freemind issue
freemind issue
Postby MmadA » Tue Mar 20, 2012 13:20
I'm trying to run freemind, but I'm getting:
$ freemind
  File "/usr/bin/gjl-2.7", line 273, in <module>
    env = get_env(pkg)
  File "/usr/bin/gjl-2.7", line 215, in get_env
    env = manager.build_dep_env_vars([package.name()], set())
  File "/usr/lib/python2.7/site-packages/java_config_2/EnvironmentManager.py", line 401, in build_dep_env_vars
    self.add_pkg_env_vars(pkg, env)
  File "/usr/lib/python2.7/site-packages/java_config_2/EnvironmentManager.py", line 373, in add_pkg_env_vars
    val = pkg.query(var)
  File "/usr/lib/python2.7/site-packages/java_config_2/Virtual.py", line 175, in query
    return self.get_provider().query(var)
  File "/usr/lib/python2.7/site-packages/java_config_2/VM.py", line 54, in query
    raise EnvironmentUndefinedError
java_config_2.Errors.EnvironmentUndefinedError
Couldn't get needed information
I'm using Sun JRE 1.6.0.29:
$ java-config -L
JAVA_HOME
JAVA_HOME
The following VMs are available for generation-2:
BUILD_ONLY
VERSION
1)      IcedTea-bin 6.1.10.4 [icedtea-bin-6]
BUILD_ONLY
VERSION
2)      Sun JDK 1.6.0.26 [sun-jdk-1.6]
BUILD_ONLY
VERSION
*)      Sun JRE 1.6.0.29 [sun-jre-bin-1.6]
What can be reason of this Traceback?
MmadA
Re: freemind issue
Postby joost » Tue Mar 20, 2012 13:24
You should use:
eselect java-vm
Re: freemind issue
Postby MmadA » Tue Mar 20, 2012 13:34
It was:
$ eselect java-vm list
Available Java Virtual Machines:
grep: /usr/share/java-config-2/vm/icedtea6-bin: Nie ma takiego pliku ani katalogu
  [1]   icedtea6-bin
  [2]   icedtea-bin-6
  [3]   sun-jdk-1.6
  [4]   sun-jre-bin-1.6  system-vm
I have now:
  [1]   icedtea6-bin
  [2]   icedtea-bin-6
  [3]   sun-jdk-1.6
  [4]   sun-jre-bin-1.6  system-vm user-vm
But I have the same issue. Thanks for clues.
MmadA
Re: freemind issue
Postby joost » Tue Mar 20, 2012 13:44
I'd try:
equo install dev-java/icedtea-6.1.11.1
Then select the system to use this vm:
eselect java-vm set system icedtea-6
Re: freemind issue
Postby MmadA » Tue Mar 20, 2012 13:59
With I'm icedtea-6 getting different issue...
adam@sabayon ~ $ LANG=EN_en freemind
/usr/share/java-config-2/launcher/launcher.bash: line 60: PROVIDES_VERSION: command not found
/usr/share/java-config-2/launcher/launcher.bash: line 60: ENV_VARS: command not found
Exception in thread "main" java.lang.NoClassDefFoundError: freemind/main/FreeMindStarter
Caused by: java.lang.ClassNotFoundException: freemind.main.FreeMindStarter
        at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
Could not find the main class: freemind.main.FreeMindStarter. Program will exit.
adam@sabayon ~ $ LANG=EN_en eselect java-vm list
grep: /usr/share/java-config-2/vm/icedtea6-bin: No such file or directory
  [1]   icedtea-6  system-vm user-vm
  [2]   icedtea-bin-6
  [3]   icedtea6-bin
  [4]   sun-jdk-1.6
  [5]   sun-jre-bin-1.6
MmadA
Re: freemind issue
Postby joost » Tue Mar 20, 2012 14:07
viewtopic.php?f=76&t=26779&p=147257&hilit=freemind#p147257
This user was succesfull launching it with icedtea 7, so perhaps you need to use that one.
Re: freemind issue
Postby MmadA » Tue Mar 20, 2012 14:35
It looks like I'm not so lucky.
adam@sabayon ~ $ freemind
--package freemind --get-args --get-vm
/usr/share/java-config-2/launcher/launcher.bash: line 61: PROVIDES_VERSION: command not found
/usr/share/java-config-2/launcher/launcher.bash: line 61: ENV_VARS: command not found
Error: Could not find or load main class freemind.main.FreeMindStarter
adam@sabayon ~ $ eselect java-vm list
  [1]   icedtea-6
  [2]   icedtea-7  system-vm user-vm
  [3]   icedtea-bin-6
  [4]   icedtea6-bin
  [5]   sun-jdk-1.6
  [6]   sun-jre-bin-1.6
adam@sabayon ~ $
'PROVIDES_VERSION and ENV_VARS commands not found' probably because in /usr/share/java-config-2/launcher/launcher.bash: line 61 we are doing eval $results and $results are:
$ gjl --package freemind --get-args --get-vm
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_TYPE
PROVIDES_VERSION
PROVIDES_TYPE
PROVIDES_VERSION
PROVIDES_TYPE
PROVIDES_VERSION
PROVIDES_TYPE
PROVIDES_VERSION
PROVIDES_TYPE
JAVA_HOME
JAVA_HOME
JAVA_HOME
JAVA_HOME
JAVA_HOME
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
JAVA_HOME
PROVIDES_VERSION
PROVIDES_TYPE
PROVIDES_VERSION
PROVIDES_TYPE
PROVIDES_VERSION
PROVIDES_TYPE
PROVIDES_VERSION
PROVIDES_TYPE
PROVIDES_VERSION
PROVIDES_TYPE
JAVA_HOME
JAVA_HOME
JAVA_HOME
JAVA_HOME
JAVA_HOME
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
PROVIDES_VERSION
TARGET
PROVIDES_VERSION
LIBRARY_PATH
LIBRARY_PATH
gjl_args=" -classpath /usr/share/xsdlib/lib/xsdlib.jar:/usr/share/jaxme/lib/jaxmejs.jar:/usr/share/xml-xmlbeans-1/lib/xbean.jar:/usr/share/xml-commons-resolver/lib/xml-commons-resolver.jar:/usr/share/ant-core/lib/ant.jar:/usr/share/batik-1.7/lib/batik-svgpp.jar:/usr/share/jibx/lib/jibx-bind.jar:/usr/share/freemind//plugins/svg/svg_plugin.jar:/usr/share/batik-1.7/lib/batik-extension.jar:/usr/share/jdom-1.0/lib/jdom.jar:/usr/share/xmlgraphics-commons-1.3/lib/xmlgraphics-commons.jar:/usr/share/xpp3/lib/xpp3.jar:/usr/share/javahelp/lib/jsearch-indexer.jar:/usr/share/rhino-1.6/lib/js.jar:/usr/share/xalan-serializer/lib/serializer.jar:/usr/share/xerces-2/lib/xercesImpl.jar:/usr/share/ant-core/lib/ant-launcher.jar:/usr/share/javahelp/lib/jh-client.jar:/usr/share/javahelp/lib/jhall.jar:/usr/share/jaxme/lib/jaxmexs.jar:/usr/share/commons-logging/lib/commons-logging-adapters.jar:/usr/share/avalon-framework-4.2/lib/avalon-framework.jar:/usr/share/batik-1.7/lib/batik-css.jar:/usr/share/simplyhtml/lib/SimplyHTML.jar:/usr/share/batik-1.7/lib/batik-slideshow.jar:/usr/share/dom4j-1/lib/dom4j.jar:/usr/share/jibx/lib/jibx-extras.jar:/usr/share/jdom-jaxen-1.0/lib/jdom-jaxen.jar:/usr/share/tomcat-servlet-api-2.4/lib/jsp-api.jar:/usr/share/xpp2/lib/PullParser-standard.jar:/usr/share/batik-1.7/lib/batik-squiggle.jar:/usr/share/xalan/lib/xalan.jar:/usr/share/jython/lib/jython.jar:/usr/share/batik-1.7/lib/RasterizerTask.jar:/usr/share/relaxng-datatype/lib/relaxngDatatype.jar:/usr/share/bcel/lib/bcel.jar:/usr/share/tomcat-servlet-api-2.2/lib/servlet.jar:/usr/share/batik-1.7/lib/batik-util.jar:/usr/share/xom/lib/xom.jar:/usr/share/batik-1.7/lib/batik-script.jar:/usr/share/batik-1.7/lib/batik-xml.jar:/usr/share/batik-1.7/lib/batik-all.jar:/usr/share/javahelp/lib/jsearch.jar:/usr/share/jgoodies-forms/lib/forms.jar:/usr/share/javacup/lib/javacup.jar:/usr/share/xmldb/lib/xmldb-api-sdk.jar:/usr/share/fop/lib/fop-sandbox.jar:/usr/share/javahelp/lib/jsearch-client.jar:/usr/share/batik-1.7/lib/batik-parser.jar:/usr/share/xpp2/lib/PullParser-x2.jar:/usr/share/commons-io-1/lib/commons-io.jar:/usr/share/xpp2/lib/PullParser.jar:/usr/share/jaxen-1.1/lib/jaxen.jar:/usr/share/batik-1.7/lib/batik-codec.jar:/usr/share/xml-commons-external-1.3/lib/xml-apis-ext.jar:/usr/share/batik-1.7/lib/batik-transcoder.jar:/usr/share/avalon-logkit-2.0/lib/avalon-logkit.jar:/usr/share/batik-1.7/lib/batik-anim.jar:/usr/share/jaxme/lib/jaxme2.jar:/usr/share/antlr/lib/antlr.jar:/usr/share/javahelp/lib/jsearch-misc.jar:/usr/share/servletapi-2.4/lib/servlet-api.jar:/usr/share/ant-core/lib/ant-bootstrap.jar:/usr/share/jsr173/lib/jsr173.jar:/usr/share/log4j/lib/log4j.jar:/usr/share/jaxme/lib/jaxmeapi.jar:/usr/share/servletapi-2.4/lib/jsp-api.jar:/usr/share/batik-1.7/lib/batik-ext.jar:/usr/share/sun-javamail/lib/mail.jar:/usr/share/xml-commons-external-1.3/lib/xml-apis.jar:/usr/share/batik-1.7/lib/batik-bridge.jar:/usr/share/fop/lib/fop.jar:/usr/share/commons-logging/lib/commons-logging.jar:/usr/share/batik-1.7/lib/batik-dom.jar:/usr/share/batik-1.7/lib/batik-ttf2svg.jar:/usr/share/simplyhtml/lib/SimplyHTMLHelp.jar:/usr/share/jaxme/lib/jaxmepm.jar:/usr/share/xpp2/lib/PullParser-intf.jar:/usr/share/gnu-regexp-1/lib/gnu-regexp.jar:/usr/share/sun-jms/lib/jms.jar:/usr/share/batik-1.7/lib/batik-svggen.jar:/usr/share/iso-relax/lib/isorelax.jar:/usr/share/freemind/lib/freemind.jar:/usr/share/tomcat-servlet-api-2.3/lib/servlet.jar:/usr/share/batik-1.7/lib/batik-awt-util.jar:/usr/share/hsqldb/lib/hsqldb.jar:/usr/share/jibx/lib/jibx-run.jar:/usr/share/batik-1.7/lib/batik-rasterizer.jar:/usr/share/batik-1.7/lib/batik-gui-util.jar:/usr/share/javahelp/lib/jh.jar:/usr/share/junit/lib/junit.jar:/usr/share/freemind//plugins/help/help_plugin.jar:/usr/share/jaxme/lib/jaxme2-rt.jar:/usr/share/msv/lib/msv.jar:/usr/share/tomcat-servlet-api-2.4/lib/servlet-api.jar:/usr/share/xmldb/lib/xmldb-api.jar:/usr/share/freemind/lib/bindings.jar:/usr/share/saxpath/lib/saxpath.jar:/usr/share/commons-logging/lib/commons-logging-api.jar:/usr/share/javahelp/lib/jhbasic.jar:/usr/share/batik-1.7/lib/batik-svg-dom.jar:/usr/share/libreadline-java/lib/libreadline-java.jar:/usr/share/batik-1.7/lib/batik-gvt.jar:/usr/share/batik-1.7/lib/batik-swing.jar -Djava.library.path="/usr/lib/libreadline-java:/lib:/usr/lib"";
ENV_VARS
JAVA_HOME
JDK_HOME
JAVAC
PATH
ROOTPATH
LDPATH
MANPATH
ENV_VARS
JAVA_HOME
JDK_HOME
JAVAC
PATH
ROOTPATH
LDPATH
MANPATH
export JAVA_HOME="/usr/lib/icedtea7";
export JDK_HOME="/usr/lib/icedtea7";
export JAVAC="/usr/lib/icedtea7/bin/javac";
export ROOTPATH="/usr/lib/icedtea7/bin:/usr/lib/icedtea7/jre/bin";
export MANPATH="/usr/lib/icedtea7/man";
export PATH="/usr/lib/icedtea7/bin:/usr/lib/icedtea7/jre/bin";
export LDPATH="/usr/lib/icedtea7/jre/lib/i386/:/usr/lib/icedtea7/jre/lib/i386/native_threads/:/usr/lib/icedtea7/jre/lib/i386/xawt/:/usr/lib/icedtea7/jre/lib/i386/server/";
But I'm not sure what about "Error: Could not find or load main class freemind.main.FreeMindStarter"...
MmadA
Re: freemind issue
Postby tblu » Mon Jun 04, 2012 5:48
Hi there,
freemind is working for me using:
[6] oracle-jdk-bin-1.7 system-vm
tblu
