Crontab : Permission denied [Solved]
Postby nobicycle » Thu Nov 24, 2011 18:03
User added to cron group:
sudo gpasswd -a `whoami` cron
Adding user adrfhi to group cron
ERROR
crontab -l
cannot chdir(/var/spool/cron), bailing out.
/var/spool/cron: Permission denied
This is a recent Sabayon 7 install.
uname -a
Linux sabayon 3.1.0-sabayon #1 SMP Sat Nov 12 08:03:21 UTC 2011 x86_64 AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ AuthenticAMD GNU/Linux
Thanks for any suggestions
nobicycle
Re: Crontab : Permission denied
Postby svantoviit » Thu Nov 24, 2011 18:45
less /etc/group | grep cron
cron:x:16:cron
crontab:x:1008:
Try to add your user to crontab group.
Or edit crontab as root.
svantoviit
Postby sabayonino » Thu Nov 24, 2011 18:46
nobicycle wrote:User added to cron group:
ERROR
crontab -l
uname -a
When adding your user (or other) to the cron group, make sure that the user log out and back in for the group change to take effect.then you can edit your crontab
$ crontab -e
Re: Crontab : Permission denied (SOLVED)
Postby nobicycle » Mon Nov 28, 2011 18:17
Thanks. That worked
nobicycle
