GnuCash Compile with MySql options (solved)
Postby nobicycle » Wed Jun 13, 2012 10:46
Hello
I am trying to run GnuCash app-office/gnucash-2.4.10 with Mysql as its database. I tried emerge and a manual compile without success. This is what was done:
su
equo install dev-db/libdbi # needed for gnucash mysql drivers
USE="--enable-dbi"  emerge gnucash
This failed, as judged by using the new set of books wizard ... at the end only XML is available as a Save target. I noticed the configure part of emerge used --disable-dbi .. it did not pickup on USE="--enable-dbi"
Then the manual compile.
./configure   --enable-compile-warnings --enable-dbi
make
make install
Again, only XML was available as a Save target.
I would appreciate any suggestions.
Best wishes
nobicycle
Re: GnuCash Compile with MySql options (Solved)
Postby nobicycle » Fri Jun 15, 2012 4:07
Not being a portage expert, I ran the portage GUI Porthole. From there the correct USE is visible:
USE="chipcard mysql quotes sqlite webkit" emerge --nospinner =app-office/gnucash-2.4.10
"dbi" is insufficient, mysql is required.
nobicycle
Postby wolfden » Fri Jun 15, 2012 6:41
you should of filed a bug so it can get fixed
Postby nobicycle » Tue Jun 19, 2012 11:40
Bug 3419 - GnuCash Compile Options
nobicycle
Postby svantoviit » Thu Jun 21, 2012 8:28
Maybe your emerge failed because there is no such useflag as enable-dbi.
eix gnucash
[I] app-office/gnucash
     Available versions:  2.4.8 2.4.10 {{chipcard cxx debug +doc hbci mysql ofx postgres python quotes sqlite webkit}}
     Installed versions:  2.4.10(12:35:02 PM 02/26/2012)(cxx doc ofx python -chipcard -debug -hbci -mysql -postgres -quotes -sqlite -webkit)
     Homepage:            http://www.gnucash.org/
     Description:         A personal finance manager
I would try the mysql useflag instead :wink:
Edit: Now I can see, you already discovered it…
svantoviit
