I recently can't connect to MSN from the Kopete client. When I try to connect it says "Connecting.." and that's it. Anyone here knows where the problem is? I found this can happen because of MS messing up something and this may also be related to a "libmsn" library.
It is installed on my system:
- Code: Select all
emerge --search libmsn
Searching...
[ Results for search key : libmsn ]
[ Applications found : 1 ]
* net-libs/libmsn
Latest version available: 4.2
Latest version installed: 4.1
Size of files: 309 kB
Homepage: http://sourceforge.net/projects/libmsn/
Description: Library for connecting to Microsoft's MSN Messenger service.
License: GPL-2
Can I ask for some help?
I installed Pidgin and it connects. I checked the MSN server and changed it in Kopete to the same as in Pidgin:
gateway.messenger.hotmail.com
but still cannot connect via Kopete.
