I installed SL8 on another hp laptop & went for the kde 64bit option this time rather than corecdx.
A few observations & issues:
I installed as normal, followed the wiki on things to do after a fresh install, I've done this many times without problems.
After doing "equo upgrade" my computer name was back to localhost after a reboot. I've changed that back but I don;t know why that happened.
Used kernel-switcher to get the latest kernel.
I seem to be missing some libraries:
- Code: Select all
# equo libtest
>> @@ Libraries test
>> @@ discarding directory: /usr/lib64, because it's symlinked on: /usr/lib
>> @@ discarding directory: /lib64, because it's symlinked on: /lib
>> @@ Collecting broken executables
>> @@ Attention: don't worry about libraries that are shown here but not later.
>> (14.6%) /usr/lib/icedtea7/jre/lib/amd64/libjawt.so [ libmawt.so ]
>> (15.7%) /usr/lib/opengl/nvidia/lib/libGL.so [ libnvidia-glcore.so.290.10 ]
>> (37.3%) /usr/lib/vlc/plugins/control/libglobalhotkeys_plugin.so [ libxcb-keysyms.so.1 ]
>> (62.8%) /usr/lib/opengl/nvidia/lib/libGL.so.290.10 [ libnvidia-glcore.so.290.10 ]
>> (76.7%) /usr/lib/opengl/nvidia/lib/libGL.so.1 [ libnvidia-glcore.so.290.10 ]
>> (82.8%) /usr/lib/vlc/plugins/video_output/libxcb_window_plugin.so [ libxcb-keysyms.so.1 ]
>> @@ Matching broken libraries/executables
>> @@ Libraries/Executables statistics:
>> ## Not matched:
>> => /usr/lib/opengl/nvidia/lib/libGL.so
>> => /usr/lib/opengl/nvidia/lib/libGL.so.1
>> => /usr/lib/opengl/nvidia/lib/libGL.so.290.10
- Code: Select all
# /usr/sbin/lspci | egrep "AGP|PCI Express|VGA|Display"
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5)
00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b5)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b5)
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Seymour [Radeon HD 6400M Series]
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
13:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5116 PCI Express Card Reader (rev 01)
13:00.1 SD Host controller: Realtek Semiconductor Co., Ltd. RTS5116 PCI Express Card Reader (rev 01)
- Code: Select all
# eselect opengl list
[1] ati
[2] nvidia
[3] xorg-x11 *
xorg-x11 is the only way to get opengl to work. Also, this laptop has an intel & radeon card, why does it seem to want nvidia libraries, am I missing something obvious?
Thanks
