From here:
https://packages.sabayon.org/quicksearc ... ca&x=0&y=0
it only exists for x86. From here:
http://developer.berlios.de/project/sho ... e_id=14167
it says that the actual x86 version is dated 2008 : 2.1.6 2008-02-10 00:00
and the very latest version would be the one at the top of the page:
2.0.10 2011-08-17 00:00
rubrica2-2.0.10.tar.bz2 708561 364 i386 Source .bz2
What do you think ? Would it be worth a try, or is there another address book in the repositories that would be light in depends while offering enough features ? The ideal for my needs would be easy import of cvs files or other export files currently performed by other addressbooks, and the possibility to add a way to classify addresses (groups, or such), and it would not need many depends (tried kaddressbook before, I don't want so many depends, and the gui is not even that intuitive).
Worth a try : I mean do you think it would it be worth requesting a package for it ?
Thanks,
Mélodie
