Problems with LyX and dead keys (us-acentos) [Solved]
Postby prosario2000 » Thu May 17, 2012 0:47
Hello everyone:
I recently installed Sabayon, and everything has been working perfectly so far. However, I have a little problem with LyX. I am a Spanish-speaking user, who has to write articles often using LyX or LaTeX, although this is the exception, not the rule. Still, I have to say that I don't have any problems regarding using accents and other diacritical signs often used in Spanish. My default keymap is "U.S. International w/dead keys" which, I assume, is "us-acentos". I have no problem using such keyboard in every software in any desktop. However, the only problem I have is I can't use it with LyX, it simply won't recognize the keyboard. Apparently it assumes it is US keyboard with no variant.
Does anyone know how to solve this problem? Thanks.
prosario2000
Re: Problems with LyX and U.S. Intl - w/dead keys (us-acento
Postby Fitzcarraldo » Fri May 18, 2012 13:04
I wonder if it is the same problem others have seen in KDE with dead keys not working (various threads in these forums)? Try the following:
equo remove --nodeps --ask ibus
(For further details, see e.g. kde aplications without accents [Solved] and Dead keys not working in several applications [Solved]).
Postby prosario2000 » Fri May 18, 2012 14:44
Yep... That was exactly the problem. It happened with all Qt based software. I did what you said, and now LyX (and everything Qt is behaving as it should) ... thank you. Sorry, it's just that I don't use many KDE stuff.
prosario2000
