsamixer 1.0.25, vlc 2.0.1~4, phonon-vlc-0.5.0
I have looked at a lot of threads and noted the post by Richlion in this recent one (http://forum.sabayon.org/viewtopic.php?f=59&t=25647) but as it wasn't answered and the thread is marked [Solved] I though I'd start this one. I have looked both here and Googling, but didn't see my combination of issues – any ideas or threads I missed?
SL Version: XI+, just rollin' along / Kernel 3.8.3 | KDE 4.10.1 | HP dv6000z | AMD Turion64 MK-36 | 2GB RAM | nVidia GeForce 6150
tonyawards
Re: VLC & SMPlayer Audio Gone – Amarok-YouTube-Clementine OK
Postby wolfden » Mon Jul 09, 2012 12:09
Do you have pavucontrol installed and verify the apps are using the correct hardware? Seems strange at some work and some don't. Fire up SMPlayer and get it going and than look in pavucontrol to see settings.
Postby tonyawards » Tue Jul 10, 2012 2:54
Thanks, wolfden.
I started SMPlayer with an mp4 file (video is working with the mp4, not with an flv, but still no audio), then I checked in pavucontrol.
In the “Playback” tab there is only one mono bar designated System Settings, with no meter level reading.
In the “Output Devices” there is a stereo bar set called Built-In Audio Analog Stereo with the dropdown for either speakers or headphones, with no reading in the level bar.
“Input Devices” has Built-In Audio Analog Stereo, Analog Input designation, with a stereo set, and a 15% or so level moving, which seems to be picking up the ambient room noise on the open mic on the laptop and nothing else.
“Configuration” profile is set to Analog Duplex.
No other devices or bar sets show, and I know I have seen more than that before. Seems like something is not registering, what I'm not exactly sure, nor am I sure how to get it back.
tonyawards
Postby Fitzcarraldo » Tue Jul 10, 2012 5:24
Have you checked System Settings > Mutlimedia > Phonon > Audio Hardware Setup? Make sure you have the correct hardware profile selected.
Another thing to check is System Settings > Mutlimedia > Phonon > Backend. You could try changing to the VLC backend (media-libs/phonon-vlc) or, if you're already using that, the GStreamer backend (media-libs/phonon-gstreamer) instead. These are the packages that I have got installed, in case it's of help:
$ eix phonon
[I] kde-base/phonon-kde
     Available versions:  (4) 4.7.4 4.8.3 (~)4.8.4
        {{alsa aqua debug pulseaudio}}
     Installed versions:  4.8.4(4)(00:24:51 30/06/12)(alsa pulseaudio -aqua -debug)
     Homepage:            http://phonon.kde.org
     Description:         Phonon KDE Integration
[I] media-libs/phonon
     Available versions:  4.4.2 (~)4.4.3 4.5.0 4.5.1-r1 (~)4.6.0-r1 **9999 {{alsa aqua debug +gstreamer pulseaudio vlc zeitgeist}}
     Installed versions:  4.6.0-r1(16:27:21 20/02/12)(pulseaudio vlc -aqua -debug -gstreamer -zeitgeist)
     Homepage:            https://projects.kde.org/projects/kdesupport/phonon
     Description:         KDE multimedia API
[I] media-libs/phonon-gstreamer
     Available versions:  4.5.0 (~)4.5.1 (~)4.6.0 **9999 {{alsa debug +network}}
     Installed versions:  4.6.0(17:48:40 20/02/12)(alsa network -debug)
     Homepage:            https://projects.kde.org/projects/kdesupport/phonon/phonon-gstreamer
     Description:         Phonon GStreamer backend
* media-libs/phonon-qt7
     Available versions:  ~*0_pre20110424 {{debug}}
     Homepage:            https://projects.kde.org/projects/kdesupport/phonon/phonon-quicktime
     Description:         Phonon QuickTime7 backend
[I] media-libs/phonon-vlc
     Available versions:  0.4.1 (~)0.5.0 **9999 {{debug}}
     Installed versions:  0.5.0(16:27:54 20/02/12)(-debug)
     Homepage:            https://projects.kde.org/projects/kdesupport/phonon/phonon-vlc
     Description:         Phonon VLC backend
* x11-libs/qt-phonon
     Available versions:  (4) [M]4.6.3 4.7.4 4.8.1 (~)4.8.2
        {{aqua c++0x dbus debug +exceptions pch qpa qt3support}}
     Homepage:            http://qt-project.org/ http://qt.nokia.com/
     Description:         The Phonon module for the Qt toolkit
Found 6 matches.
And here is a list of the GStreamer plugins that I have got installed:
$ eix -I --only-names gst-plugins
media-libs/gst-plugins-bad
media-libs/gst-plugins-base
media-libs/gst-plugins-good
media-libs/gst-plugins-ugly
media-plugins/gst-plugins-a52dec
media-plugins/gst-plugins-alsa
media-plugins/gst-plugins-dts
media-plugins/gst-plugins-dv
media-plugins/gst-plugins-dvb
media-plugins/gst-plugins-dvdread
media-plugins/gst-plugins-faac
media-plugins/gst-plugins-faad
media-plugins/gst-plugins-ffmpeg
media-plugins/gst-plugins-flac
media-plugins/gst-plugins-gconf
media-plugins/gst-plugins-gio
media-plugins/gst-plugins-gl
media-plugins/gst-plugins-jpeg
media-plugins/gst-plugins-lame
media-plugins/gst-plugins-libpng
media-plugins/gst-plugins-mad
media-plugins/gst-plugins-meta
media-plugins/gst-plugins-mpeg2dec
media-plugins/gst-plugins-musepack
media-plugins/gst-plugins-ofa
media-plugins/gst-plugins-ogg
media-plugins/gst-plugins-pango
media-plugins/gst-plugins-pulse
media-plugins/gst-plugins-resindvd
media-plugins/gst-plugins-soup
media-plugins/gst-plugins-taglib
media-plugins/gst-plugins-theora
media-plugins/gst-plugins-v4l2
media-plugins/gst-plugins-vorbis
media-plugins/gst-plugins-x
media-plugins/gst-plugins-x264
media-plugins/gst-plugins-xvid
media-plugins/gst-plugins-xvideo
Postby tonyawards » Wed Jul 11, 2012 5:57
Thanks for your settings, Fitzcarraldo.
I looked at the System Settings > Mutlimedia > Phonon > Audio Hardware Setup and Backend settings - they seem the same as when I accessed them in the Phonon window, through what I had called the "kmix > mixer" settings method, and are still set as mentioned above in my first post. I still can't see anything wrong with them, but if there is another selection I should try (I have tried most all of them, I think) I'll give that a go.
I had gstreamer as preferred in Backend, so I swapped it again for vlc, but still no luck.
As for the packages lists, I ran the two eix commands, which I'll post here:
# eix phonon
     Installed versions:  4.8.4(4)(02:41:16 AM 06/26/2012)(alsa pulseaudio -aqua -debug)
     Installed versions:  4.6.0-r1(11:07:21 AM 02/22/2012)(gstreamer pulseaudio -aqua -debug -vlc -zeitgeist)
     Installed versions:  4.6.0(03:36:41 PM 02/26/2012)(alsa network -debug)
     Installed versions:  0.5.0(11:09:01 AM 02/22/2012)(-debug)
Found 6 matches.
# eix -I --only-names gst-plugins
media-plugins/gst-plugins-libmms
The only differences I can see are that I have
and yours has a slightly different installed versions sequence of
Otherwise, our installed packages lists look the same to me.
For the eix of the gstreamer plugins, it looks like I am missing your media-plugins/gst-plugins-faac, -gconf, -gl, -jpeg, -libpng, and I have -libmms, which I do not see in your list.
I'm not sure if the mismatches matter - if I need any or all of them, do I just equo-install them from the repositories? All, or one at a time to debug? O can it be something else?
I still have not touched the settings again in vlc since I reset them to defaults, and they worked before in a default configuration.
tonyawards
Postby Fitzcarraldo » Wed Jul 11, 2012 20:07
Notice that you have the vlc USE flag switched off in your phonon package, whereas I have it turned on. The vlc USE flag is used in the phonon ebuild to build the VLC Phonon backend. But, according to the eix output you posted, you have that installed.
As you have audio working on Amarok, YouTube and Clementine, I assume your audio infrastructure is actually working correctly and your problem lies with a missing plugin/codec for the type of audio you are trying to play in VLC and SMPlayer. The media-plugins/gst-plugins-faac looks like a possible candidate if you are using the GStreamer Phonon backend. Try installing that.
Postby tonyawards » Thu Jul 12, 2012 5:29
I installed media-plugins/gst-plugins-faac, as well as all the other plugins you had and I did not. I installed them one at a time, and opened vlc and SMPlayer with an mp4 file (that did work before...) after each installation from the plugin list. Video is fine in both, still no audio in either one.
I took a look at the Tools > Codec Information in vlc while the mp4 was playing, just to see, and in the various tabs for the audio data I have this:
Codec Tab
Stream 1
Type: Audio
Codec: MPEG AAC Audio (mp4a)
Channels: Stereo
Sample rate: 44100 Hz
Statistics Tab
Audio
Decoded (constantly growing as it plays) blocks
Played    (constantly growing as it plays, same quantity) blocks
Lost        1 buffers
Input/Read
(constantly growing as it plays) KiBs
Discarded (corrupted)  0
Dropped (discontinued)  0
Output/Written/Sent
Sent  0 packets
Sent  0 Kib
Upstream rate  0 kb/s
The "Lost" etc most likely doesn't mean much, but thought I'd post it just in case...
Would it help, then, to add that USE flag like you have? If so, how would I do that (I'm an entropy guy, not well versed with gentoo as yet)?
Or, and I'm really just guessing here, it seems like sometimes with certain issues, that deleting and recreating some kde prefs, hidden directories &/or settings can help. Is anything like that worth pursuing?
tonyawards
Postby tonyawards » Sun Jul 15, 2012 2:54
Still have had no luck, but I took a snapshot of a log (Tools > Messages, set to level 2-debug) while vlc was playing an mp4 file - it does have some errors throughout but I don't know how to interpret them to see what I am missing, or has corrupted. I'll post it here, up until the last line, which began to repeat the same message forever..
main debug: adding item `Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4' ( file:///home/me/Music/_MP4%20Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4 )
    main debug: rebuilding array of current - root Playlist
    main debug: rebuild done - 1 items, index -1
    main debug: processing request item: Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4, node: null, skip: 0
    main debug: resyncing on Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4
    main debug: Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4 is at 0
    main debug: starting playback of the new playlist item
    main debug: creating new input thread
    main debug: Creating an input for 'Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4'
    qt4 debug: Adding a new MRL to recent ones: file:///home/me/Music/_MP4%20Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4
    main debug: using timeshift granularity of 50 MiB, in path '/tmp'
    main debug: `file:///home/me/Music/_MP4%20Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4' gives access `file' demux `' path `/home/me/Music/_MP4%20Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4'
    main debug: creating demux: access='file' demux='' location='/home/me/Music/_MP4%20Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4' file='/home/me/Music/_MP4 Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4'
    main debug: looking for access_demux module: 2 candidates
    main debug: no access_demux module matching "file" could be loaded
    main debug: TIMER module_need() : 0.403 ms - Total 0.403 ms / 1 intvls (Avg 0.403 ms)
    main debug: creating access 'file' location='/home/me/Music/_MP4%20Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4', path='/home/me/Music/_MP4 Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4'
    main debug: looking for access module: 2 candidates
    filesystem debug: opening file `/home/me/Music/_MP4 Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4'
    main debug: using access module "filesystem"
    main debug: TIMER module_need() : 0.189 ms - Total 0.189 ms / 1 intvls (Avg 0.189 ms)
    main debug: Using stream method for AStream*
    main debug: starting pre-buffering
    main debug: received first data after 0 ms
    main debug: pre-buffering done 1024 bytes in 0s - 25641 KiB/s
    main debug: looking for stream_filter module: 7 candidates
    main debug: no stream_filter module matching "any" could be loaded
    main debug: TIMER module_need() : 0.347 ms - Total 0.347 ms / 1 intvls (Avg 0.347 ms)
    main debug: looking for stream_filter module: 1 candidate
    main debug: using stream_filter module "stream_filter_record"
    main debug: TIMER module_need() : 0.124 ms - Total 0.124 ms / 1 intvls (Avg 0.124 ms)
    main debug: looking for demux module: 51 candidates
    mp4 warning: unknown box type btrt (incompletely loaded)
    qt4 debug: IM: Setting an input
    mp4 warning: unknown box type gsst (incompletely loaded)
    mp4 warning: unknown box type gstd (incompletely loaded)
    mp4 warning: unknown box type gssd (incompletely loaded)
    mp4 warning: unknown box type gspu (incompletely loaded)
    mp4 warning: unknown box type gspm (incompletely loaded)
    mp4 warning: unknown box type gshh (incompletely loaded)
    mp4 debug: dumping root Box "root"
    mp4 debug: |   + ftyp size 24
    mp4 debug: |   + moov size 1785040
    mp4 debug: |   |   + mvhd size 108
    mp4 debug: |   |   + iods size 21
    mp4 debug: |   |   + trak size 640595
    mp4 debug: |   |   |   + tkhd size 92
    mp4 debug: |   |   |   + mdia size 640495
    mp4 debug: |   |   |   |   + mdhd size 32
    mp4 debug: |   |   |   |   + hdlr size 45
    mp4 debug: |   |   |   |   + minf size 640410
    mp4 debug: |   |   |   |   |   + vmhd size 20
    mp4 debug: |   |   |   |   |   + dinf size 36
    mp4 debug: |   |   |   |   |   |   + dref size 28
    mp4 debug: |   |   |   |   |   |   |   + url  size 12
    mp4 debug: |   |   |   |   |   + stbl size 640346
    mp4 debug: |   |   |   |   |   |   + stsd size 170
    mp4 debug: |   |   |   |   |   |   |   + avc1 size 154
    mp4 debug: |   |   |   |   |   |   |   |   + avcC size 48
    mp4 debug: |   |   |   |   |   |   |   |   + btrt size 20
    mp4 debug: |   |   |   |   |   |   + stts size 24
    mp4 debug: |   |   |   |   |   |   + stss size 11180
    mp4 debug: |   |   |   |   |   |   + stsc size 52
    mp4 debug: |   |   |   |   |   |   + stsz size 580520
    mp4 debug: |   |   |   |   |   |   + stco size 48392
    mp4 debug: |   |   + trak size 1143551
    mp4 debug: |   |   |   + mdia size 1143451
    mp4 debug: |   |   |   |   + hdlr size 76
    mp4 debug: |   |   |   |   + minf size 1143335
    mp4 debug: |   |   |   |   |   + smhd size 16
    mp4 debug: |   |   |   |   |   + stbl size 1143275
    mp4 debug: |   |   |   |   |   |   + stsd size 91
    mp4 debug: |   |   |   |   |   |   |   + mp4a size 75
    mp4 debug: |   |   |   |   |   |   |   |   + esds size 39
    mp4 debug: |   |   |   |   |   |   + stsc size 94744
    mp4 debug: |   |   |   |   |   |   + stsz size 1000020
    mp4 debug: |   |   |   |   |   |   + stco size 48388
    mp4 debug: |   |   + udta size 757
    mp4 debug: |   |   |   + meta size 749
    mp4 debug: |   |   |   |   + hdlr size 33
    mp4 debug: |   |   |   |   + ilst size 704
    mp4 debug: |   |   |   |   |   + gsst size 25
    mp4 debug: |   |   |   |   |   + gstd size 31
    mp4 debug: |   |   |   |   |   + gssd size 56
    mp4 debug: |   |   |   |   |   + gspu size 152
    mp4 debug: |   |   |   |   |   + gspm size 152
    mp4 debug: |   |   |   |   |   + gshh size 280
    mp4 debug: |   + mdat size 1497203802
    mp4 debug: unrecognized major file specification (mp42).
    mp4 debug: found 2 tracks
    mp4 debug: track[Id 0x1] read 12094 chunk
    mp4 debug: track[Id 0x1] read 145125 samples length:5805s
    main debug: selecting program id=0
    mp4 debug: adding track[Id 0x1] video (enable) language undef
    mp4 debug: track[Id 0x2] read 12093 chunk
    mp4 debug: track[Id 0x2] read 250000 samples length:5804s
    mp4 debug: adding track[Id 0x2] audio (enable) language undef
    main debug: using demux module "mp4"
    main debug: TIMER module_need() : 167.819 ms - Total 167.819 ms / 1 intvls (Avg 167.819 ms)
    main debug: looking for a subtitle file in /home/me/Music/_MP4 Files
    main debug: looking for decoder module: 27 candidates
    main debug: meta ok for (null), need to fetch art
    main debug: looking for meta fetcher module: 1 candidate
    lua debug: Trying Lua scripts in /home/me/.local/share/vlc/lua/meta/fetcher
    lua debug: Trying Lua scripts in /usr/lib64/vlc/lua/meta/fetcher
    lua debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/fetcher/tvrage.luac
    main debug: using meta fetcher module "lua"
    main debug: TIMER module_need() : 0.631 ms - Total 0.631 ms / 1 intvls (Avg 0.631 ms)
    main debug: removing module "lua"
    main debug: searching art for Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4
    main debug: looking for art finder module: 2 candidates
    lua debug: Trying Lua scripts in /home/spike/.local/share/vlc/lua/meta/art
    lua debug: Trying Lua scripts in /usr/lib64/vlc/lua/meta/art
    lua debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/art/00_musicbrainz.luac
    lua debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/art/01_googleimage.luac
    lua debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/art/02_frenchtv.luac
    lua debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/art/03_lastfm.luac
    lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
    main debug: no art finder module matching "any" could be loaded
    main debug: TIMER module_need() : 10.529 ms - Total 10.529 ms / 1 intvls (Avg 10.529 ms)
    main debug: art not found for Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4
    avcodec debug: libavcodec initialized (interface 0x352300)
    avcodec debug: trying to use direct rendering
    avcodec debug: allowing 1 thread(s) for decoding
    avcodec debug: ffmpeg codec (H264 - MPEG-4 AVC (part 10)) started
    main debug: using decoder module "avcodec"
    main debug: TIMER module_need() : 79.032 ms - Total 79.032 ms / 1 intvls (Avg 79.032 ms)
    main debug: using decoder module "faad"
    main debug: TIMER module_need() : 0.302 ms - Total 0.302 ms / 1 intvls (Avg 0.302 ms)
    main debug: looking for meta reader module: 2 candidates
    lua debug: Trying Lua scripts in /home/me/.local/share/vlc/lua/meta/reader
    lua debug: Trying Lua scripts in /usr/lib64/vlc/lua/meta/reader
    lua debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/reader/filename.luac
    lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
    main debug: no meta reader module matching "any" could be loaded
    main debug: TIMER module_need() : 0.848 ms - Total 0.848 ms / 1 intvls (Avg 0.848 ms)
    main debug: `file:///home/me/Music/_MP4%20Files/Pete_Gabriel_Growing_Gotan_-_Milan_Italy.mp4' successfully opened
    mp4 debug: track[Id 0x1] using Sync Sample Box (stss)
    mp4 debug: stts gives 0 --> 0 (sample number)
    mp4 debug: track[Id 0x2] does not provide Sync Sample Box (stss)
    main debug: Buffering 0%
    main debug: looking for text renderer module: 3 candidates
    freetype debug: Building font databases.
    freetype debug: Took 1 microseconds
    freetype debug: Using Sans as font from file /usr/share/fonts/dejavu/DejaVuSans.ttf
    freetype debug: using fontsize: 2
    main debug: using text renderer module "freetype"
    main debug: TIMER module_need() : 14.065 ms - Total 14.065 ms / 1 intvls (Avg 14.065 ms)
    main debug: looking for video filter2 module: 18 candidates
    swscale debug: 32x32 chroma: YUVA -> 16x16 chroma: RGBA with scaling using Bicubic (good quality)
    main debug: using video filter2 module "swscale"
    main debug: TIMER module_need() : 1.305 ms - Total 1.305 ms / 1 intvls (Avg 1.305 ms)
    yuvp debug: YUVP to YUVA converter
    main debug: using video filter2 module "yuvp"
    main debug: TIMER module_need() : 1.760 ms - Total 1.760 ms / 1 intvls (Avg 1.760 ms)
    main debug: Deinterlacing available
    main debug: deinterlace 0, mode blend, is_needed 0
    faad warning: decoded zero sample
    main debug: Buffering 33%
    main debug: Opening vout display wrapper
    main debug: looking for vout display module: 6 candidates
    main debug: Buffering 66%
    main debug: Buffering 100%
    main debug: Stream buffering done (400 ms in 22 ms)
    main debug: looking for vout window xid module: 4 candidates
    qt4 debug: requesting video...
    qt4 debug: Video was requested 0, 0
    main debug: using vout window xid module "qt4"
    main debug: TIMER module_need() : 86.981 ms - Total 86.981 ms / 1 intvls (Avg 86.981 ms)
    main debug: looking for inhibit module: 2 candidates
    main debug: using inhibit module "xdg_screensaver"
    main debug: TIMER module_need() : 0.664 ms - Total 0.664 ms / 1 intvls (Avg 0.664 ms)
    xcb_xv debug: connected to X11.0 server
    xcb_xv debug:  vendor : The X.Org Foundation
    xcb_xv debug:  version: 11104000
    xcb_xv debug: using screen 0x243
    xcb_xv debug: using XVideo extension v2.2
    xcb_xv debug: using adaptor NV17 Video Texture
    xcb_xv debug: using port 505
    xcb_xv debug: using image format 0x30323449
    xcb_xv debug: using X11 visual ID 0x21 (depth: 24)
    xcb_xv debug: using X11 window 0x07800000
    xcb_xv debug: using X11 graphic context 0x07800002
    main debug: VoutDisplayEvent 'fullscreen' 0
    main debug: VoutDisplayEvent 'resize' 1280x677 window
    main debug: using vout display module "xcb_xv"
    main debug: TIMER module_need() : 106.286 ms - Total 106.286 ms / 1 intvls (Avg 106.286 ms)
    main debug: original format sz 1280x720, of (0,0), vsz 1280x720, 4cc I420, sar 1:1, msk r0x0 g0x0 b0x0
    main debug: removing module "freetype"
    main debug: TIMER module_need() : 1.461 ms - Total 1.461 ms / 1 intvls (Avg 1.461 ms)
    main debug: creating audio output
    main debug: looking for audio output module: 3 candidates
    avcodec warning: disabling direct rendering
    xcb_xv debug: display is visible
    xdg_screensaver debug: started xdg-screensaver (PID = 10514)
    pulse debug: using stereo channel map
    pulse debug: using library version 2.0.0
    pulse debug:  (compiled with version 2.0.0, protocol 26)
    pulse debug: connected locally to unix:/tmp/pulse-s6MGfZnfzwpx/native as client #4
    pulse debug: using protocol 26, server protocol 26
    pulse debug: using buffer metrics: maxlength=4194304, tlength=14296, prebuf=0, minreq=7056
    pulse debug: connected to sink 0: alsa_output.pci-0000_00_10.1.analog-stereo
    main debug: using audio output module "pulse"
    main debug: TIMER module_need() : 30.563 ms - Total 30.563 ms / 1 intvls (Avg 30.563 ms)
    main debug: output 'f32l' 44100 Hz Stereo frame=1 samples/8 bytes
    main debug: mixer 'f32l' 44100 Hz Stereo frame=1 samples/8 bytes
    main debug: filter(s) 'f32l'->'f32l' 44100 Hz->44100 Hz Stereo->Stereo
    main debug: conversion pipeline completed
    main debug: looking for audio mixer module: 2 candidates
    main debug: using audio mixer module "float32_mixer"
    main debug: TIMER module_need() : 7.539 ms - Total 7.539 ms / 1 intvls (Avg 7.539 ms)
    main debug: input 'f32l' 44100 Hz Stereo frame=1 samples/8 bytes
    main debug: looking for audio filter module: 1 candidate
    scaletempo debug: format: 44100 rate, 2 nch, 4 bps, fl32
    scaletempo debug: params: 30 stride, 0.200 overlap, 14 search
    scaletempo debug: 1.000 scale, 1323.000 stride_in, 1323 stride_out, 1059 standing, 264 overlap, 617 search, 2204 queue, fl32 mode
    main debug: using audio filter module "scaletempo"
    main debug: TIMER module_need() : 19.997 ms - Total 19.997 ms / 1 intvls (Avg 19.997 ms)
    main debug: filter(s) 'f32l'->'f32l' 48510 Hz->44100 Hz Stereo->Stereo
    main debug: looking for audio filter module: 13 candidates
    main debug: End of video preroll
    main debug: Received first picture
    main debug: looking for video blending module: 1 candidate
    main debug: using audio filter module "speex_resampler"
    main debug: TIMER module_need() : 92.654 ms - Total 92.654 ms / 1 intvls (Avg 92.654 ms)
    main debug: End of audio preroll
    main debug: using video blending module "blend"
    main debug: TIMER module_need() : 26.155 ms - Total 26.155 ms / 1 intvls (Avg 26.155 ms)
    main debug: Post-processing available
    main debug: Decoder buffering done in 625 ms
    main warning: PTS is out of range (-31685), dropping buffer
    pulse error: cannot write: Connection terminated
Most of it may well be repetitive, but perhaps there is a clue in there somewhere; I just haven't found it yet.
tonyawards
Postby Richlion » Mon Jul 16, 2012 17:44
Hi there,
this is a bit frustrating. VLC has not had any sound despite 3-4 weeks worth of updates on SL.
I don't want to tweak the system, only if I really have to.
From my console this is what comes up upon launching VLC:
LC media player 2.0.1 Twoflower (revision 2.0.1-0-gf432547)
[0x1779e18] main interface error: no suitable interface module
[0x169f108] main libvlc error: interface "globalhotkeys,none" initialization failed
[0x169f108] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Some poeple have VLC fixed. On my configuration SMPlayer so far works, but it simply lacks the functionality.
The side effect is also that after I close VLC I cannot communicate via Skype, I get disconnected without knowing it, I have to reboot the system. In some way VLC is interfering with parts of the system.
Is there any other type of logging we can do to find out what the problems are?
On the other hand also colours are a total crap when viewing movie content in a web browser, both with Firefox and Chromuim. The content is filled with blue, especially faces.
Richlion
Postby Fitzcarraldo » Mon Jul 16, 2012 18:42
The blue faces problem is due to NVIDIA problems with Flash; see flash 11.2 w/ nvidia card colors swapped [Solved].
