K3B SL7-can't rip any DVD-"Execution transcode failed"
Postby Richlion » Sat Oct 29, 2011 18:50
I just installed Sabayon 7 amd64-bit
Linux 3.0.0-sabayon #1 SMP Wed Aug 31 05:36:15 UTC 2011 x86_64 Pentium(R) Dual-Core CPU T4200 @ 2.00GHz GenuineIntel GNU/Linux
with KDE 4.7.2 and ran all the upgrades.
VLC by default cannot open DVD's because it points to /dev/dvd, which I had to change to /dev/sr0.
The same goes with dvd-rip.
K3B, when trying to rip it says "Execution transcode failed" during second phase. I didn't check if I can make a DVD backup.
Maybe this debug from K3b can show some light, this is a dump from the second pass from a DVD i have already ripped with a previous SL6 version:
Devices
TSSTcorp CDDVDW TS-L633A AC00 (/dev/sr0, CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD-R DL, DVD+R, DVD+RW, DVD+R DL) [DVD-ROM, DVD-R Sequential, DVD-R Dual Layer Sequential, DVD-R Dual Layer Jump, DVD-RAM, DVD-RW Restricted Overwrite, DVD-RW Sequential, DVD+RW, DVD+R, DVD+R Dual Layer, CD-ROM, CD-R, CD-RW] [SAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, Restricted Overwrite, Layer Jump] [%7]
System
K3b Version: 2.0.2
KDE Version: 4.7.2 (4.7.2)
QT Version:  4.7.4
Kernel:      3.0.0-sabayon
Used versions
transcode: 1.1.5
transcode
transcode v1.1.5 (C) 2001-2003 Thomas Oestreich, 2003-2009 Transcode Team
libdvdread: Using libdvdcss version 1.2.10 for DVD access
=== last message repeated 2 times. ===
[dvd_reader.c] DVD title 3/15: 5 chapter(s), 1 angle(s), title set 2
[dvd_reader.c] title playback time: 00:52:05.12  3126 sec
[transcode] V: auto-probing     | /dev/sr0 (OK)
[transcode] V: import format    | MPEG 2 program stream in DVD PAL (module=dvd)
[transcode] A: auto-probing     | /dev/sr0 (OK)
[transcode] A: import format    | AC3 in DVD PAL (module=dvd)
[transcode] V: AV demux/sync    | (1) sync AV at initial MPEG sequence
[transcode] V: import frame     | 720x576  1.25:1  encoded @ 4:3
[transcode] V: clip frame (<-)  | 720x576
[transcode] V: zoom             | 768x576  1.33:1 (Lanczos3)
[transcode] V: bits/pixel       | 0.109 (low)
[transcode] V: decoding fps,frc | 25.000,3
[transcode] V: multi-pass       | (mode=1) writing data (pass 1) to /tmp/kde-rysiek/k3b_0.log
[transcode] V: video format     | YUV420 (4:2:0) aka I420
[transcode] A: import format    | 0x2000  AC3          [48000,16,2]
[transcode] A: export           | disabled
[transcode] V: encoding fps,frc | 25.000,3
[transcode] A: language         | en
[transcode] A: bytes per frame  | 7680 (7680.000000)
[transcode] A: adjustment       | 0@1000
[transcode] V: IA32/AMD64 accel | sse3 sse2 sse mmx cmove asm
[transcode] V: video buffer     | 10 @ 768x576 [0x2]
[transcode] A: audio buffer     | 10 @ 48000x2x16
[import_dvd.so] v0.4.1 (2007-07-15) (video) DVD | (audio) MPEG/AC3/PCM
[export_null.so] v0.1.2 (2001-08-17) (video) null | (audio) null
[export_ffmpeg.so] v0.3.18 (2008-11-29) (video) Lavc52.122.0 | (audio) MPEG/AC3/PCM
[import_dvd.so] tccat -T 3,-1,1 -i "/dev/sr0" -t dvd -d 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 0 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0
[import_dvd.so] tccat -T 3,-1,1 -i "/dev/sr0" -t dvd -d 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p
[import_dvd.so] delaying DVD access by 3 seconds
[import_dvd.so] waiting...
No accelerated IMDCT transform found
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a _long_ time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x00000135
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00000208
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x000002b7
libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x00002747
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x00009dde
libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x003c772e
libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x003c77dd
libdvdread: Get key for /VIDEO_TS/VTS_04_0.VOB at 0x003cada0
libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x003cae53
libdvdread: Found 4 VTS's
[export_ffmpeg.so] Using FFMPEG codec 'mpeg4' (FourCC 'DIVX', MPEG4 compliant video).
[export_ffmpeg.so] No profile selected
[export_ffmpeg.so] Error opening configuration file ./ffmpeg.cfg: No such file or directory
[export_ffmpeg.so] Starting 1 thread(s)
[export_ffmpeg.so] Set display aspect ratio to input
[mpeg4 @ 0x69e770] removing common factors from framerate
[decode_mpeg2.c] libmpeg2 acceleration: mmxext
encoding=1 frame=520 first=0 last=-1 fps=85.253 done=-1.000000 timestamp=20.800 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=1040 first=0 last=-1 fps=83.774 done=-1.000000 timestamp=41.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1560 first=0 last=-1 fps=83.035 done=-1.000000 timestamp=62.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2080 first=0 last=-1 fps=81.882 done=-1.000000 timestamp=83.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2600 first=0 last=-1 fps=81.378 done=-1.000000 timestamp=104.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3120 first=0 last=-1 fps=80.787 done=-1.000000 timestamp=124.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3640 first=0 last=-1 fps=80.479 done=-1.000000 timestamp=145.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4160 first=0 last=-1 fps=80.134 done=-1.000000 timestamp=166.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4680 first=0 last=-1 fps=79.997 done=-1.000000 timestamp=187.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5200 first=0 last=-1 fps=79.976 done=-1.000000 timestamp=208.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5720 first=0 last=-1 fps=79.898 done=-1.000000 timestamp=228.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6240 first=0 last=-1 fps=79.849 done=-1.000000 timestamp=249.600 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=6760 first=0 last=-1 fps=79.795 done=-1.000000 timestamp=270.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7280 first=0 last=-1 fps=79.647 done=-1.000000 timestamp=291.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7800 first=0 last=-1 fps=79.598 done=-1.000000 timestamp=312.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8320 first=0 last=-1 fps=79.650 done=-1.000000 timestamp=332.800 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=8840 first=0 last=-1 fps=79.591 done=-1.000000 timestamp=353.600 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=9360 first=0 last=-1 fps=79.599 done=-1.000000 timestamp=374.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9880 first=0 last=-1 fps=79.579 done=-1.000000 timestamp=395.200 timeleft=-1 decodebuf=1 filterbuf=4 encodebuf=15
encoding=1 frame=10400 first=0 last=-1 fps=79.515 done=-1.000000 timestamp=416.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10920 first=0 last=-1 fps=79.476 done=-1.000000 timestamp=436.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11440 first=0 last=-1 fps=79.451 done=-1.000000 timestamp=457.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11960 first=0 last=-1 fps=79.367 done=-1.000000 timestamp=478.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12480 first=0 last=-1 fps=79.257 done=-1.000000 timestamp=499.200 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=13000 first=0 last=-1 fps=79.191 done=-1.000000 timestamp=520.000 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=13520 first=0 last=-1 fps=79.193 done=-1.000000 timestamp=540.800 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=14040 first=0 last=-1 fps=79.212 done=-1.000000 timestamp=561.600 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=14560 first=0 last=-1 fps=79.203 done=-1.000000 timestamp=582.400 timeleft=-1 decodebuf=0 filterbuf=4 encodebuf=16
encoding=1 frame=15080 first=0 last=-1 fps=79.191 done=-1.000000 timestamp=603.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=15600 first=0 last=-1 fps=79.133 done=-1.000000 timestamp=624.000 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=16120 first=0 last=-1 fps=79.107 done=-1.000000 timestamp=644.800 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=16640 first=0 last=-1 fps=79.073 done=-1.000000 timestamp=665.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17160 first=0 last=-1 fps=78.970 done=-1.000000 timestamp=686.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17680 first=0 last=-1 fps=78.953 done=-1.000000 timestamp=707.200 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=18200 first=0 last=-1 fps=78.884 done=-1.000000 timestamp=728.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=18720 first=0 last=-1 fps=78.835 done=-1.000000 timestamp=748.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=19240 first=0 last=-1 fps=78.774 done=-1.000000 timestamp=769.600 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=19760 first=0 last=-1 fps=78.793 done=-1.000000 timestamp=790.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=20280 first=0 last=-1 fps=78.792 done=-1.000000 timestamp=811.200 timeleft=-1 decodebuf=0 filterbuf=4 encodebuf=16
encoding=1 frame=20800 first=0 last=-1 fps=78.803 done=-1.000000 timestamp=832.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=21320 first=0 last=-1 fps=78.749 done=-1.000000 timestamp=852.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=21840 first=0 last=-1 fps=78.643 done=-1.000000 timestamp=873.600 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=22360 first=0 last=-1 fps=78.613 done=-1.000000 timestamp=894.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=22880 first=0 last=-1 fps=78.573 done=-1.000000 timestamp=915.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=23400 first=0 last=-1 fps=78.583 done=-1.000000 timestamp=936.000 timeleft=-1 decodebuf=0 filterbuf=3 encodebuf=17
encoding=1 frame=23920 first=0 last=-1 fps=78.576 done=-1.000000 timestamp=956.800 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=24440 first=0 last=-1 fps=78.589 done=-1.000000 timestamp=977.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=24960 first=0 last=-1 fps=78.587 done=-1.000000 timestamp=998.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=25480 first=0 last=-1 fps=78.559 done=-1.000000 timestamp=1019.200 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=26000 first=0 last=-1 fps=78.591 done=-1.000000 timestamp=1040.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=26520 first=0 last=-1 fps=78.599 done=-1.000000 timestamp=1060.800 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=27040 first=0 last=-1 fps=78.579 done=-1.000000 timestamp=1081.600 timeleft=-1 decodebuf=0 filterbuf=1 encodebuf=19
encoding=1 frame=27560 first=0 last=-1 fps=78.595 done=-1.000000 timestamp=1102.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=28080 first=0 last=-1 fps=78.584 done=-1.000000 timestamp=1123.200 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=28600 first=0 last=-1 fps=78.581 done=-1.000000 timestamp=1144.000 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=29120 first=0 last=-1 fps=78.593 done=-1.000000 timestamp=1164.800 timeleft=-1 decodebuf=0 filterbuf=4 encodebuf=16
encoding=1 frame=29640 first=0 last=-1 fps=78.581 done=-1.000000 timestamp=1185.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=30160 first=0 last=-1 fps=78.570 done=-1.000000 timestamp=1206.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=30680 first=0 last=-1 fps=78.591 done=-1.000000 timestamp=1227.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=31200 first=0 last=-1 fps=78.551 done=-1.000000 timestamp=1248.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=31720 first=0 last=-1 fps=78.549 done=-1.000000 timestamp=1268.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=32240 first=0 last=-1 fps=78.534 done=-1.000000 timestamp=1289.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=32760 first=0 last=-1 fps=78.574 done=-1.000000 timestamp=1310.400 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=33280 first=0 last=-1 fps=78.588 done=-1.000000 timestamp=1331.200 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=33800 first=0 last=-1 fps=78.591 done=-1.000000 timestamp=1352.000 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=34320 first=0 last=-1 fps=78.621 done=-1.000000 timestamp=1372.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=34840 first=0 last=-1 fps=78.619 done=-1.000000 timestamp=1393.600 timeleft=-1 decodebuf=0 filterbuf=3 encodebuf=17
encoding=1 frame=35360 first=0 last=-1 fps=78.655 done=-1.000000 timestamp=1414.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=35880 first=0 last=-1 fps=78.682 done=-1.000000 timestamp=1435.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=36400 first=0 last=-1 fps=78.544 done=-1.000000 timestamp=1456.000 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=36920 first=0 last=-1 fps=78.527 done=-1.000000 timestamp=1476.800 timeleft=-1 decodebuf=1 filterbuf=2 encodebuf=17
encoding=1 frame=37440 first=0 last=-1 fps=77.159 done=-1.000000 timestamp=1497.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=37960 first=0 last=-1 fps=77.062 done=-1.000000 timestamp=1518.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=38480 first=0 last=-1 fps=76.637 done=-1.000000 timestamp=1539.200 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=39000 first=0 last=-1 fps=76.465 done=-1.000000 timestamp=1560.000 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=39520 first=0 last=-1 fps=76.415 done=-1.000000 timestamp=1580.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=40040 first=0 last=-1 fps=76.507 done=-1.000000 timestamp=1601.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=40560 first=0 last=-1 fps=76.576 done=-1.000000 timestamp=1622.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=41080 first=0 last=-1 fps=76.250 done=-1.000000 timestamp=1643.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=41600 first=0 last=-1 fps=76.306 done=-1.000000 timestamp=1664.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=42120 first=0 last=-1 fps=76.287 done=-1.000000 timestamp=1684.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=42640 first=0 last=-1 fps=76.341 done=-1.000000 timestamp=1705.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=43160 first=0 last=-1 fps=76.195 done=-1.000000 timestamp=1726.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=43680 first=0 last=-1 fps=76.116 done=-1.000000 timestamp=1747.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=44200 first=0 last=-1 fps=75.907 done=-1.000000 timestamp=1768.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=44720 first=0 last=-1 fps=75.894 done=-1.000000 timestamp=1788.800 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=45240 first=0 last=-1 fps=75.954 done=-1.000000 timestamp=1809.600 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=45760 first=0 last=-1 fps=75.965 done=-1.000000 timestamp=1830.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=46280 first=0 last=-1 fps=76.000 done=-1.000000 timestamp=1851.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=46800 first=0 last=-1 fps=75.936 done=-1.000000 timestamp=1872.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=47320 first=0 last=-1 fps=75.730 done=-1.000000 timestamp=1892.800 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=47840 first=0 last=-1 fps=75.643 done=-1.000000 timestamp=1913.600 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=48360 first=0 last=-1 fps=75.531 done=-1.000000 timestamp=1934.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=48880 first=0 last=-1 fps=74.994 done=-1.000000 timestamp=1955.200 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=49400 first=0 last=-1 fps=74.909 done=-1.000000 timestamp=1976.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=49920 first=0 last=-1 fps=74.741 done=-1.000000 timestamp=1996.800 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=50440 first=0 last=-1 fps=74.745 done=-1.000000 timestamp=2017.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=50960 first=0 last=-1 fps=74.766 done=-1.000000 timestamp=2038.400 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=51480 first=0 last=-1 fps=74.795 done=-1.000000 timestamp=2059.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=52000 first=0 last=-1 fps=74.878 done=-1.000000 timestamp=2080.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=52520 first=0 last=-1 fps=74.949 done=-1.000000 timestamp=2100.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=53040 first=0 last=-1 fps=75.017 done=-1.000000 timestamp=2121.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=53560 first=0 last=-1 fps=75.041 done=-1.000000 timestamp=2142.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=54080 first=0 last=-1 fps=75.035 done=-1.000000 timestamp=2163.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=54600 first=0 last=-1 fps=75.040 done=-1.000000 timestamp=2184.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=55120 first=0 last=-1 fps=75.040 done=-1.000000 timestamp=2204.800 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=55640 first=0 last=-1 fps=75.079 done=-1.000000 timestamp=2225.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=56160 first=0 last=-1 fps=75.086 done=-1.000000 timestamp=2246.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=56680 first=0 last=-1 fps=75.083 done=-1.000000 timestamp=2267.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=57200 first=0 last=-1 fps=75.036 done=-1.000000 timestamp=2288.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=57720 first=0 last=-1 fps=75.043 done=-1.000000 timestamp=2308.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=58240 first=0 last=-1 fps=75.108 done=-1.000000 timestamp=2329.600 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=58760 first=0 last=-1 fps=75.171 done=-1.000000 timestamp=2350.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=59280 first=0 last=-1 fps=75.214 done=-1.000000 timestamp=2371.200 timeleft=-1 decodebuf=0 filterbuf=2 encodebuf=18
encoding=1 frame=59800 first=0 last=-1 fps=75.277 done=-1.000000 timestamp=2392.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=60320 first=0 last=-1 fps=75.300 done=-1.000000 timestamp=2412.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=60840 first=0 last=-1 fps=75.343 done=-1.000000 timestamp=2433.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=61360 first=0 last=-1 fps=75.372 done=-1.000000 timestamp=2454.400 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=61880 first=0 last=-1 fps=75.410 done=-1.000000 timestamp=2475.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=62400 first=0 last=-1 fps=75.441 done=-1.000000 timestamp=2496.000 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=62920 first=0 last=-1 fps=75.481 done=-1.000000 timestamp=2516.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=63440 first=0 last=-1 fps=75.506 done=-1.000000 timestamp=2537.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=63960 first=0 last=-1 fps=75.538 done=-1.000000 timestamp=2558.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=64480 first=0 last=-1 fps=75.569 done=-1.000000 timestamp=2579.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=65000 first=0 last=-1 fps=75.595 done=-1.000000 timestamp=2600.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=65520 first=0 last=-1 fps=75.629 done=-1.000000 timestamp=2620.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=66040 first=0 last=-1 fps=75.669 done=-1.000000 timestamp=2641.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=66560 first=0 last=-1 fps=75.686 done=-1.000000 timestamp=2662.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=67080 first=0 last=-1 fps=75.733 done=-1.000000 timestamp=2683.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=67600 first=0 last=-1 fps=75.764 done=-1.000000 timestamp=2704.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=68120 first=0 last=-1 fps=75.794 done=-1.000000 timestamp=2724.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=68640 first=0 last=-1 fps=75.819 done=-1.000000 timestamp=2745.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=69160 first=0 last=-1 fps=75.850 done=-1.000000 timestamp=2766.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=69680 first=0 last=-1 fps=75.872 done=-1.000000 timestamp=2787.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=70200 first=0 last=-1 fps=75.788 done=-1.000000 timestamp=2808.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=70720 first=0 last=-1 fps=75.802 done=-1.000000 timestamp=2828.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=71240 first=0 last=-1 fps=75.856 done=-1.000000 timestamp=2849.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=71760 first=0 last=-1 fps=75.908 done=-1.000000 timestamp=2870.400 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=72280 first=0 last=-1 fps=75.950 done=-1.000000 timestamp=2891.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=72800 first=0 last=-1 fps=75.990 done=-1.000000 timestamp=2912.000 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=73320 first=0 last=-1 fps=76.032 done=-1.000000 timestamp=2932.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=73840 first=0 last=-1 fps=76.068 done=-1.000000 timestamp=2953.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=74360 first=0 last=-1 fps=76.090 done=-1.000000 timestamp=2974.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=74880 first=0 last=-1 fps=76.111 done=-1.000000 timestamp=2995.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=75400 first=0 last=-1 fps=76.144 done=-1.000000 timestamp=3016.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=75920 first=0 last=-1 fps=76.143 done=-1.000000 timestamp=3036.800 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=76440 first=0 last=-1 fps=76.169 done=-1.000000 timestamp=3057.600 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=76960 first=0 last=-1 fps=76.189 done=-1.000000 timestamp=3078.400 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=77480 first=0 last=-1 fps=76.213 done=-1.000000 timestamp=3099.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=78000 first=0 last=-1 fps=76.246 done=-1.000000 timestamp=3120.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
*** glibc detected *** /usr/bin/transcode: free(): invalid pointer: 0x00007feae848e14c ***
======= Backtrace: =========
/lib64/libc.so.6(+0x72fd6)[0x7feafadbdfd6]
/lib64/libc.so.6(cfree+0x6c)[0x7feafadc2e5c]
/usr/lib64/libavutil.so.50(av_freep+0xc)[0x7feae72c66ac]
/usr/lib64/libavutil.so.50(av_opt_free+0x3f)[0x7feae72c6c0f]
/usr/lib64/libavcodec.so.52(avcodec_close+0xdb)[0x7feae77b92ea]
/usr/lib64/transcode/export_ffmpeg.so(tc_export+0x41d)[0x7feae848a2bd]
/usr/bin/transcode(tcv_export+0x60)[0x415230]
/usr/bin/transcode(tc_encoder_stop+0x9b)[0x41656b]
/usr/bin/transcode(main+0x3eef)[0x40e36f]
/lib64/libc.so.6(__libc_start_main+0xfd)[0x7feafad69ebd]
/usr/bin/transcode[0x40a089]
======= Memory map: ========
00400000-00471000 r-xp 00000000 fb:00 395407                             /usr/bin/transcode
00670000-00671000 r--p 00070000 fb:00 395407                             /usr/bin/transcode
00671000-00675000 rw-p 00071000 fb:00 395407                             /usr/bin/transcode
00675000-00b1e000 rw-p 00000000 00:00 0                                  [heap]
7feadc000000-7feadc021000 rw-p 00000000 00:00 0
7feadc021000-7feae0000000 ---p 00000000 00:00 0
7feae14b8000-7feae14b9000 ---p 00000000 00:00 0
7feae14b9000-7feae1cb9000 rw-p 00000000 00:00 0
7feae1cb9000-7feae1cba000 ---p 00000000 00:00 0
7feae1cba000-7feae24ba000 rw-p 00000000 00:00 0
7feae24ba000-7feae24c6000 r-xp 00000000 fb:00 2097267                    /lib64/libnss_files-2.13.so
7feae24c6000-7feae26c5000 ---p 0000c000 fb:00 2097267                    /lib64/libnss_files-2.13.so
7feae26c5000-7feae26c6000 r--p 0000b000 fb:00 2097267                    /lib64/libnss_files-2.13.so
7feae26c6000-7feae26c7000 rw-p 0000c000 fb:00 2097267                    /lib64/libnss_files-2.13.so
7feae26c7000-7feae26d1000 r-xp 00000000 fb:00 2097271                    /lib64/libnss_nis-2.13.so
7feae26d1000-7feae28d1000 ---p 0000a000 fb:00 2097271                    /lib64/libnss_nis-2.13.so
7feae28d1000-7feae28d2000 r--p 0000a000 fb:00 2097271                    /lib64/libnss_nis-2.13.so
7feae28d2000-7feae28d3000 rw-p 0000b000 fb:00 2097271                    /lib64/libnss_nis-2.13.so
7feae28d3000-7feae28e8000 r-xp 00000000 fb:00 2097261                    /lib64/libnsl-2.13.so
7feae28e8000-7feae2ae7000 ---p 00015000 fb:00 2097261                    /lib64/libnsl-2.13.so
7feae2ae7000-7feae2ae8000 r--p 00014000 fb:00 2097261                    /lib64/libnsl-2.13.so
7feae2ae8000-7feae2ae9000 rw-p 00015000 fb:00 2097261                    /lib64/libnsl-2.13.so
7feae2ae9000-7feae2aeb000 rw-p 00000000 00:00 0
7feae2aeb000-7feae2af2000 r-xp 00000000 fb:00 2097263                    /lib64/libnss_compat-2.13.so
7feae2af2000-7feae2cf1000 ---p 00007000 fb:00 2097263                    /lib64/libnss_compat-2.13.so
7feae2cf1000-7feae2cf2000 r--p 00006000 fb:00 2097263                    /lib64/libnss_compat-2.13.so
7feae2cf2000-7feae2cf3000 rw-p 00007000 fb:00 2097263                    /lib64/libnss_compat-2.13.so
7feae2cf3000-7feae2cfa000 r-xp 00000000 fb:00 412705                     /usr/lib64/libdvdcss.so.2.1.0
7feae2cfa000-7feae2ef9000 ---p 00007000 fb:00 412705                     /usr/lib64/libdvdcss.so.2.1.0
7feae2ef9000-7feae2efa000 r--p 00006000 fb:00 412705                     /usr/lib64/libdvdcss.so.2.1.0
7feae2efa000-7feae2efb000 rw-p 00007000 fb:00 412705                     /usr/lib64/libdvdcss.so.2.1.0
7feae2efb000-7feae2efc000 ---p 00000000 00:00 0
7feae2efc000-7feae36fc000 rw-p 00000000 00:00 0
7feae36fc000-7feae36fd000 ---p 00000000 00:00 0
7feae36fd000-7feae3efd000 rw-p 00000000 00:00 0
7feae3efd000-7feae3efe000 ---p 00000000 00:00 0
7feae3efe000-7feae46fe000 rw-p 00000000 00:00 0
7feae46fe000-7feae4713000 r-xp 00000000 fb:00 2107420                    /lib64/libgcc_s.so.1
7feae4713000-7feae4912000 ---p 00015000 fb:00 2107420                    /lib64/libgcc_s.so.1
7feae4912000-7feae4913000 r--p 00014000 fb:00 2107420                    /lib64/libgcc_s.so.1
7feae4913000-7feae4914000 rw-p 00015000 fb:00 2107420                    /lib64/libgcc_s.so.1
7feae4914000-7feae4a00000 r-xp 00000000 fb:00 663222                     /usr/lib64/gcc/x86_64-pc-linux-gnu/4.5.2/libstdc++.so.6.0.14
7feae4a00000-7feae4bff000 ---p 000ec000 fb:00 663222                     /usr/lib64/gcc/x86_64-pc-linux-gnu/4.5.2/libstdc++.so.6.0.14
7feae4bff000-7feae4c07000 r--p 000eb000 fb:00 663222                     /usr/lib64/gcc/x86_64-pc-linux-gnu/4.5.2/libstdc++.so.6.0.14
7feae4c07000-7feae4c09000 rw-p 000f3000 fb:00 663222                     /usr/lib64/gcc/x86_64-pc-linux-gnu/4.5.2/libstdc++.so.6.0.14
7feae4c09000-7feae4c1e000 rw-p 00000000 00:00 0
7feae4c1e000-7feae4c24000 r-xp 00000000 fb:00 414176                     /usr/lib64/libogg.so.0.7.1
7feae4c24000-7feae4e23000 ---p 00006000 fb:00 414176                     /usr/lib64/libogg.so.0.7.1
7feae4e23000-7feae4e24000 r--p 00005000 fb:00 414176                     /usr/lib64/libogg.so.0.7.1
7feae4e24000-7feae4e25000 rw-p 00006000 fb:00 414176                     /usr/lib64/libogg.so.0.7.1
7feae4e25000-7feae4e35000 r-xp 00000000 fb:00 412819                     /usr/lib64/libfaac.so.0.0.0
7feae4e35000-7feae5034000 ---p 00010000 fb:00 412819                     /usr/lib64/libfaac.so.0.0.0
7feae5034000-7feae5035000 r--p 0000f000 fb:00 412819                     /usr/lib64/libfaac.so.0.0.0
7feae5035000-7feae5038000 rw-p 00010000 fb:00 412819                     /usr/lib64/libfaac.so.0.0.0
7feae5038000-7feae5043000 r-xp 00000000 fb:00 413113                     /usr/lib64/libgsm.so.1.0.12
7feae5043000-7feae5242000 ---p 0000b000 fb:00 413113                     /usr/lib64/libgsm.so.1.0.12
7feae5242000-7feae5243000 r--p 0000a000 fb:00 413113                     /usr/lib64/libgsm.so.1.0.12
7feae5243000-7feae5244000 rw-p 0000b000 fb:00 413113                     /usr/lib64/libgsm.so.1.0.12
7feae5244000-7feae5273000 r-xp 00000000 fb:00 414191                     /usr/lib64/libopencore-amrnb.so.0.0.2
7feae5273000-7feae5473000 ---p 0002f000 fb:00 414191                     /usr/lib64/libopencore-amrnb.so.0.0.2
7feae5473000-7feae5474000 r--p 0002f000 fb:00 414191                     /usr/lib64/libopencore-amrnb.so.0.0.2
7feae5474000-7feae5475000 rw-p 00030000 fb:00 414191                     /usr/lib64/libopencore-amrnb.so.0.0.2
7feae5475000-7feae548b000 r-xp 00000000 fb:00 414194                     /usr/lib64/libopencore-amrwb.so.0.0.2
7feae548b000-7feae568a000 ---p 00016000 fb:00 414194                     /usr/lib64/libopencore-amrwb.so.0.0.2
7feae568a000-7feae568b000 r--p 00015000 fb:00 414194                     /usr/lib64/libopencore-amrwb.so.0.0.2
7feae568b000-7feae568c000 rw-p 00016000 fb:00 414194                     /usr/lib64/libopencore-amrwb.so.0.0.2
7feae568c000-7feae56a1000 r-xp 00000000 fb:00 414618                     /usr/lib64/libspeex.so.1.5.0
7feae56a1000-7feae58a0000 ---p 00015000 fb:00 414618                     /usr/lib64/libspeex.so.1.5.0
7feae58a0000-7feae58a1000 r--p 00014000 fb:00 414618                     /usr/lib64/libspeex.so.1.5.0
7feae58a1000-7feae58a2000 rw-p 00015000 fb:00 414618                     /usr/lib64/libspeex.so.1.5.0
7feae58a2000-7feae58b1000 r-xp 00000000 fb:00 414713                     /usr/lib64/libtheoradec.so.1.1.4
7feae58b1000-7feae5ab0000 ---p 0000f000 fb:00 414713                     /usr/lib64/libtheoradec.so.1.1.4
7feae5ab0000-7feae5ab1000 r--p 0000e000 fb:00 414713                     /usr/lib64/libtheoradec.so.1.1.4
7feae5ab1000-7feae5ab2000 rw-p 0000f000 fb:00 414713                     /usr/lib64/libtheoradec.so.1.1.4
7feae5ab2000-7feae5ade000 r-xp 00000000 fb:00 414718                     /usr/lib64/libtheoraenc.so.1.1.2
7feae5ade000-7feae5cdd000 ---p 0002c000 fb:00 414718                     /usr/lib64/libtheoraenc.so.1.1.2
7feae5cdd000-7feae5cde000 r--p 0002b000 fb:00 414718                     /usr/lib64/libtheoraenc.so.1.1.2
7feae5cde000-7feae5cdf000 rw-p 0002c000 fb:00 414718                     /usr/lib64/libtheoraenc.so.1.1.2
7feae5cdf000-7feae5cfe000 r-xp 00000000 fb:00 414839                     /usr/lib64/libvo-aacenc.so.0.0.2
7feae5cfe000-7feae5efd000 ---p 0001f000 fb:00 414839                     /usr/lib64/libvo-aacenc.so.0.0.2
7feae5efd000-7feae5efe000 r--p 0001e000 fb:00 414839                     /usr/lib64/libvo-aacenc.so.0.0.2
7feae5efe000-7feae5eff000 rw-p 0001f000 fb:00 414839                     /usr/lib64/libvo-aacenc.so.0.0.2
7feae5eff000-7feae5f16000 r-xp 00000000 fb:00 414842                     /usr/lib64/libvo-amrwbenc.so.0.0.2
7feae5f16000-7feae6115000 ---p 00017000 fb:00 414842                     /usr/lib64/libvo-amrwbenc.so.0.0.2
7feae6115000-7feae6116000 r--p 00016000 fb:00 414842                     /usr/lib64/libvo-amrwbenc.so.0.0.2
7feae6116000-7feae611c000 rw-p 00017000 fb:00 414842                     /usr/lib64/libvo-amrwbenc.so.0.0.2
7feae611c000-7feae6147000 r-xp 00000000 fb:00 414846                     /usr/lib64/libvorbis.so.0.4.4
7feae6147000-7feae6347000 ---p 0002b000 fb:00 414846                     /usr/lib64/libvorbis.so.0.4.4
7feae6347000-7feae6348000 r--p 0002b000 fb:00 414846                     /usr/lib64/libvorbis.so.0.4.4
7feae6348000-7feae6349000 rw-p 0002c000 fb:00 414846                     /usr/lib64/libvorbis.so.0.4.4
7feae6349000-7feae65fc000 r-xp 00000000 fb:00 414850                     /usr/lib64/libvorbisenc.so.2.0.7
7feae65fc000-7feae67fb000 ---p 002b3000 fb:00 414850                     /usr/lib64/libvorbisenc.so.2.0.7
7feae67fb000-7feae6817000 r--p 002b2000 fb:00 414850                     /usr/lib64/libvorbisenc.so.2.0.7
7feae6817000-7feae6818000 rw-p 002ce000 fb:00 414850                     /usr/lib64/libvorbisenc.so.2.0.7
7feae6818000-7feae68a0000 r-xp 00000000 fb:00 414859                     /usr/lib64/libvpx.so.0.9.6
7feae68a0000-7feae6a9f000 ---p 00088000 fb:00 414859                     /usr/lib64/libvpx.so.0.9.6
7feae6a9f000-7feae6aa1000 r--p 00087000 fb:00 414859                     /usr/lib64/libvpx.so.0.9.6
7feae6aa1000-7feae6aa2000 rw-p 00089000 fb:00 414859                     /usr/lib64/libvpx.so.0.9.6
7feae6aa2000-7feae6aac000 rw-p 00000000 00:00 0
7feae6aac000-7feae6b50000 r-xp 00000000 fb:00 414911                     /usr/lib64/libx264.so.115
7feae6b50000-7feae6d50000 ---p 000a4000 fb:00 414911                     /usr/lib64/libx264.so.115
7feae6d50000-7feae6d52000 r--p 000a4000 fb:00 414911                     /usr/lib64/libx264.so.115
7feae6d52000-7feae6d53000 rw-p 000a6000 fb:00 414911                     /usr/lib64/libx264.so.115
7feae6d53000-7feae6d70000 rw-p 00000000 00:00 0
7feae6d70000-7feae6e16000 r-xp 00000000 fb:00 415033                     /usr/lib64/libxvidcore.so.4.3
7feae6e16000-7feae7016000 ---p 000a6000 fb:00 415033                     /usr/lib64/libxvidcore.so.4.3
7feae7016000-7feae7017000 r--p 000a6000 fb:00 415033                     /usr/lib64/libxvidcore.so.4.3
7feae7017000-7feae7021000 rw-p 000a7000 fb:00 415033                     /usr/lib64/libxvidcore.so.4.3
7feae7021000-7feae708b000 rw-p 00000000 00:00 0
7feae708b000-7feae709d000 r-xp 00000000 fb:00 414816                     /usr/lib64/libva.so.1.0.14
7feae709d000-7feae729d000 ---p 00012000 fb:00 414816                     /usr/lib64/libva.so.1.0.14
7feae729d000-7feae729e000 r--p 00012000 fb:00 414816                     /usr/lib64/libva.so.1.0.14
7feae729e000-7feae729f000 rw-p 00013000 fb:00 414816                     /usr/lib64/libva.so.1.0.14
7feae729f000-7feae72b8000 rw-p 00000000 00:00 0
7feae72b8000-7feae72d4000 r-xp 00000000 fb:00 412283                     /usr/lib64/libavutil.so.50.43.0
7feae72d4000-7feae74d3000 ---p 0001c000 fb:00 412283                     /usr/lib64/libavutil.so.50.43.0
7feae74d3000-7feae74d5000 r--p 0001b000 fb:00 412283                     /usr/lib64/libavutil.so.50.43.0
7feae74d5000-7feae74d6000 rw-p 0001d000 fb:00 412283                     /usr/lib64/libavutil.so.50.43.0
7feae74d6000-7feae74d9000 rw-p 00000000 00:00 0
7feae74d9000-7feae7521000 r-xp 00000000 fb:00 413964                     /usr/lib64/libmp3lame.so.0.0.0
7feae7521000-7feae7721000 ---p 00048000 fb:00 413964                     /usr/lib64/libmp3lame.so.0.0.0
7feae7721000-7feae7722000 r--p 00048000 fb:00 413964                     /usr/lib64/libmp3lame.so.0.0.0
7feae7722000-7feae7723000 rw-p 00049000 fb:00 413964                     /usr/lib64/libmp3lame.so.0.0.0
7feae7723000-7feae7756000 rw-p 00000000 00:00 0
7feae7756000-7feae7e95000 r-xp 00000000 fb:00 412271                     /usr/lib64/libavcodec.so.52.122.0
7feae7e95000-7feae8094000 ---p 0073f000 fb:00 412271                     /usr/lib64/libavcodec.so.52.122.0
7feae8094000-7feae80a4000 r--p 0073e000 fb:00 412271                     /usr/lib64/libavcodec.so.52.122.0
7feae80a4000-7feae80bb000 rw-p 0074e000 fb:00 412271                     /usr/lib64/libavcodec.so.52.122.0
7feae80bb000-7feae8481000 rw-p 00000000 00:00 0
7feae8481000-7feae848f000 r-xp 00000000 fb:00 415110                     /usr/lib64/transcode/export_ffmpeg.so
7feae848f000-7feae868e000 ---p 0000e000 fb:00 415110                     /usr/lib64/transcode/export_ffmpeg.so
7feae868e000-7feae868f000 r--p 0000d000 fb:00 415110                     /usr/lib64/transcode/export_ffmpeg.so
7feae868f000-7feae8691000 rw-p 0000e000 fb:00 415110                     /usr/lib64/transcode/export_ffmpeg.so
7feae8691000-7feae8692000 r-xp 00000000 fb:00 415124                     /usr/lib64/transcode/export_null.so
7feae8692000-7feae8891000 ---p 00001000 fb:00 415124                     /usr/lib64/transcode/export_null.so
7feae8891000-7feae8892000 r--p 00000000 fb:00 415124                     /usr/lib64/transcode/export_null.so
7feae8892000-7feae8893000 rw-p 00001000 fb:00 415124                     /usr/lib64/transcode/export_null.so
7feae8893000-7feae88a9000 r-xp 00000000 fb:00 2097334                    /lib64/libz.so.1.2.5
7feae88a9000-7feae8aa9000 ---p 00016000 fb:00 2097334                    /lib64/libz.so.1.2.5
7feae8aa9000-7feae8aaa000 r--p 00016000 fb:00 2097334                    /lib64/libz.so.1.2.5
7feae8aaa000-7feae8aab000 rw-p 00017000 fb:00 2097334                    /lib64/libz.so.1.2.5
7feae8aab000-7feae8ac7000 r-xp 00000000 fb:00 2110560                    /usr/lib64/libdvdread.so.4.1.2
7feae8ac7000-7feae8cc7000 ---p 0001c000 fb:00 2110560                    /usr/lib64/libdvdread.so.4.1.2
7feae8cc7000-7feae8cc8000 r--p 0001c000 fb:00 2110560                    /usr/lib64/libdvdread.so.4.1.2
7feae8cc8000-7feae8cc9000 rw-p 0001d000 fb:00 2110560                    /usr/lib64/libdvdread.so.4.1.2
7feae8cfe000-7feae8d09000 r-xp 00000000 fb:00 415262                     /usr/lib64/transcode/import_dvd.so
7feae8d09000-7feae8f08000 ---p 0000b000 fb:00 415262                     /usr/lib64/transcode/import_dvd.so
7feae8f08000-7feae8f09000 r--p 0000a000 fb:00 415262                     /usr/lib64/transcode/import_dvd.so
7feae8f09000-7feae8f0a000 rw-p 0000b000 fb:00 415262                     /usr/lib64/transcode/import_dvd.so
7feae8f0a000-7feafad4b000 rw-p 00000000 00:00 0
7feafad4b000-7feafaece000 r-xp 00000000 fb:00 2097196                    /lib64/libc-2.13.so
7feafaece000-7feafb0cd000 ---p 00183000 fb:00 2097196                    /lib64/libc-2.13.so
7feafb0cd000-7feafb0d1000 r--p 00182000 fb:00 2097196                    /lib64/libc-2.13.so
7feafb0d1000-7feafb0d2000 rw-p 00186000 fb:00 2097196                    /lib64/libc-2.13.so
7feafb0d2000-7feafb0d7000 rw-p 00000000 00:00 0
7feafb0d7000-7feafb0d9000 r-xp 00000000 fb:00 2097215                    /lib64/libdl-2.13.so
7feafb0d9000-7feafb2d9000 ---p 00002000 fb:00 2097215                    /lib64/libdl-2.13.so
7feafb2d9000-7feafb2da000 r--p 00002000 fb:00 2097215                    /lib64/libdl-2.13.so
7feafb2da000-7feafb2db000 rw-p 00003000 fb:00 2097215                    /lib64/libdl-2.13.so
7feafb2db000-7feafb35d000 r-xp 00000000 fb:00 2097252                    /lib64/libm-2.13.so
7feafb35d000-7feafb55c000 ---p 00082000 fb:00 2097252                    /lib64/libm-2.13.so
7feafb55c000-7feafb55d000 r--p 00081000 fb:00 2097252                    /lib64/libm-2.13.so
7feafb55d000-7feafb55e000 rw-p 00082000 fb:00 2097252                    /lib64/libm-2.13.so
7feafb55e000-7feafb576000 r-xp 00000000 fb:00 2097293                    /lib64/libpthread-2.13.so
7feafb576000-7feafb775000 ---p 00018000 fb:00 2097293                    /lib64/libpthread-2.13.so
7feafb775000-7feafb776000 r--p 00017000 fb:00 2097293                    /lib64/libpthread-2.13.so
7feafb776000-7feafb777000 rw-p 00018000 fb:00 2097293                    /lib64/libpthread-2.13.so
7feafb777000-7feafb77b000 rw-p 00000000 00:00 0
7feafb77b000-7feafb79a000 r-xp 00000000 fb:00 2097173                    /lib64/ld-2.13.so
7feafb7b0000-7feafb964000 rw-p 00000000 00:00 0
7feafb966000-7feafb99a000 rw-p 00000000 00:00 0
7feafb99a000-7feafb99b000 r--p 0001f000 fb:00 2097173                    /lib64/ld-2.13.so
7feafb99b000-7feafb99c000 rw-p 00020000 fb:00 2097173                    /lib64/ld-2.13.so
7feafb99c000-7feafb99d000 rw-p 00000000 00:00 0
7fffe42cf000-7fffe42f0000 rw-p 00000000 00:00 0                          [stack]
7fffe43ff000-7fffe4400000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
transcode command:
/usr/bin/transcode --nice 19 --log_no_color --progress_meter 2 --progress_rate 520 -i /dev/sr0 -x dvd -T 3,-1,1 -a 0 -j 0,0,0,0 -R 1,/tmp/kde-rysiek/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 768x576
Ejecting the DVD is causing problems. The "device" notified can stop responding, so I open the console to eject the DVD. I used to call "eject", but this comes with an error:
rysiek@Richlion2 ~ $ eject
eject: tried to use `/mnt/cdrom' as device name but it is no block device
eject: unable to find or open device for: `cdrom'
rysiek@Richlion2 ~ $ eject /dev/sr0
only eject /dev/sr0 allows me to get the disk out.
Today there were 42 updates to my system, but they haven't fixed the problem.
Regards,
Richlion
Richlion
Re: K3B SL7-can't rip any DVD-"Execution transcode failed"
Postby Richlion » Sun Nov 13, 2011 20:30
anybody knows when K3b will be fixed on DVD ripping? There have been tons of updates on SL7 since my initial post, buy k3B still can't pass the 2nd phase of a DVD rip. Should I report a bug?
Regards
Richlion
