i have some problems with e17.
1. i am trying to set few startup apps. when i open settings -> apps -> startup applications, under system tab i have few on list but under applications tab no applications at all. where is the problem? (this worked for me on bodhi/ubuntu)
2. krusader don't want to open some files that i associate with jubler. jubler is subtitle app written in java. i can open this files from command line too, but when i want to save changes i get error that file is not writeable. if i open jubler (which i added) from e17 menu and then subtitle then save changes everything is ok. any solution?
3. i can't run virtualbox from e17 menu. the application failed to start is error msg. now with synaptic i could see full path with filename of installed files for some package. how to do this with equo or sulfur? then i could start virtualbox from cl and see what is the problem (i guess that problem is something about compiling driver for kernel or not adding me as user to vbox group)
that's it for now
thanks
