Pov-Ray and related install issues
Postby msdobrescu » Tue Mar 13, 2012 19:18
I try to install povray. I have chosen povtree and kpovmodeler also.
Sabayon is up to date, there are several errors during the installation.
Here is the install log:
(1/6) Fetching: media-gfx/povtree-1.5
   ## Downloading: media-gfx:povtree-1.5~1.tbz2
   ## ( mirror #1 ) Downloading from: http://ftp.surfnet.nl
   ## ( mirror #1 ) Successfully downloaded from: http://ftp.surfnet.nl at 1.8MB/second
   ## Package checksum matches: media-gfx:povtree-1.5~1.tbz2
      : GPG matches
      : SHA1 matches
      : SHA256 disabled
      : SHA512 disabled
(2/6) Fetching: media-gfx/povray-3.7.0_rc3-r1
   ## Package checksum matches: media-gfx:povray-3.7.0_rc3-r1~0.tbz2
(3/6) Fetching: media-gfx/kpovmodeler-1.1.3
   ## Package checksum matches: media-gfx:kpovmodeler-1.1.3~0.tbz2
(4/6) Installing: media-gfx/povtree-1.5
   ## Unpacking: media-gfx:povtree-1.5~1.tbz2
   ## Installing package: media-gfx/povtree-1.5
   ## [Tree generator for POVray based on TOMTREE macro]
   ## Updating database: media-gfx/povtree-1.5
   ## Cleaning previously installed application data.
>>> Regenerating /etc/ld.so.cache...
   ## Cleaning: media-gfx/povtree-1.5
(5/6) Installing: media-gfx/povray-3.7.0_rc3-r1
   ## Unpacking: media-gfx:povray-3.7.0_rc3-r1~0.tbz2
   ## SPM: pre-install phase
ls: cannot access /etc/povray: No such file or directory
   ## Installing package: media-gfx/povray-3.7.0_rc3-r1
   ## [The Persistence of Vision Raytracer]
   ## Updating database: media-gfx/povray-3.7.0_rc3-r1
   ## Cleaning: media-gfx/povray-3.7.0_rc3-r1
(6/6) Installing: media-gfx/kpovmodeler-1.1.3
   ## Unpacking: media-gfx:kpovmodeler-1.1.3~0.tbz2
   ## SPM: setup phase
 * ERROR: media-gfx/kpovmodeler-1.1.3 failed (setup phase):
 *   Failed to determine KDEDIR!
 * Call stack:
 *     ebuild.sh, line   85:  Called pkg_setup
 *   environment, line 3587:  Called kde4-base_pkg_setup
 *   environment, line 2983:  Called die
 *               [[ -z ${KDEDIR} ]] && die "Failed to determine KDEDIR!";
 * If you need support, post the output of 'emerge --info =media-gfx/kpovmodeler-1.1.3',
 * the complete build log and the output of 'emerge -pqv =media-gfx/kpovmodeler-1.1.3'.
 * The complete build log is located at '/var/tmp/entropy/packages/amd64/5/media-gfx_kpovmodeler-1.1.3_0.tbz2/portage/media-gfx/kpovmodeler-1.1.3/temp/build.log'.
 * The ebuild environment file is located at '/var/tmp/entropy/packages/amd64/5/media-gfx_kpovmodeler-1.1.3_0.tbz2/portage/media-gfx/kpovmodeler-1.1.3/temp/environment'.
 * S: '/var/tmp/entropy/packages/amd64/5/media-gfx_kpovmodeler-1.1.3_0.tbz2/portage/media-gfx/kpovmodeler-1.1.3/work/kpovmodeler-1.1.3'
   ## Installing package: media-gfx/kpovmodeler-1.1.3
   ## [A modeling and composition program for creating POV-Ray(TM) scenes]
   ## Updating database: media-gfx/kpovmodeler-1.1.3
   ## SPM: post-install phase
   ## Cleaning: media-gfx/kpovmodeler-1.1.3
Am I the only one having this issue?
Thank you.
msdobrescu
Re: Pov-Ray and related install issues
Postby joost » Tue Mar 13, 2012 19:29
No it has to do with the SPM hook that is using an old kde eclass.
I'll have to revision bump this package.
Postby msdobrescu » Tue Mar 13, 2012 20:08
You are awesome!
Additionally, if I try to run povray, it says:
povray: cannot open the user configuration file /home/<my user>/.povray/3.7/povray.conf: No such file or directory
This shouldn't have to do with KDE, isn't it?
There are also a couple of errors:
The directory is created during installation, though.
msdobrescu
Postby joost » Tue Mar 13, 2012 21:28
I'd try this:
equo remove media-gfx/povray --nodeps --configfiles
rm -rf /etc/povray
equo install  media-gfx/povray
Postby msdobrescu » Tue Mar 13, 2012 21:45
It looks the same.
>>  @@ Calculating dependencies ...
>>  ## [N] [sabayon-weekly] media-gfx/povray-3.7.0_rc3-r1|0
>>  @@ Packages needing to be installed/updated/downgraded: 1
>>  @@ Packages needing to be removed: 0
>>  @@ Download size: 0b
>>  @@ Used disk space: 18.0MB
>>  @@ You need at least: 39.4MB of free space
>>  :: (1/1) >>> 1 package
>>  ++ (1/1) >>> media-gfx/povray-3.7.0_rc3-r1
>>  @@ Installation complete.
>>  @@ Configuration files scan complete.
msdobrescu
Postby joost » Tue Mar 13, 2012 21:50
I see there is some unusual voodoo in the povray ebuild:
pkg_preinst() {
   # Copy the old config files if they are in the old location
   # but do not yet exist in the new location.
   # This way, they can be treated by CONFIG_PROTECT as normal.
   for conf_file in $(ls "${ED}/etc/${PN}"); do
      if [ ! -e "${EROOT}etc/${PN}/${conf_file}" ]; then
         for version_dir in $(ls "${EROOT}etc/${PN}" | grep "^[0-9]" | sort -rn); do
            if [ -e "${EROOT}etc/${PN}/${version_dir}/${conf_file}" ]; then
               mv "${EROOT}etc/${PN}/${version_dir}/${conf_file}" "${EROOT}etc/${PN}"
               elog "Note: ${conf_file} moved from ${EROOT}etc/povray/${version_dir}/ to ${EROOT}etc/povray/"
               break
            fi
         done
      fi
   done
I'll have a look.
Postby msdobrescu » Sat Oct 06, 2012 9:29
Hi, any news?
I think it is the same version in the repos, isn't it?
msdobrescu
