plugin needed for ulogd
Postby synux » Mon Apr 09, 2012 20:20
Hi. I am new of Sabayon.
I'd like to use ulogd working together with MySQL.
I installed ulogd-2.0.0_beta4 and created the database, but when try to start ulogd I get error because of a lost plugin.
This is what I can see in the ulogd.log :
ulogd.c:599 load_plugin: /usr/lib/ulogd/ulogd_output_MYSQL.so: cannot open shared object file: No such file or directory
How can I get the ulogd_output_MYSQL.so plugin ?
synux
Re: plugin needed for ulogd
Postby wolfden » Tue Apr 10, 2012 9:28
looks like you need to file a bug on our bugzilla
Postby synux » Tue Apr 10, 2012 20:27
wolfden wrote:looks like you need to file a bug on our bugzilla
maybe there should be some ulogd-mysql packet in the repository!
synux
Postby Stupot » Tue Apr 10, 2012 21:23
That is what http://packages.sabayon.org/show/ulogd, ... 5,standard is.
If you'll note, it was built with the mysql use flag.
USE Flags
doc
Global: Adds extra documentation (API, Javadoc, etc). It is recommended to enable per package instead of globally
mysql
Global: Adds mySQL Database support
Local: Build MYSQL output plugin to save packets in a mysql database.
postgres
Global: Adds support for the postgresql database
Local: Build PGSQL output plugin to save packets in a postgres database.
pcap
Global: Add support for network packet capture via net-libs/libpcap
Local: Build PCAP output plugin to save packets in PCAP format. Uses the net-libs/libpcap library
sqlite
Global: Adds support for sqlite - embedded sql database
Local: Build SQLITE3 output plugin to save packets in an sqlite database.
It looks like it is being maintained properly, but perhaps there is a bug in the code or in the ebuild.
Postby synux » Wed Apr 11, 2012 18:45
Stupot wrote:...
OK. Thanks for your explanation! Now I know something more.
So I should file a bug as wolfden suggested! But... how to do it? I never did it.
synux
Postby Stupot » Wed Apr 11, 2012 19:48
https://bugs.sabayon.org/
Look for "Enter a new bug request"
Give as much detail as you can. Any error logs you've got from mysql would be helpful.
Postby synux » Thu Apr 12, 2012 11:43
Bug 3228 opened. I hope it is well opened!
It is in UNCONFIRMED status. It isn't my job to change the status, right?
Thanks!
synux
Postby Stupot » Thu Apr 12, 2012 14:59
Nope, just keep your eye on it.
If the bug is closed as invalid because there aren't enough logs/ right kind of logs, then chime in and offer to collect some logs.
Other than that, your part should be done.
Postby synux » Sun Apr 22, 2012 13:44
synux wrote:Bug 3228 opened. I hope it is well opened!
Thanks!
After 10 days, the bug is still in UNCONFIRMED status. No one takes care of this bug and I can't use ulogd with mysql yet. :?:
synux
Postby synux » Fri Jun 08, 2012 11:03
Bug 3228 has been solved, now I have the mysql plugin, but still I can't start ulogd.
My ulogd plugins configuration:
plugin="/usr/lib/ulogd/ulogd_inppkt_ULOG.so"
plugin="/usr/lib/ulogd/ulogd_filter_IFINDEX.so"
plugin="/usr/lib/ulogd/ulogd_filter_IP2BIN.so"
plugin="/usr/lib/ulogd/ulogd_filter_HWHDR.so"
plugin="/usr/lib/ulogd/ulogd_output_MYSQL.so"
plugin="/usr/lib/ulogd/ulogd_raw2packet_BASE.so"
stack=ulog1:ULOG,base1:BASE,ifi1:IFINDEX,ip2bin1:IP2BIN,mac2str1:HWHDR,mysql1:MYSQL
[ulog1]
nlgroup=1
[mysql1]
db="ulogd"
host="localhost"
user="xxxx"
table="ulog"
pass="xxxxxxxx"
procedure="INSERT_PACKET_FULL"
in ulogd.log:
Fri Jun  8 13:31:06 2012 <5> ulogd.c:372 registering plugin `ULOG'
Fri Jun  8 13:31:06 2012 <5> ulogd.c:372 registering plugin `IFINDEX'
Fri Jun  8 13:31:06 2012 <5> ulogd.c:372 registering plugin `IP2BIN'
Fri Jun  8 13:31:06 2012 <5> ulogd.c:372 registering plugin `HWHDR'
Fri Jun  8 13:31:06 2012 <5> ulogd.c:372 registering plugin `MYSQL'
Fri Jun  8 13:31:06 2012 <5> ulogd.c:372 registering plugin `BASE'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:811 building new pluginstance stack (ulog1:ULOG,base1:BASE,ifi1:IFINDEX,ip2bin1:IP2BIN,mac2str1:HWHDR,mysql1:MYSQL):
Fri Jun  8 13:31:06 2012 <1> ulogd.c:820 tok=`ulog1:ULOG'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:856 pushing `ULOG' on stack
Fri Jun  8 13:31:06 2012 <1> ulogd.c:820 tok=`base1:BASE'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:856 pushing `BASE' on stack
Fri Jun  8 13:31:06 2012 <1> ulogd.c:820 tok=`ifi1:IFINDEX'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:856 pushing `IFINDEX' on stack
Fri Jun  8 13:31:06 2012 <1> ulogd.c:820 tok=`ip2bin1:IP2BIN'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:856 pushing `IP2BIN' on stack
Fri Jun  8 13:31:06 2012 <1> ulogd.c:820 tok=`mac2str1:HWHDR'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:856 pushing `HWHDR' on stack
Fri Jun  8 13:31:06 2012 <1> ulogd.c:820 tok=`mysql1:MYSQL'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:856 pushing `MYSQL' on stack
Fri Jun  8 13:31:06 2012 <1> ulogd.c:646 traversing plugin `MYSQL'
Fri Jun  8 13:31:06 2012 <5> ../../util/db.c:144 (re)configuring
Fri Jun  8 13:31:06 2012 <1> ulogd_output_MYSQL.c:131 42 fields in table
Fri Jun  8 13:31:06 2012 <1> ulogd.c:646 traversing plugin `HWHDR'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:646 traversing plugin `IP2BIN'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:646 traversing plugin `IFINDEX'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:646 traversing plugin `BASE'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:646 traversing plugin `ULOG'
Fri Jun  8 13:31:06 2012 <1> ulogd.c:662 connecting input/output keys of stack:
Fri Jun  8 13:31:06 2012 <1> ulogd.c:670 traversing plugin `MYSQL'
Fri Jun  8 13:31:06 2012 <7> ulogd.c:727 cannot find key `pwsniff.user' in stack
Fri Jun  8 13:31:06 2012 <1> ulogd.c:863 destroying stack
Fri Jun  8 13:31:06 2012 <8> ulogd.c:1179 not even a single working plugin stack
May I have some help?!
synux
