desmume 0.9.7
desmume 0.9.7
Postby nestea2004 » Thu Nov 10, 2011 3:22
EDIT: Fleshing out my problem more..
Pre-requisites
The Linux version of desmume comes in source code form only, and if your distribution does not package it or is packaging an old version you will have to compile the sources yourself. In order to compile desmume from a source tarball you'll need at least these packages:
gcc make libglib2 libgtk2 libglade gettext libsdl zlib intltool agg libasound
I have every single package except for libglib2, now as I can't find a way to get libglib2 on Sabayon was hoping someone could help.
EQUO has DesMuMe-0.9.5, but it doesn't play the games I wan't to play, 9.7 does so I am having to compile like you would regularly.
Any ideas on where I can get libglib2 or a working pre-done for sabayon version of 0.9.7 ?
here is there website that i was using to do this: http://wiki.desmume.org/index.php?title ... _compilers
nestea2004
Re: desmume 0.9.7
Postby throdon » Thu Nov 10, 2011 3:55
If you are compiling this are you using portage or entrophy as your package manager?
If you are using portage gentoo after a quick search ahas it in either portage or an overlay.
Troll hunter with an overzealous nature
throdon
Re: desmume 0.9.7
Postby sabayonino » Thu Nov 10, 2011 12:51
Hi
more overlays has desmume
http://gpo.zugaina.org/games-emulation/desmume
please see Sabayon Wiki "Overlays & layman" section
bye :wink:
