Digikam crashes after todays updates 11/03
Postby cl00t » Sun Mar 11, 2012 10:13
After installing todays updates Digikam crashes. I was sure to do equo conf update / deptest / libtest.
After rebooting I ran Digikam & it crashed on opening, so I deleted the digikamrc config file & digikam dir in .kde.
I also deleted the digikam database.
Digikam now starts correctly, I can change settings ok, choose a new location for images, but as soon as I choose a directory in the 'My Albums' tree to view its images, the kde crash handler appears.
I can also rebuild my image thumbnail database, but clicking on a dir in the album tree crashes Digikam.
I'm not sure what info I can post here to help if someone can guide me on that please?
ps it worked yesterday ok, before the updates today & I am running SL 8 corecdx with kde added. I use entropy only, not portage or any other manually installed apps.
Thank you.
cl00t
Re: Digikam crashes after todays updates 11/03
Postby cl00t » Sun Mar 11, 2012 11:53
Ok, I create clonezilla backups every saturday, so I restored yesterdays backup.
To be sure, I ran digikam & was able to use it without problems.
Installed todays updates again & the same problem exists as in above post, I cannot select images in the album view without it crashing.
cl00t
Postby dunsurfin » Sun Mar 11, 2012 14:24
I can confirm digikam crashing on my machine. Running digikam from a command line I get the following:
robin@robin2 ~ $ digikam
QSqlDatabasePrivate::removeDatabase: connection 'ConnectionTest' is still in use, all queries will cease to work.
*** glibc detected *** digikam: free(): invalid pointer: 0xa8f4ca48 ***
======= Backtrace: =========
/lib/libc.so.6(+0x6df72)[0xb4678f72]
/lib/libc.so.6(+0x6ebfa)[0xb4679bfa]
/lib/libc.so.6(cfree+0x6d)[0xb467cc8d]
/usr/lib/opengl/nvidia/lib/libnvidia-tls.so.295.20(+0x1d43)[0xaf84cd43]
[0xffcbc1bd]
======= Memory map: ========
08048000-08548000 r-xp 00000000 08:07 6704386    /usr/bin/digikam
08548000-08549000 r--p 004ff000 08:07 6704386    /usr/bin/digikam
08549000-0854e000 rw-p 00500000 08:07 6704386    /usr/bin/digikam
0854e000-08550000 rw-p 00000000 00:00 0
0a09d000-0c2f9000 rw-p 00000000 00:00 0          [heap]
96d68000-96d69000 ---p 00000000 00:00 0
96d69000-97569000 rw-p 00000000 00:00 0
97569000-9756a000 ---p 00000000 00:00 0
9756a000-97d6a000 rw-p 00000000 00:00 0
97d6a000-97d6b000 ---p 00000000 00:00 0
97d6b000-9856b000 rw-p 00000000 00:00 0
9856b000-987b3000 rw-s 00000000 00:04 11567138   /SYSV00000000 (deleted)
987b3000-987fd000 r-xp 00000000 08:07 6704449    /usr/lib/kde4/digikamimageplugin_transform.so
987fd000-987fe000 r--p 0004a000 08:07 6704449    /usr/lib/kde4/digikamimageplugin_transform.so
987fe000-987ff000 rw-p 0004b000 08:07 6704449    /usr/lib/kde4/digikamimageplugin_transform.so
987ff000-98841000 r-xp 00000000 08:07 6704446    /usr/lib/kde4/digikamimageplugin_enhance.so
98841000-98843000 r--p 00041000 08:07 6704446    /usr/lib/kde4/digikamimageplugin_enhance.so
98843000-98844000 rw-p 00043000 08:07 6704446    /usr/lib/kde4/digikamimageplugin_enhance.so
98844000-9884d000 r-xp 00000000 08:07 5009491    /usr/lib/libkpty.so.4.8.0
9884d000-9884e000 r--p 00008000 08:07 5009491    /usr/lib/libkpty.so.4.8.0
9884e000-9884f000 rw-p 00009000 08:07 5009491    /usr/lib/libkpty.so.4.8.0
9884f000-98936000 r-xp 00000000 08:07 5009414    /usr/lib/libkde3support.so.4.8.0
98936000-9893c000 r--p 000e7000 08:07 5009414    /usr/lib/libkde3support.so.4.8.0
9893c000-9893e000 rw-p 000ed000 08:07 5009414    /usr/lib/libkde3support.so.4.8.0
98961000-98980000 r-xp 00000000 08:07 6704448    /usr/lib/kde4/digikamimageplugin_fxfilters.so
98980000-98981000 r--p 0001e000 08:07 6704448    /usr/lib/kde4/digikamimageplugin_fxfilters.so
98981000-98982000 rw-p 0001f000 08:07 6704448    /usr/lib/kde4/digikamimageplugin_fxfilters.so
98982000-989a7000 r-xp 00000000 08:07 6704445    /usr/lib/kde4/digikamimageplugin_decorate.so
989a7000-989a8000 r--p 00025000 08:07 6704445    /usr/lib/kde4/digikamimageplugin_decorate.so
989a8000-989a9000 rw-p 00026000 08:07 6704445    /usr/lib/kde4/digikamimageplugin_decorate.so
989a9000-989d9000 r-xp 00000000 08:07 6704444    /usr/lib/kde4/digikamimageplugin_color.so
989d9000-989da000 r--p 0002f000 08:07 6704444    /usr/lib/kde4/digikamimageplugin_color.so
989da000-989db000 rw-p 00030000 08:07 6704444    /usr/lib/kde4/digikamimageplugin_color.so
989db000-989dc000 ---p 00000000 00:00 0
989dc000-991dc000 rw-p 00000000 00:00 0
991dc000-991e5000 r-xp 00000000 08:07 7130072    /usr/lib/kde4/kipiplugin_kopete.so
991e5000-991e6000 r--p 00008000 08:07 7130072    /usr/lib/kde4/kipiplugin_kopete.so
991e6000-991e7000 rw-p 00009000 08:07 7130072    /usr/lib/kde4/kipiplugin_kopete.so
991e7000-99201000 r-xp 00000000 08:07 7130079    /usr/lib/kde4/kipiplugin_rawconverter.so
99201000-99202000 r--p 0001a000 08:07 7130079    /usr/lib/kde4/kipiplugin_rawconverter.so
99202000-99203000 rw-p 0001b000 08:07 7130079    /usr/lib/kde4/kipiplugin_rawconverter.so
99203000-99231000 r-xp 00000000 08:07 7130058    /usr/lib/kde4/kipiplugin_facebook.so
99231000-99232000 r--p 0002d000 08:07 7130058    /usr/lib/kde4/kipiplugin_facebook.so
99232000-99233000 rw-p 0002e000 08:07 7130058    /usr/lib/kde4/kipiplugin_facebook.so
99233000-9934f000 r-xp 00000000 08:07 7130022    /usr/lib/kde4/kipiplugin_dngconverter.so
9934f000-99350000 ---p 0011c000 08:07 7130022    /usr/lib/kde4/kipiplugin_dngconverter.so
99350000-99353000 r--p 0011c000 08:07 7130022    /usr/lib/kde4/kipiplugin_dngconverter.so
99353000-99355000 rw-p 0011f000 08:07 7130022    /usr/lib/kde4/kipiplugin_dngconverter.so
99355000-99356000 rw-p 00000000 00:00 0
99356000-993cd000 r-xp 00000000 08:07 7130073    /usr/lib/kde4/kipiplugin_metadataedit.so
993cd000-993d0000 r--p 00077000 08:07 7130073    /usr/lib/kde4/kipiplugin_metadataedit.so
993d0000-993d1000 rw-p 0007a000 08:07 7130073    /usr/lib/kde4/kipiplugin_metadataedit.so
993d1000-99404000 r-xp 00000000 08:07 5954223    /usr/lib/libxslt.so.1.1.26
99404000-99405000 r--p 00032000 08:07 5954223    /usr/lib/libxslt.so.1.1.26
99405000-99406000 rw-p 00033000 08:07 5954223    /usr/lib/libxslt.so.1.1.26
99406000-99426000 r-xp 00000000 08:07 7130064    /usr/lib/kde4/kipiplugin_galleryexport.so
99426000-99427000 r--p 0001f000 08:07 7130064    /usr/lib/kde4/kipiplugin_galleryexport.so
99427000-99428000 rw-p 00020000 08:07 7130064    /usr/lib/kde4/kipiplugin_galleryexport.so
99428000-99446000 r-xp 00000000 08:07 7130071    /usr/lib/kde4/kipiplugin_kmlexport.so
99446000-99447000 r--p 0001e000 08:07 7130071    /usr/lib/kde4/kipiplugin_kmlexport.so
99447000-99448000 rw-p 0001f000 08:07 7130071    /usr/lib/kde4/kipiplugin_kmlexport.so
99448000-9944a000 r--p 00000000 08:07 7131065    /usr/share/locale/en_GB/LC_MESSAGES/kipiplugin_htmlexport.mo
9944a000-99477000 r-xp 00000000 08:07 7130066    /usr/lib/kde4/kipiplugin_htmlexport.so
99477000-99479000 r--p 0002c000 08:07 7130066    /usr/lib/kde4/kipiplugin_htmlexport.so
99479000-9947a000 rw-p 0002e000 08:07 7130066    /usr/lib/kde4/kipiplugin_htmlexport.so
9947a000-995d6000 r-xp 00000000 08:07 7130074    /usr/lib/kde4/kipiplugin_photolayoutseditor.so
995d6000-995de000 r--p 0015b000 08:07 7130074    /usr/lib/kde4/kipiplugin_photolayoutseditor.so
995de000-995e0000 rw-p 00163000 08:07 7130074    /usr/lib/kde4/kipiplugin_photolayoutseditor.so
995e0000-99611000 r-xp 00000000 08:07 7130084    /usr/lib/kde4/kipiplugin_yandexfotki.so
99611000-99612000 r--p 00030000 08:07 7130084    /usr/lib/kde4/kipiplugin_yandexfotki.so
99612000-99613000 rw-p 00031000 08:07 7130084    /usr/lib/kde4/kipiplugin_yandexfotki.so
99613000-99646000 r-xp 00000000 08:07 7130075    /usr/lib/kde4/kipiplugin_picasawebexport.so
99646000-99647000 ---p 00033000 08:07 7130075    /usr/lib/kde4/kipiplugin_picasawebexport.so
99647000-99648000 r--p 00033000 08:07 7130075    /usr/lib/kde4/kipiplugin_picasawebexport.so
99648000-99649000 rw-p 00034000 08:07 7130075    /usr/lib/kde4/kipiplugin_picasawebexport.so
99649000-996cb000 r-xp 00000000 08:07 7130065    /usr/lib/kde4/kipiplugin_gpssync.so
996cb000-996cc000 ---p 00082000 08:07 7130065    /usr/lib/kde4/kipiplugin_gpssync.so
996cc000-996cf000 r--p 00082000 08:07 7130065    /usr/lib/kde4/kipiplugin_gpssync.so
996cf000-996d0000 rw-p 00085000 08:07 7130065    /usr/lib/kde4/kipiplugin_gpssync.so
996d0000-99732000 r-xp 00000000 08:07 7130018    /usr/lib/kde4/kipiplugin_batchprocessimages.so
99732000-99735000 r--p 00062000 08:07 7130018    /usr/lib/kde4/kipiplugin_batchprocessimages.so
99735000-99736000 rw-p 00065000 08:07 7130018    /usr/lib/kde4/kipiplugin_batchprocessimages.so
99736000-99758000 r-xp 00000000 08:07 5105664    /usr/lib/libqjson.so.0.7.1
99758000-99759000 r--p 00021000 08:07 5105664    /usr/lib/libqjson.so.0.7.1
99759000-9975a000 rw-p 00022000 08:07 5105664    /usr/lib/libqjson.so.0.7.1
99760000-9976d000 r--p 00000000 08:07 7131070    /usr/share/locale/en_GB/LC_MESSAGES/kipiplugin_metadataedit.mo
9976d000-9977f000 r-xp 00000000 08:07 5954217    /usr/lib/libexslt.so.0.8.15
9977f000-99780000 r--p 00011000 08:07 5954217    /usr/lib/libexslt.so.0.8.15
99780000-99781000 rw-p 00012000 08:07 5954217    /usr/lib/libexslt.so.0.8.15
99781000-9979b000 r-xp 00000000 08:07 7130080    /usr/lib/kde4/kipiplugin_sendimages.so
9979b000-9979c000 ---p 0001a000 08:07 7130080    /usr/lib/kde4/kipiplugin_sendimages.so
9979c000-9979d000 r--p 0001a000 08:07 7130080    /usr/lib/kde4/kipiplugin_sendimages.so
9979d000-9979e000 rw-p 0001b000 08:07 7130080    /usr/lib/kde4/kipiplugin_sendimages.so
9979e000-997aa000 r-xp 00000000 08:07 6151860    /usr/lib/libavahi-common.so.3.5.3
997aa000-997ab000 r--p 0000b000 08:07 6151860    /usr/lib/libavahi-common.so.3.5.3
997ab000-997ac000 rw-p 0000c000 08:07 6151860    /usr/lib/libavahi-common.so.3.5.3
997ac000-997bc000 r-xp 00000000 08:07 6151857    /usr/lib/libavahi-client.so.3.2.9
997bc000-997bd000 r--p 00010000 08:07 6151857    /usr/lib/libavahi-client.so.3.2.9
997bd000-997be000 rw-p 00011000 08:07 6151857    /usr/lib/libavahi-client.so.3.2.9
997be000-997e0000 r-xp 00000000 08:07 6411515    /usr/lib/libsane.so.1.0.22
997e0000-997e1000 r--p 00021000 08:07 6411515    /usr/lib/libsane.so.1.0.22
997e1000-997e2000 rw-p 00022000 08:07 6411515    /usr/lib/libsane.so.1.0.22
997e2000-997e4000 rw-p 00000000 00:00 0
997e4000-99822000 r-xp 00000000 08:07 5429032    /usr/lib/libksane.so.0.2.0
99822000-99824000 r--p 0003d000 08:07 5429032    /usr/lib/libksane.so.0.2.0
99824000-99825000 rw-p 0003f000 08:07 5429032    /usr/lib/libksane.so.0.2.0
99826000-99827000 r-xp 00000000 08:07 5429785    /usr/lib/libutempter.so.1.1.5
99827000-99828000 r--p 00000000 08:07 5429785    /usr/lib/libutempter.so.1.1.5
99828000-99829000 rw-p 00001000 08:07 5429785    /usr/lib/libutempter.so.1.1.5
99829000-99841000 r-xp 00000000 08:07 7130083    /usr/lib/kde4/kipiplugin_timeadjust.so
99841000-99842000 ---p 00018000 08:07 7130083    /usr/lib/kde4/kipiplugin_timeadjust.so
99842000-99843000 r--p 00018000 08:07 7130083    /usr/lib/kde4/kipiplugin_timeadjust.so
99843000-99844000 rw-p 00019000 08:07 7130083    /usr/lib/kde4/kipiplugin_timeadjust.so
99844000-99850000 r--p 00000000 08:07 7131056    /usr/share/locale/en_GB/LC_MESSAGES/kipiplugin_batchprocessimages.mo
99850000-99867000 r-xp 00000000 08:07 7130020    /usr/lib/kde4/kipiplugin_debianscreenshots.so
99867000-99868000 r--p 00017000 08:07 7130020    /usr/lib/kde4/kipiplugin_debianscreenshots.so
99868000-99869000 rw-p 00018000 08:07 7130020    /usr/lib/kde4/kipiplugin_debianscreenshots.so
99869000-99892000 r-xp 00000000 08:07 7130059    /usr/lib/kde4/kipiplugin_flashexport.so
99892000-99893000 ---p 00029000 08:07 7130059    /usr/lib/kde4/kipiplugin_flashexport.so
99893000-99894000 r--p 00029000 08:07 7130059    /usr/lib/kde4/kipiplugin_flashexport.so
99894000-99895000 rw-p 0002a000 08:07 7130059    /usr/lib/kde4/kipiplugin_flashexport.so
99895000-9999b000 r-xp 00000000 08:07 6246732    /usr/lib/qca2/libqca.so.2.0.3
9999b000-9999f000 r--p 00105000 08:07 6246732    /usr/lib/qca2/libqca.so.2.0.3
9999f000-999a1000 rw-p 00109000 08:07 6246732    /usr/lib/qca2/libqca.so.2.0.3
999a1000-999c0000 r-xp 00000000 08:07 7130081    /usr/lib/kde4/kipiplugin_shwup.so
999c0000-999c1000 r--p 0001f000 08:07 7130081    /usr/lib/kde4/kipiplugin_shwup.so
999c1000-999c2000 rw-p 00020000 08:07 7130081    /usr/lib/kde4/kipiplugin_shwup.so
999c2000-999ec000 r-xp 00000000 08:07 7130082    /usr/lib/kde4/kipiplugin_smug.so
999ec000-999ed000 r--p 00029000 08:07 7130082    /usr/lib/kde4/kipiplugin_smug.so
999ed000-999ee000 rw-p 0002a000 08:07 7130082    /usr/lib/kde4/kipiplugin_smug.so
999ee000-99a04000 r-xp 00000000 08:07 5756151    /usr/lib/libicalss.so.0.48.0
99a04000-99a05000 r--p 00015000 08:07 5756151    /usr/lib/libicalss.so.0.48.0
99a05000-99a06000 rw-p 00016000 08:07 5756151    /usr/lib/libicalss.so.0.48.0
99a06000-99a08000 rw-p 00000000 00:00 0
99a08000-99a5c000 r-xp 00000000 08:07 5756146    /usr/lib/libical.so.0.48.0
99a5c000-99a64000 r--p 00054000 08:07 5756146    /usr/lib/libical.so.0.48.0
99a64000-99a65000 rw-p 0005c000 08:07 5756146    /usr/lib/libical.so.0.48.0
99a65000-99a66000 rw-p 00000000 00:00 0
99a66000-99b27000 r-xp 00000000 08:07 5077709    /usr/lib/libkcalcore.so.4.8.0
99b27000-99b28000 ---p 000c1000 08:07 5077709    /usr/lib/libkcalcore.so.4.8.0
99b28000-99b2a000 r--p 000c1000 08:07 5077709    /usr/lib/libkcalcore.so.4.8.0
99b2a000-99b2c000 rw-p 000c3000 08:07 5077709    /usr/lib/libkcalcore.so.4.8.0
99b2e000-99b33000 r-xp 00000000 08:07 7491525    /lib/libnss_dns-2.13.so
99b33000-99b34000 r--p 00004000 08:07 7491525    /lib/libnss_dns-2.13.so
99b34000-99b35000 rw-p 00005000 08:07 7491525    /lib/libnss_dns-2.13.so
99b35000-99b4e000 r-xp 00000000 08:07 7130069    /usr/lib/kde4/kipiplugin_jpeglossless.so
99b4e000-99b4f000 r--p 00018000 08:07 7130069    /usr/lib/kde4/kipiplugin_jpeglossless.so
99b4f000-99b50000 rw-p 00019000 08:07 7130069    /usr/lib/kde4/kipiplugin_jpeglossless.so
99b50000-99b6e000 r-xp 00000000 08:07 7130076    /usr/lib/kde4/kipiplugin_piwigoexport.so
99b6e000-99b6f000 r--p 0001d000 08:07 7130076    /usr/lib/kde4/kipiplugin_piwigoexport.so
99b6f000-99b70000 rw-p 0001e000 08:07 7130076    /usr/lib/kde4/kipiplugin_piwigoexport.so
99b70000-99ba7000 r-xp 00000000 08:07 7130063    /usr/lib/kde4/kipiplugin_flickrexport.so
99ba7000-99ba8000 r--p 00037000 08:07 7130063    /usr/lib/kde4/kipiplugin_flickrexport.so
99ba8000-99ba9000 rw-p 00038000 08:07 7130063    /usr/lib/kde4/kipiplugin_flickrexport.so
99ba9000-99be5000 r-xp 00000000 08:07 7130077    /usr/lib/kde4/kipiplugin_printimages.so
99be5000-99be6000 ---p 0003c000 08:07 7130077    /usr/lib/kde4/kipiplugin_printimages.so
99be6000-99be7000 r--p 0003c000 08:07 7130077    /usr/lib/kde4/kipiplugin_printimages.so
99be7000-99be8000 rw-p 0003d000 08:07 7130077    /usr/lib/kde4/kipiplugin_printimages.so
99be8000-99c34000 r-xp 00000000 08:07 7130017    /usr/lib/kde4/kipiplugin_advancedslideshow.so
99c34000-99c35000 ---p 0004c000 08:07 7130017    /usr/lib/kde4/kipiplugin_advancedslideshow.so
99c35000-99c37000 r--p 0004c000 08:07 7130017    /usr/lib/kde4/kipiplugin_advancedslideshow.so
99c37000-99c38000 rw-p 0004e000 08:07 7130017    /usr/lib/kde4/kipiplugin_advancedslideshow.so
99c38000-9a018000 r-xp 00000000 08:07 5005383    /usr/lib/qt4/libQtXmlPatterns.so.4.8.0
9a018000-9a038000 r--p 003df000 08:07 5005383    /usr/lib/qt4/libQtXmlPatterns.so.4.8.0Alarm clock
robin@robin2 ~ $
The day before yesterday it was running perfectly.
SLK x86 Fully updated running kernel 3.2.0
Self-righteousness is a loud din raised to drown
the voice of guilt within us - Eric Hoffer
dunsurfin
Postby maulbongo » Sun Mar 11, 2012 16:49
For me the same here.
Have you done a bug report yet?
greetings
maulbongo
maulbongo
Postby dunsurfin » Sun Mar 11, 2012 17:15
Reported as bug 3126
dunsurfin
Postby cl00t » Sun Mar 11, 2012 19:04
You beat me to it, sorry, I have been out all day & didn't get a chance this AM. Thanks for filing a report.
cl00t
Postby totedati » Sun Mar 11, 2012 22:05
i can confirm, same problem even worse because in my case digicam do not manage to finish image database rebuild
and second try ... instant crash ...
deleted digicam old settings and old image database ... third try ... hmmm ... i can use digicam! ... but not for much time, first try to open an image and digicam crash ... so i can navigate, i can preview images but when try to open any image digicam crash ...
last try, instant crash ...
my sabayon is up to date, upgraded today, i use stable sabayon repository not limbo or weekly test
because i have an entropy with debug option enabled will upload my crash logs to Bug 3126 – Digikam crashes after qt updates bug report
linux is free, the expertise to harness it is not!
you don't make so much money selling open source software!
You make MORE money USING it, just like google!
linux registered user #352479
totedati
Postby misty3 » Tue Mar 13, 2012 4:16
Same here on laptop as well as my desktop machine. Digikam crashed and then was unable to be reopened. I only use it for resizing images for emailing. Noticed Gwenview has same facility, so no problem and seems simpler to use..
misty3
misty3
Postby dunsurfin » Tue Mar 13, 2012 18:06
Seems to be OK here with KDE 4.8.1
dunsurfin
Postby cl00t » Tue Mar 13, 2012 20:49
dunsurfin wrote:Seems to be OK here with KDE 4.8.1
Thanks, that's good to know, I'll wait for the updated kde to filter through to entropy.
cl00t
