how to build with python 3 when 2 is the default one[Solved]
Postby msdobrescu » Mon Feb 13, 2012 6:07
I try to build dupeGuru (http://www.hardcoded.net/dupeguru/).
It seems to request python 3.
ImportError: No module named builtins/code]
I have python 2 and 3 installed, but 2 is the default one and I wouldn't make the 3 as default:
[code]python -V
Python 2.7.2
How could it be done?
Thank you.
msdobrescu
Re: how to build with python 3 when 2 is the default one
Postby sabayonino » Mon Feb 13, 2012 12:41
Hi
You can install python3 from entropy and switch it using eselect python command
build your package and then remember to switch to python2.7 becaus most applications are not supported from python3
check available python list
# eeselect python list
Set python profile
# eselect python set X
where "X" is the index of python showed
Example :
# eselect python list
Available Python interpreters:
  [1]   python2.7 *
  [2]   python3.2
To switch from 2.7 to 3.2 type :
@ eselect python set 2
Postby msdobrescu » Mon Feb 13, 2012 18:06
Thank you,
Now, I have the following error:
!!! Error: Cannot remove symlinks
exiting
msdobrescu
Postby sabayonino » Mon Feb 13, 2012 20:10
msdobrescu wrote:Thank you,
exiting
run the command as Root !
Postby msdobrescu » Mon Feb 13, 2012 21:48
Thank you, it worked!
msdobrescu
