Sensors do not work [Solved]
Postby limathebest » Wed May 16, 2012 16:33
I installed Xsensors, set up the sensors, but it seems that the sensors do not work. I have Debian installed on another partition, and there function normally, any idea?
Sorry for my bad English.
limathebest
Re: Sensors do not work
Postby wolfden » Thu May 17, 2012 9:35
Some more info would be handy as stating do not work doesn't tell us a thing and nobody can guess from here. Since it's an interface, I have to assume you setup lm-sensor and done that procedure? Otherwise we need errors or something to at least go on.
Postby Jomiel » Thu May 17, 2012 12:04
Telling us what you installed it for might help too (conky, panel plugin, or something else).
Jomiel
Postby limathebest » Thu May 17, 2012 16:33
Right!
When you run the command in console: xsensors, no error is reported
When you open Xsensors, it shows this:
If I run the command: sensors, the following errors are reported
No sensors found!
Make sure you loaded all the kernel drivers you need.
Try sensors-detect to Find out Which These are.
But since I ran the command sensors-detect. And answered all questions. Already restart the system and the error persists.
Any idea?
limathebest
Postby joost » Thu May 17, 2012 17:17
You need to actually start lm-sensors (as root):
/etc/init.d/lm-sensors start
to make it start at boot:
rc-update add lm-sensors
Postby limathebest » Thu May 17, 2012 18:23
Great !!!!!!
Just a small correction, the commands that worked were:
/etc/init.d/lm_sensors start
and
rc-update add lm_sensors
Thanks to all for the effort, a big hug!
limathebest
