krusader kdiff3 'Opening of these files failed' error
Postby msdobrescu » Sun Oct 02, 2011 8:44
I've got krusader and kdiff3 and when I try to use the 'Compare by content' command, krusader opens kdiff3 and then 'Opening of these files failed' error occurs.
When I use kdiff3 separately, it works fine.
Does anybody else face this problem?
Is there a fix?
Thanks.
msdobrescu
Re: krusader kdiff3 'Opening of these files failed' error
Postby raman » Sun Oct 02, 2011 15:08
KDE or another DE?
raman
Postby msdobrescu » Sun Oct 02, 2011 15:58
KDE 4.7.1.
msdobrescu
Postby raman » Sun Oct 02, 2011 16:15
Mmmm, dunno, the same problem. I try compare 2 .txt files, on admin krusader mode too and the same error: "Opeing of these files failed"
raman
Postby msdobrescu » Sun Oct 02, 2011 16:36
Indeed, it seems not to matter if the user is root or not.
msdobrescu
Postby Fitzcarraldo » Sun Oct 02, 2011 17:09
Works OK for me. Not sure whether or not if it's relevant, but the versions I'm using are:
# eix -I krusader
[I] kde-misc/krusader
     Available versions:  (4) 2.3.0_beta1 (~)2.4.0_beta1
        {aqua debug handbook kdeenablefinal linguas_bg linguas_bs linguas_ca linguas_ca@valencia linguas_cs linguas_da linguas_de linguas_el linguas_en_GB linguas_eo linguas_es linguas_et linguas_fr linguas_ga linguas_gl linguas_hr linguas_hu linguas_it linguas_ja linguas_ko linguas_lt linguas_mai linguas_nb linguas_nds linguas_nl linguas_pl linguas_pt linguas_pt_BR linguas_ro linguas_ru linguas_sk linguas_sl linguas_sv linguas_tr linguas_ug linguas_uk linguas_zh_CN linguas_zh_TW}
     Installed versions:  2.4.0_beta1(4)(04:24:01 27/08/11)(-aqua -debug -handbook -kdeenablefinal -linguas_bg -linguas_bs -linguas_ca -linguas_ca@valencia -linguas_cs -linguas_da -linguas_de -linguas_el -linguas_en_GB -linguas_eo -linguas_es -linguas_et -linguas_fr -linguas_ga -linguas_gl -linguas_hr -linguas_hu -linguas_it -linguas_ja -linguas_ko -linguas_lt -linguas_mai -linguas_nb -linguas_nds -linguas_nl -linguas_pl -linguas_pt -linguas_pt_BR -linguas_ro -linguas_ru -linguas_sk -linguas_sl -linguas_sv -linguas_tr -linguas_ug -linguas_uk -linguas_zh_CN -linguas_zh_TW)
     Homepage:            http://www.krusader.org/
     Description:         An advanced twin-panel (commander-style) file-manager for KDE with many extras.
# eix -I kdiff3
[I] kde-misc/kdiff3
     Available versions:  (4) 0.9.95-r1!t (~)0.9.96!t
        {aqua debug +handbook kde kdeenablefinal konqueror linguas_ar linguas_bg linguas_br linguas_bs linguas_ca linguas_ca@valencia linguas_cs linguas_cy linguas_da linguas_de linguas_el linguas_en_GB linguas_eo linguas_es linguas_et linguas_fr linguas_ga linguas_gl linguas_hi linguas_hne linguas_hr linguas_hu linguas_is linguas_it linguas_ja linguas_ka linguas_lt linguas_mai linguas_ml linguas_nb linguas_nds linguas_nl linguas_nn linguas_pl linguas_pt linguas_pt_BR linguas_ro linguas_ru linguas_rw linguas_sk linguas_sv linguas_ta linguas_tg linguas_tr linguas_ug linguas_uk linguas_zh_CN linguas_zh_TW}
     Installed versions:  0.9.96(4)(11:01:46 11/09/11)(handbook kde -aqua -debug -kdeenablefinal -linguas_ar -linguas_bg -linguas_br -linguas_bs -linguas_ca -linguas_ca@valencia -linguas_cs -linguas_cy -linguas_da -linguas_de -linguas_el -linguas_en_GB -linguas_eo -linguas_es -linguas_et -linguas_fr -linguas_ga -linguas_gl -linguas_hi -linguas_hne -linguas_hr -linguas_hu -linguas_is -linguas_it -linguas_ja -linguas_ka -linguas_lt -linguas_mai -linguas_ml -linguas_nb -linguas_nds -linguas_nl -linguas_nn -linguas_pl -linguas_pt -linguas_pt_BR -linguas_ro -linguas_ru -linguas_rw -linguas_sk -linguas_sv -linguas_ta -linguas_tg -linguas_tr -linguas_ug -linguas_uk -linguas_zh_CN -linguas_zh_TW)
     Homepage:            http://kdiff3.sourceforge.net/
     Description:         Qt/KDE based frontend to diff3
Postby raman » Sun Oct 02, 2011 17:12
# equo search kdiff3
>>  @@ Wyszukiwanie...
>>      @@ Pakiet: kde-misc/kdiff3-0.9.95-r1 gałąź: 5, [sabayon-weekly]
>>         Dostępne:        wersja: 0.9.95-r1 ~ tag: NoTag ~ nr rewizji: 0
>>         Zainstalowane:   wersja: 0.9.95-r1 ~ tag: NoTag ~ nr rewizji: 0
>>         Slot:            4
>>         Strona domowa:   http://kdiff3.sourceforge.net/
>>         Opis:            Qt/KDE based frontend to diff3
>>         Licencja:        GPL-2
>>  Słowa kluczowe:  kdiff3
>>  Znaleziono:      1 element/y/ów
# equo search krusader
>>  @@ Wyszukiwanie...
>>      @@ Pakiet: kde-misc/krusader-2.4.0_beta1 gałąź: 5, [sabayon-weekly]
>>         Dostępne:        wersja: 2.4.0_beta1 ~ tag: NoTag ~ nr rewizji: 1
>>         Zainstalowane:   wersja: 2.4.0_beta1 ~ tag: NoTag ~ nr rewizji: 1
>>         Slot:            4
>>         Strona domowa:   http://www.krusader.org/
>>         Opis:            An advanced twin-panel (commander-style)
>>                          extras.
>>         Licencja:        GPL-2
>>  Słowa kluczowe:  krusader
So we have older kdiff3..
raman
Postby msdobrescu » Sun Oct 02, 2011 17:41
eix -I krusader
     Installed versions:  2.4.0_beta1(4)(12:42:40 PM 08/08/2011)(linguas_bg linguas_bs linguas_ca linguas_cs linguas_da linguas_de linguas_el linguas_en_GB linguas_eo linguas_es linguas_et linguas_fr linguas_ga linguas_gl linguas_hr linguas_hu linguas_it linguas_ja linguas_ko linguas_lt linguas_nb linguas_nds linguas_nl linguas_pl linguas_pt linguas_pt_BR linguas_ro linguas_ru linguas_sk linguas_sl linguas_sv linguas_tr linguas_uk linguas_zh_CN linguas_zh_TW -aqua -debug -handbook -kdeenablefinal -linguas_ca@valencia -linguas_mai -linguas_ug)
eix -I kdiff3
[U] kde-misc/kdiff3
     Installed versions:  0.9.95-r1(4)!t(11:43:31 AM 01/31/2011)(handbook linguas_ar linguas_bg linguas_br linguas_cs linguas_cy linguas_da linguas_de linguas_el linguas_en_GB linguas_es linguas_et linguas_fr linguas_ga linguas_gl linguas_hi linguas_hu linguas_it linguas_ja linguas_lt linguas_nb linguas_nds linguas_nl linguas_pl linguas_pt linguas_pt_BR linguas_ro linguas_ru linguas_rw linguas_sv linguas_ta linguas_tg linguas_tr linguas_uk linguas_zh_CN -aqua -debug -kde -kdeenablefinal -konqueror -linguas_ka)
msdobrescu
Postby Fitzcarraldo » Sun Oct 02, 2011 17:48
raman wrote:So we have older kdiff3..
Yup, you both do. That may be the cause of your problem. You'll either have to wait for the later version to be built and put in the Entropy repository (no doubt that'll happen within a few days), or build the later version using Portage.
Postby totedati » Tue Oct 11, 2011 1:23
equo search kde-misc/krusader
>>  @@ Searching...
>>      @@ Package: kde-misc/krusader-2.4.0_beta1 branch: 5, [sabayonlinux.org]
>>         Available:     version: 2.4.0_beta1 ~ tag: NoTag ~ revision: 1
>>         Installed:     version: 2.4.0_beta1 ~ tag: NoTag ~ revision: 1
>>         Slot:          4
>>                        extras.
>>         License:       GPL-2
>>  Keywords:  kde-misc/krusader
>>  Found:     1 entries
equo search kde-misc/kdiff3
>>  @@ Searching...
>>      @@ Package: kde-misc/kdiff3-0.9.95-r1 branch: 5, [sabayonlinux.org]
>>         Available:     version: 0.9.95-r1 ~ tag: NoTag ~ revision: 0
>>         Installed:     version: 0.9.95-r1 ~ tag: NoTag ~ revision: 0
>>         Slot:          4
>>         License:       GPL-2
>>  Keywords:  kde-misc/kdiff3
>>  Found:     1 entries
and can not reproduce this error, i can select and kdiff files without any error ... just update to latest stable sabayon package versions and check again ...
linux is free, the expertise to harness it is not!
you don't make so much money selling open source software!
You make MORE money USING it, just like google!
linux registered user #352479
totedati
