Some libs are emtpy - how to fix?
Postby reitermaniac » Sun May 13, 2012 10:16
Yesterday after a equo upgrade process I noticed some "libs empty" Errors after installing some packages:
>>> Regenerating /etc/ld.so.cache...
/sbin/ldconfig: File /usr/lib64/libpyglib-gi-2.0-python.so.0 is empty, not checked.
/sbin/ldconfig: File /usr/lib64/libppl.so.10.0.0 is empty, not checked.
/sbin/ldconfig: File /usr/lib64/libppl.so is empty, not checked.
/sbin/ldconfig: File /usr/lib64/libpyglib-gi-2.0-python.so.0.0.0 is empty, not checked.
/sbin/ldconfig: File /usr/lib64/libppl.so.10 is empty, not checked.
/sbin/ldconfig: File /usr/lib64/libpyglib-gi-2.0-python.so is empty, not checked
I also can't run every gtk python application anymore.
Can anybody tell me which libs/packages I have to reinstall to fix it?
thx!
reitermaniac
Re: Some libs are emtpy - how to fix?
Postby svantoviit » Sun May 13, 2012 11:19
would try
equo deptest && equo libtest
but maybe your problem is the same as described here: LECTORI SALUTEM: Missing gtk+ icons/font render problems?
svantoviit
Postby reitermaniac » Sun May 13, 2012 18:09
hi,
I tested both solutions, but it doesn't fix the problem.
any other hints?
reitermaniac
Postby cl00t » Sun May 13, 2012 18:18
Which version of SL is installed?
How long since your last update?
If it's been a while & you are running an old version of entropy, update that before updating the system:
# equo install entropy equo --relaxed
cl00t
Postby svantoviit » Sun May 13, 2012 21:16
any other hints?
I would try to (re)install dev-python/pygobject-base and dev-libs/ppl then…
svantoviit
Postby reitermaniac » Tue May 15, 2012 19:02
hi,
thank you very much!! - reinstall the packages solved my problem :)
reitermaniac
