codeblocks doesn't run
Postby fjkhf » Fri Jun 29, 2012 14:28
i installed codeblocks but it doesn't run.
When it begins ,it shows the screen where you choose the compiler and then it crushes immediately.
I tried to install again but still the same.
Any ideas?
Thanks!
fjkhf
Re: codeblocks doesn't run
Postby micia » Fri Jun 29, 2012 18:20
codeblocks runs perfectly here, have you installed it from entropy?
Could you post the output of:
codeblocks
from a console?
micia
Postby fjkhf » Fri Jun 29, 2012 19:19
Hello ,
yes with entropy i installed it.
From the console it runs until there,to choose the compiler and then when crushes gives:
Initializing plugins...
The program 'codeblocks' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadWindow (invalid Window parameter)'.
(Details: serial 14709 error_code 3 request_code 152 minor_code 3)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
(segmentation fault)
Thanks!
fjkhf
Postby micia » Thu Jul 05, 2012 10:18
That's pretty strange, what's the output of:
eselect wxwidgets list
Is any wxWidgets implementation selected?
micia
