Error running TED
Error running TED
Postby chasha420 » Tue Feb 07, 2012 19:27
Hi, I was wondering if TED (Torrent Episode Downloader) was available in Portage? I haven't seen TED in entropy but TED is basically a java based application that can be downloaded & run from the main site: http://www.ted.nu/download.php
After I download it manually from the site & try to run it this is the error I get:
$ java -jar ted.jar        [1:23:12]
Exception in thread "main" java.lang.UnsatisfiedLinkError: no tray in java.library.path
   at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1738)
   at java.lang.Runtime.loadLibrary0(Runtime.java:823)
   at java.lang.System.loadLibrary(System.java:1028)
   at org.jdesktop.jdic.tray.internal.impl.GnomeSystemTrayService.<clinit>(Unknown Source)
   at org.jdesktop.jdic.tray.internal.impl.ServiceManagerStub.getService(Unknown Source)
   at org.jdesktop.jdic.tray.internal.ServiceManager.getService(Unknown Source)
   at org.jdesktop.jdic.tray.SystemTray.<clinit>(Unknown Source)
   at ted.TedTrayIcon.<init>(TedTrayIcon.java:28)
   at ted.TedMainDialog.initGUI(TedMainDialog.java:309)
   at ted.TedMainDialog.<init>(TedMainDialog.java:125)
   at ted.TedMain.main(TedMain.java:50)
Btw, it used to work perfectly fine on Ubuntu & that's a long time back. Let me know if anything can be done to fix this.
Thanks :mrgreen:
chasha420
