now i have dvd-r burning problem that never exists a few days before when i was on another lin distro (bodhi ubuntu based). every dvd is destroyed in a way that k3b or nero burn something on it and when real data have to be burned i get errors and then dvd burning stopswith errors. with nero i get illegal disc msg error and with k3b something like "... probably buffer underrun" now before i (burning programs) destroy more dvd's any idea how to solve this and where is the problem? one more thing. this didn't happened with my dvd-rw media.
this is nero log:
- Code: Select all
9M1K-0098-P3HL-PK6P-T6UA-1E5X-****-****
Linux 3.0.0-sabayon (x86_64)
Nero API version: 9.7.0.132
Using interface version: 9.0.1.4
Installed in: /usr/lib/nero/
Application: Nero AG\Nero Linux
Internal Version: 9, 7, 0, 132
Recorder: <HL-DT-ST DVDRAM GSA-H12N>Version: UL01 - HA 4 TA 0 - 0.0.0.0
Adapter driver: <unknown> HA 4
Drive buffer : 2048kB
Bus Type : via Inquiry data
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 3960MB (4056016kB)
Free physical memory: 750MB (768912kB)
Memory in use : 81 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.9.2011
NeroAPI
17:36:47 #1 Phase 114 File ExtendedProgress.cpp, Line 537
DVD-Video files reallocation completed (no file modified)
17:36:47 #2 Text 0 File DataCompilation.cpp, Line 1322
Multisession status:
Multisession type: no multisession
ISO 9660 file system settings:
Data mode: Mode 2/XA
File system: ISO 9660 only
File name length (ISO): Max. of 11 = 8 + 3 chars (Level 1)
Character set (ISO): ISO 9660 (standard ISO CD-ROM)
Add Rock Ridge extensions: no
Allow path depth of more than 8 dirs: no
Allow more than 255 characters in path: no
Do not add the ISO file version extension: no
Allow more than 64 characters for Joliet: no
UDF file system settings:
Mode: automatic
Volume labels:
ISO volume label: 'SPY_HARD'
System identifier: ''
Volume set: ''
Publisher: ''
Data preparer: ''
Application: 'NERO LINUX'
Copyright file: ''
Abstract file: ''
Bibliographic file: ''
UDF volume label: 'Spy_Hard'
Cache status:
Cache files from disk or network: yes
Cache small files: yes
Small files size limit: 65536 bytes
17:36:47 #3 Phase 111 File ExtendedProgress.cpp, Line 537
DVD-Video files sorted
17:36:47 #4 ISO9660GEN -11 File Geniso.cpp, Line 3337
First writeable address = 0 (0x00000000)
17:36:48 #5 ISO9660GEN -11 File Geniso.cpp, Line 3337
17:36:48 #6 Text 0 File Burncd.cpp, Line 3647
Turn on Disc-At-Once, using DVD media
17:36:48 #7 ISO9660GEN -11 File Geniso.cpp, Line 3337
17:36:48 #8 ISO9660GEN -11 File Geniso.cpp, Line 3337
17:36:48 #9 Text 0 File DlgWaitCD.cpp, Line 313
Last possible write address on media: 2298495
Last address to be written: 1938207
17:36:48 #10 Text 0 File DlgWaitCD.cpp, Line 325
Write in overburning mode: NO
17:36:48 #11 Text 0 File DlgWaitCD.cpp, Line 2856
Recorder: HL-DT-ST DVDRAM GSA-H12N, Media type: DVD-R
Disc Manufacturer ID: <CMC MA> <G. AM3>
Disc Application Code: 64, Disc Physical Code: 193
17:36:48 #12 Text 0 File DlgWaitCD.cpp, Line 500
>>> Protocol of DlgWaitCD activities: <<<
17:36:48 #13 Text 0 File ThreadedTransferInterface.cpp, Line 734
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1938208 (1938208) = #1938208/430:42.58
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1938208 blocks [HL-DT-ST DVDRAM GSA-H12N (H:4 T:0)]
17:36:48 #14 Text 0 File ThreadedTransferInterface.cpp, Line 936
Prepare [HL-DT-ST DVDRAM GSA-H12N (H:4 T:0)] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3969449984, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1938208 | 0 | 0x00
1938208 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
17:36:48 #15 Text 0 File Burncd.cpp, Line 4354
Caching options: cache CDRom or Network-No, small files-Yes (<32KB)
17:36:48 #16 Phase 24 File ExtendedProgress.cpp, Line 537
Caching of files started
17:36:48 #17 Text 0 File Burncd.cpp, Line 4476
Cache writing successful.
17:36:48 #18 Phase 25 File ExtendedProgress.cpp, Line 537
Caching of files completed
17:36:48 #19 Phase 36 File ExtendedProgress.cpp, Line 537
Burn process started at 4x (5540 KB/s)
17:36:48 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2690
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
17:36:48 #21 Text 0 File DVDR.cpp, Line 3287
Recording mode: Sequential Recording Mode
17:36:48 #22 Text 0 File DVDR.cpp, Line 3441
Start write address at LBA 0
DVD high compatibility mode: Yes
17:36:48 #23 Text 0 File Cdrdrv.cpp, Line 10169
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 26127F h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 2FE10 h
Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 84 0D 12 98 99 90 00 .@....R.........
03 43 4D 43 20 4D 41 00 - 04 47 2E 20 41 4D 33 00 .CMC.MA..G..AM3.
05 88 80 00 00 00 02 00 - 06 09 0D 14 98 88 90 00 ................
07 88 80 00 00 00 00 00 - 08 07 17 0A 0E 09 04 00 ................
09 95 07 0D 0B 88 88 00 - 0A 80 00 00 00 00 10 00 ................
0B 06 17 15 B8 99 85 00 - 0C B8 9A 32 03 20 32 00 ...........2..2.
0D 00 00 D0 00 00 00 00 - 0E 09 1F 39 2F 25 1C 00 ...........9/%..
0F 50 19 29 19 89 B5 00 - 10 88 84 00 04 00 04 00 .P.)............
11 00 00 00 00 00 00 00 - 12 09 2B 37 2D 29 1B 00 ..........+7-)..
13 50 1D 2D 1F A6 B5 00 - 14 88 80 00 00 00 00 00 .P.-............
15 00 00 00 00 00 00 00 - 16 0B 45 3D 3B 1F 25 00 ..........E=;.%.
17 30 25 31 0D 8A B5 00 - 18 88 80 00 00 00 00 00 .0%1............
19 00 00 00 00 00 00 00 - 1A 0C 51 51 51 45 2D 00 ..........QQQE-.
1B 90 23 2D 19 79 B5 00 - 1C 88 80 00 00 00 00 00 ..#-.y..........
17:36:48 #24 Text 0 File DVDR.cpp, Line 3579
Reserved Track size: 1938208 (1D9320h, 3785MB) -> return code 0
17:36:48 #25 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
17:36:56 #26 Text 0 File Cdrdrv.cpp, Line 1273
17:36:56 - HL-DT-ST DVDRAM GSA-H12N (H:4 T:0) : Queue again later
17:37:16 #27 SCSI -1046 File SCSIInterface.cpp, Line 624
SCSI Exec, HA 4, TA 0, LUN 0, buffer 0x0x7f87c97fc040
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x05 (0x0B, SCSI_TASTATUS_FAILED)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x10
0x2A 0x00 0x00 0x0C 0x30 0x05
17:37:16 #28 CDR -1046 File Writer.cpp, Line 306
Illegal disc
17:37:17 #29 Text 0 File DVDR.cpp, Line 3846
EndDAO: Last written address was 4294967295 (FFFFFFFFh)
17:37:17 #30 Text 0 File DVDPlusDualLayer.cpp, Line 1455
SetDriveCaps: Set LAST LBA of layer 1 to 0
17:37:17 #31 Phase 38 File ExtendedProgress.cpp, Line 537
Burn process failed at 4x (5540 KB/s)
thanks
