Thunderbird 12.0.1 has openpgp enabled by default & it isn't something which I can disable. In add-ons I disable the enigmail add on & it says to re-start to disable. I click to re-start but it still says to re-start after thunderbird has re-started
There is no way to disable it in options.
The same is true of the additional languages in Thunderbird, I click to disable them, they should be disabled on re-starting. they remain enabled on re-start & it says again to re-start ... an infinate loop.
I notice that enigmail is not available in entropy as a seperate package (it is in portage).
How can I disable enigmail as I get the openpgp pop up every time I send an email & it's a bit annoying
Can anyone else confirm this problem? If Thunderbird has been compiled with enigmail built in I will file a bug report asking if it can be compiled without it & enigmail provided as a seperate package for those who want it.
