Firefox & Sulfur dont start
Postby Martyss » Sat Mar 03, 2012 21:57
I updated 4 months old fresh install Sabayon. Now i cant start Firefox a Sulfur.
Firefox:
XPCOMGlueLoad error for file /usr/lib64/firefox/libxpcom.so:
libEGL.so.1: cannot open shared object file: No such file or directory
Couldn't load XPCOM.
Sulfur:
  File "/usr/lib/entropy/sulfur/sulfur_client.py", line 18, in <module>
    import gtk
  File "/usr/lib64/python2.7/site-packages/gtk-2.0/gtk/__init__.py", line 40, in <module>
    from gtk import _gtk
ImportError: libEGL.so.1: cannot open shared object file: No such file or directory
Could sameone hepl me? Thanks of lot...
Martyss
Re: Firefox & Sulfur dont start
Postby micia » Sat Mar 03, 2012 22:21
Hi, which video card model and drivers are you using?
micia
Postby Martyss » Sat Mar 03, 2012 22:53
micia wrote:Hi, which video card model and drivers are you using?
Im using NTB HP 635 with processor AMD E-350, GK AMD Radeon HD 6310M, ati-drivers-12.1-r1.
Martyss
Postby micia » Sat Mar 03, 2012 22:57
Nice, then try running the following commands:
(as root)
eselect opengl set xorg-x11
eselect opengl set ati
to force the system to rebuild OpenGL implementation links, then try to start one of the application that previously failed.
micia
Postby sabayonino » Sun Mar 04, 2012 0:05
Firefox :
You could try to install nss package .
dev-libs/nss
