Macro recorder
Macro recorder
Postby mpmills » Tue Mar 13, 2012 4:04
Probably a question I overlooked but Im looking for a multi-function macro recorder. I found Xmacro but its no longer being supported? I found xnee, but the GNU (gnee) isnt in the supported list. Im not yet at the understanding lever for command lines etc, outside of updating the system and installing supported packages, so anyone have any suggestions?
Moderator Edit: Subject changed to Sentence case. Please don't use upper case.
registered Linux user number 371609
HP Pavilion a1410n 3gig Ram 360gig AMD64 Sabayon 8 XFCE
mpmills
Re: Macro recorder
Postby Fitzcarraldo » Tue Mar 13, 2012 6:07
Check out AutoKey (doesn't record, but can be configured to play macros) and Easystroke (records and plays), which may satisfy your needs. You can use the SL Forums 'Search' facility with keywords "AutoKey" and "Easystroke" to throw up a few recent threads about them.
Re: Macro recorder
Postby mpmills » Mon Mar 19, 2012 4:09
Interesting software but I am looking for the lines of repetitive actions such as to record, replay and continue user actions. I ran across Xgee but no GUI. I installed xnee, currently cnee is on my pc, I will have to look deeper on what its actually capable of, I last had a program that could read color codes and execute said parameters etc. more homework I guess.
mpmills
Re: Macro recorder
Postby mpmills » Fri Mar 23, 2012 19:50
this looks more advanced than I found, but still somewhat limited. how irritating.
mpmills
Re: Macro recorder
Postby Fitzcarraldo » Sun Mar 25, 2012 1:21
Well, you could try xnee. Version 3.11 is in the Entropy weekly repository, and version 3.12 is in Portage.
http://itupw056.itu.chalmers.se/project-xnee//
Xnee consists of a library, two applications and a Gnome panel applet
cnee (cnee's not an event emulator) - Command line program
gnee (gnee's not an emulator either) - Graphical User Interface (GUI) program
pnee (pnee's not even emulating) - Gnome Panel Applet
libxnee (libxnee is basically xnee) - Library used by cnee, pnee and gnee
Never tried it myself, as AutoKey and Easystroke run all the macros I need.
Users browsing this forum: maulbongo and 2 guests
