Problem for install and running LAMP
Postby user#21 » Fri Oct 14, 2011 11:05
I install it:
sudo equo install dev-lang/php-5.3.8
sudo equo install www-servers/apache-2.2.21
rc-update add apache2
/etc/init.d/apache2 start
sudo nano /etc/conf.d/apache2
edit APACHE2_OPTS to
APACHE2_OPTS="-D DEFAULT_VHOST -D INFO -D SSL -D SSL_DEFAULT_VHOST -D SUEXEC -D LANGUAGE -D LANGUAGE -D PHP5"
sudo /etc/init.d/apache2 restart
echo '<?php phpinfo(); ?>' > /var/www/localhost/htdocs/info.php
sudo equo install dev-db/mysql-5.1.53
rc-update add mysql
emerge --config =dev-db/mysql-5.1.53
Performing Global Updates:
(Could take a couple of minutes if you have a lot of binary packages.)
.='update pass' *='binary update' #='/var/db update' @='/var/db move'
s='/var/db SLOT move' %='binary move' S='binary SLOT move'
p='update /etc/portage/package.*'
/usr/portage/profiles/updates/1Q-2009..............
/usr/portage/profiles/updates/2Q-2009............................................................................
/usr/portage/profiles/updates/3Q-2009......................................................
/usr/portage/profiles/updates/4Q-2009...................
Configuring pkg...
* Please provide a password for the mysql 'root' user now,
* or in the MYSQL_ROOT_PASSWORD env var.
* Avoid ["'\_%] characters in the password
> root pass
* Retype the password
>root pass
* Creating the mysql database and setting proper
* permissions on it ...
* Starting mysqld ... [ ok ]
* Setting root password ... [ ok ]
* Loading "zoneinfo", this step may require a few seconds ... ... [ ok ]
* Stopping the server ...
* Done
sudo equo install dev-db/phpmyadmin-3.4.4
and i go http://localhost/info.php - it works
if i go http://localhost/phpmyadmin and enter root login and pass, my browser wrote
Data not received
Unable to load a web page, so as not received information from the server.
in apache2 error.log:
[Fri Oct 14 14:31:18 2011] [notice] child pid 27413 exit signal Segmentation fault (11)
[Fri Oct 14 14:31:18 2011] [notice] child pid 27414 exit signal Segmentation fault (11)
Help please, how my error?
ps. Sorry for my bad english
user#21
Re: Problem for install and running LAMP
Postby user#21 » Sun Oct 16, 2011 11:33
Here there is anyone alive? My problem is still with us. :(
user#21
Postby wolfden » Sun Oct 16, 2011 22:41
what browser are you using? Try using a different browser.
Postby user#21 » Mon Oct 17, 2011 11:01
Chrome, which was supplied when installing the Sabayon linux
user#21
Postby joost » Mon Oct 17, 2011 11:41
Apache segfaulting would not have anything todo with the client browser (I hope)
What architecture is your LAMP server?
Perhaps related to this?
https://bugs.sabayon.org/show_bug.cgi?id=2725
Postby user#21 » Mon Oct 17, 2011 19:37
i386
user#21
Postby wolfden » Mon Oct 17, 2011 21:58
There is references that chrome not working properly with it so that is why I asked.
If you google Unable to load a web page, so as not received information from the server. you will see reference to it and others with chrome having the issue. Hard to understand but the issue is there. Process of elimination :D
