Java
Java
Postby joe74 » Wed Apr 11, 2012 0:49
I've just installed java (my system up-to-date with kernel 3.3), but when I try to run a simple app, or do a simple "java" command, it returns:
joe74@chilitower ~ $ java
* Home for VM 'sun-jdk-1.6' does not exist: /usr/lib/jvm/sun-jdk-1.6
* Invalid System VM: sun-jdk-1.6
Never used java before in SL, thus my question. I didn't find anything related in here.
I'm not a java user, not regular user, but needed to run this.
Thanks for the help.
joe74
Re: Java
Postby camelinahat » Wed Apr 11, 2012 13:42
Hi Joe74,
There was an issue with the default java-vm settings in some releases that may be resulting in this issue. We just need to reassign your java symlink to the correct version. Fortunately the eselect utility makes this very simple for us.
$ su
# eselect java-vm list
You will receive a list of installed java virtual machines, You may also receive a couple errors at the top that there's no such file or directory. Chances are there's one that doesn't list an error at the top, on my system it's icedtea-7. Find the correlating number with that entry. Then:
# eselect java-vm set <number>
If you also want to update your java plugin for your browser, you will need to do the same process with java-nsplugin (instead of java-vm).
camelinahat
Re: Java
Postby bernd_b » Fri Apr 13, 2012 21:20
What is wrong here?
abayon-bb / # eselect java-vm list
Available Java Virtual Machines:
grep: /usr/share/java-config-2/vm/emul-linux-x86-java-1.6: No such file or directory
grep: /usr/share/java-config-2/vm/icedtea-6: No such file or directory
grep: /usr/share/java-config-2/vm/icedtea6-bin: No such file or directory
  [1]   emul-linux-x86-java-1.6
  [2]   icedtea-6
  [3]   icedtea6-bin
  [4]   icedtea-bin-7
  [5]   sun-jdk-1.6  system-vm
sabayon-bb / # eselect java-vm set 4
!!! Error: Usage [user|system] [vm]
exiting
bernd_b
Re: Java
Postby camelinahat » Fri Apr 13, 2012 21:40
Oops, looks like I missed a setting for user specific or system wide. Try:
# eselect java-vm set system 4
Or possibly:
# eselect java-vm set system icedtea-bin-7
Unfortunately, I'm not at my PC right now to verify which
camelinahat
Re: Java
Postby bernd_b » Sat Apr 14, 2012 10:33
Oops from me too
I always tried to replace "user|system" with something like "eselect java-vm set root system 4", but of course it is as simple as you wrote.
bernd_b
Re: Java
Postby joe74 » Mon Apr 16, 2012 18:30
camelinahat wrote:Oops, looks like I missed a setting for user specific or system wide. Try:
Or possibly:
Thanks, camelinahat. It worked :)
Later for it to run the browser plugin:
eselect java-nsplugin set 64bit icedtea-7
In case you have 64bits.
joe74
