VLC cannot play any file.No suitable decoder module [Solved]
Postby Richlion » Sun Nov 20, 2011 12:11
after last nights updates VLC cannot play any .wmv file - no codecs found. Can this be somehow fixed?
Mp4 files cannot be played:
No suitable decoder module:
VLC does not support the audio or video format "mp4v". Unfortunately there is no way for you to fix this.
Opening .wmv files:
VLC does not support the audio or video format "WMA2". Unfortunately there is no way for you to fix this.
VLC does not support the audio or video format "WMV3". Unfortunately there is no way for you to fix this.
Regards,
Richard
Richlion
Re: [Solved]VLC cannot play any file.No suitable decoder mod
Postby Richlion » Sun Nov 20, 2011 19:27
Seems that updates have arrived and fixed the problem.
Richlion
Postby cnotis » Mon Nov 21, 2011 0:11
I have the same problem with vlc. The version of the VLC is 1.1.12 on Sabayon 7.
Any help???
cnotis
Postby operative.terminus » Mon Nov 21, 2011 5:21
Same problem here. Since the update, VLC doesn't support most of the formats it did just a few days ago. I can get a few videos in my collection to play, but just a few. My AVIs, MKVs, and FLVs won't play at all. More than half of my WMVs play, though. This is not the VLC I know and love. I logged in on Windows and VLC plays all of them perfectly.
Hope this is fixed soon...
operative.terminus
Re: VLC cannot play any file.No suitable decoder module [Sol
Postby operative.terminus » Tue Nov 22, 2011 3:13
Updates have come, and VLC is now working again on my PC :D
Thanks!
operative.terminus
Postby aquarius » Mon Dec 05, 2011 13:41
The problem is back with the yesterdays update.
Trying to play .wmv file, got just audio and no video. The error message is:
VLC does not support the audio or video format "MSS2". Unfortunately there is no way for you to fix this.
Gnome2 is dead! Long live... E17!
System76 Gazelle Professional:
Intel Core i7-2670QM
Nvidia GeForce GTX 560M
16GB DDR3 SDRAM
750GB HDD + 120GB SSD
15.6" Full HD LED-Backlit Matte Display
powered by Sabayon amd64 E17
aquarius
Postby svantoviit » Tue Dec 06, 2011 9:22
@aquarius: using 64 bit? 64-bit versions of Linux multimedia players cannot play .wmv files that use the MSS2 codec
In Fitzcarraldo's blog you can read how to play such files with wine:
How to play MSS2 codec (Windows Media Video 9 Screen) .wmv files in 64-bit Linux
svantoviit
Postby aquarius » Tue Dec 06, 2011 9:46
@svantoviit
Thanks! That explains everything :)
16GB DDR3 SDRAM
aquarius
