Problem, missing apps [Solved]
Postby Predatux » Fri Mar 09, 2012 12:10
Hello, I'm using Sabayon KDE and I have a problem with missing applications.
It happens especially with games. I have installed 0AD, mupen64plus, etc.. When looking at Kupfer, K menu, konsole, etc, the programs are not available.
In the package manager are installed. I tried to remove and install again, but no way.
I have all updates installed system.
Can anyone help me?
Predatux
Re: Problem, missing apps
Postby Jomiel » Fri Mar 09, 2012 15:30
Hi Predatux and welcome to Sabayon-Forum,
did you allready added yourself to the games group? It tells you to do so in the terminal after installing the games. Just run the following code as root:
# gpasswd -a yourusername games
cheers
Jomiel
Jomiel
Postby tomtom+ » Fri Mar 09, 2012 16:05
i have the same problem. try the "search"-bar in the kickoff-menu, then the games will appear. now you can copy them to "favorites" or desktop. its only a work-around, any real solution would be nice. the "games" group is already added.
tom
tomtom+
Postby Predatux » Sat Mar 10, 2012 11:48
Hi again.
User added.
mupen64plus
bash: mupen64plus: no se encontró la orden
$ 0ad
bash: 0ad: no se encontró la orden
nexuiz
bash: nexuiz: no se encontró la orden
doom3 works
All games installed... alien-arena too
Need help ;)
Predatux
Postby Fitzcarraldo » Sat Mar 10, 2012 18:04
If you installed them and the installation ran to completion then they will be on your machine. It is possible that the binaries are not in your $PATH. See e.g. Unable to start installed games [Solved]. You can use various commands to find them, for example:
$ whereis pacmanarena
pacmanarena: /usr/games/bin/pacmanarena
and, if /usr/games/bin/ is not in your $PATH then you would need to enter the command using Alt-F2 or in a Konsole/Terminal window (or configure the menu GUI to use the command):
$ whereis alien
alien:
$ whereis alien-arena
alien-arena:
$ whereis alienarena
alienarena: /usr/games/bin/alienarena
$ /usr/games/bin/alienarena
Another useful tool for finding files quickly is the locate command. You need to install the mlocate package and then populate its index file first:
$ su
Password:
# equo install mlocate
# updatedb
# exit
$ locate pacmanarena
From the output you'll be able to see in the list where the likely binary or launch script is located.
Postby Predatux » Sun Mar 11, 2012 15:46
Thanks a lot... solved.
whereis alinearena
Executing in konsole /usr/games/bin/alienarena for example, the game run. Now i can find it with kupfer or terminal.
Regards
Predatux
Re: Problem, missing apps [Solved]
Postby phd7 » Thu May 10, 2012 22:40
BUMP on this (supertuxkart)...
I have added my username to gamers
The only way I can open this is with Krusader in root mode and going into /usr/games/bin
I would like to have it in the kickoff menu
I tried to create a shortcut in the menu but it wont open. I assume this is because /usr/games is owned by root.
Also recursively chown-ed /usr/games to my username but still no good
Even moved the executable to /usr/bin.. still no good
has anyone found a way to add this (or others like it) to kick-off?
Cant open via terminal either
Terminal result:
Irrlicht Engine version 1.7.2
Linux 3.2.0-sabayon #1 SMP Sat Feb 11 08:52:29 UTC 2012 x86_64
[FileManager] Data files will be fetched from: '/usr/share/games/supertuxkart/'
[IrrDriver] Creating NULL device
No protocol specified
[IrrDriver] Trying OpenGL rendering.
[IrrDriver] Tring to create device with 32 bits
[IrrDriver Temp Logger] Level 2: Error: Need running XServer to start Irrlicht Engine.
[IrrDriver Temp Logger] Level 2: Could not open display: :0
phd7
Postby Fitzcarraldo » Fri May 11, 2012 9:55
phd7 wrote:I have added my username to gamers
The group is not "gamers", it's "games":
fitzcarraldo@meshedgedx ~ $ groups
disk lp wheel floppy uucp cron audio cdrom dialout video games cdrw usb users kismet clamav haldaemon plugdev scanner pulse-access pulse-rt pulse kvm crontab vboxusers polkituser
Postby phd7 » Sat May 12, 2012 19:01
Sorry,typo on my part above.
Anyway, it works now for some reason..after creating the menu item and giving it the path /usr/games/bin/supertuxkart
phd7
