Deluge and Gkrellm wont start after update...? [Solved]
Postby greendave8 » Sun Apr 29, 2012 16:00
Hi All,
After updating from weekly repo this morning, both Deluge and Gkrell wont start. I'd really appreciate a point in the right direction to solve these issues.
Thanks
gd8
Deluge from terminal gives this
christine@dave-sabayon ~ $ su
Password:
dave-sabayon christine # deluge
  File "/usr/bin/deluge", line 9, in <module>
    load_entry_point('deluge==1.3.5', 'gui_scripts', 'deluge')()
  File "/usr/lib64/python2.7/site-packages/deluge/main.py", line 132, in start_ui
    UI(options, args, options.args)
  File "/usr/lib64/python2.7/site-packages/deluge/ui/ui.py", line 149, in __init__
    from deluge.ui.gtkui.gtkui import GtkUI
  File "/usr/lib64/python2.7/site-packages/deluge/ui/gtkui/__init__.py", line 1, in <module>
    from gtkui import start
  File "/usr/lib64/python2.7/site-packages/deluge/ui/gtkui/gtkui.py", line 79, in <module>
    from torrentview import TorrentView
  File "/usr/lib64/python2.7/site-packages/deluge/ui/gtkui/torrentview.py", line 58, in <module>
    deluge.common.get_pixmap("downloading16.png"))
glib.GError: Couldn't recognize the image file format for file '/usr/lib64/python2.7/site-packages/deluge/data/pixmaps/downloading16.png'
and gkrellm gives this
dave-sabayon christine # gkrellm
(gkrellm:10016): GdkPixbuf-WARNING **: Error loading XPM image loader: Image type 'xpm' is not supported
(gkrellm:10016): Gtk-CRITICAL **: IA__gtk_window_set_default_icon: assertion `GDK_IS_PIXBUF (icon)' failed
  Cannot load xpm: frame_top
  Cannot load xpm: frame_bottom
  Cannot load xpm: frame_left
  Cannot load xpm: frame_right
  Cannot load xpm: bg_chart
  Cannot load xpm: bg_grid
  Cannot load xpm: bg_panel
  Cannot load xpm: bg_meter
  Cannot load xpm: decal_alarm
  Cannot load xpm: decal_warn
  Cannot load xpm: decal_misc
  Cannot load xpm: decal_button
  Cannot load xpm: krell_panel
  Cannot load xpm: krell_meter
  Cannot load xpm: krell_mail
  Cannot load xpm: krell_slider
  Cannot load xpm: krell_mini
  Cannot load xpm: (null)
gkrellm segmentation fault:    (?)
Aborted
greendave8
Re: Deluge and Gkrellm wont start after update...?
Postby sabayonino » Sun Apr 29, 2012 16:26
Pleas run deluge and gkrell as user not as root
Postby greendave8 » Sun Apr 29, 2012 16:53
Hi Sabayonino,
I tried both ways to no avail, but here is the output as user for both applications. I'm sure its a simple fix, but I aint smart enough to figure it out, been on it most of the day now....Thanks for any advice....
christine@dave-sabayon ~ $ deluge
and this is gkrell
christine@dave-sabayon ~ $ gkrellm
(gkrellm:11169): GdkPixbuf-WARNING **: Error loading XPM image loader: Image type 'xpm' is not supported
(gkrellm:11169): Gtk-CRITICAL **: IA__gtk_window_set_default_icon: assertion `GDK_IS_PIXBUF (icon)' failed
Aborted
greendave8
Postby Joecanadian » Sun Apr 29, 2012 19:08
The GdkPixbuf warning makes me wonder whether you're affected by the issue that Joost mentioned earlier today--> https://www.sabayon.org/article/missing-gtk-iconsfont-render-problems
Joecanadian
Re: Deluge and Gkrellm wont start after update...? [Solved]
Postby greendave8 » Sun Apr 29, 2012 20:32
THANK YOU Joecanadian.... You have the answer for me. Well done to Joost too!
Job done and solved see code below...
equo install x11-libs/pango x11-libs/gdk-pixbuf x11-libs/gtk+:2 x11-libs/gtk+:3
thank you
gd8
greendave8
