Opera + Flash [Solved]
Postby NoSavy » Thu Oct 06, 2011 12:52
This is great. Opera is now working with flash (using flash 64bit ver.11.0.1.152).
Can anyone say what the problem has been as it was mainly Gentoo and Sabayon that it was failing on.?
I've upgraded today and it was the Nvidia files only, so I'm assuming it was the problem.
NS.
Asus M4A79XTD EVO motherboard, AMD Phenom II X4 965 CPU, 4 GB ram.
Gigabyte NVIDIA 9800GT Silent graphics card, Dell FP2007 22 Digital Flat panel.
Samsung harddisks 2 x 200gb SP2004S,1 x Hitachi 750gb HDT 72107,Optiarc SATA DVD-RW. Sabayon 64 & 32bit.
NoSavy
Re: Opera + Flash
Postby Sisko43 » Sat Oct 08, 2011 17:20
Yes, it depends on Nvidia files. I think it's the "nvidia-userspace" package from sabayon. I use now for several month the nvidia-drivers from portage. there is no nvidia-userspace and flash in opera works flawless. So if you have issues with flash + opera in the future, emerge the nvidia-drivers from portage with option "nodeps" and flash in opera will be fine again. Sometimes it works with nvidia-userspace, sometimes not. So I will stay with the portage-variant until this issue is fixed permanently.
Sisko43
Re: Opera + Flash (answered, ie. Solved)
Postby NoSavy » Sun Oct 09, 2011 20:43
Thankyou Sisko43 for the explanation.
NS.
NoSavy
