Sabayon 5.4 and kernel source/header.
Postby francescodl » Sat Dec 24, 2011 10:07
I installed few days ago Sabayon 5.4 (don't ask me why i installed that old version :-) ), but i cannot find nowhere the kernel source/headers (kernel installed is 2.6.35-sabayon). I need it. Where i can fount it? Or, what real kernel version is it?
Thanks.
francescodl
Re: Sabayon 5.4 and kernel source/header.
Postby maulbongo » Sat Dec 24, 2011 14:24
Hi francescodl,
The oldest sources is sabayon-sources-2.6.36-r1, so you should do a kernel switch to this version and then you have it.
But I don't get it, why you use this old Version.
greetings
maulbongo
maulbongo
Postby francescodl » Tue Dec 27, 2011 15:51
I tryed to install a new kernel using Sulfur. I got always the same message about missing dependencies (package masked or package not found): >=gnome-base/gnome-settings-daemon-3.1.4[colord(+)]. My Gnome version is 2.30.X.
Is there somewhere an old ebuild for that kernel source (2.6.35-sabayon) or a place where to download the source by myself?
francescodl
Postby Draft » Thu Dec 29, 2011 19:07
Hello francescodl,
You should always choose the newest version if you install a Linux system.
Anyway i think this is the link to the source of the 2.6.36 kernel :
http://distfiles.sabayon.org/sys-kernel ... -3.tar.bz2
Draft
