It's a bit strange issue, I realized that the freez comes eventually when using Chromium, but only after a while, when searching in google.
I am using XFCE, if I try to login into KDE, computer freezes as well on the KDE loading screen. Even a new created user can't login to KDE.
kdm.log shows
- Code: Select all
WARNING: Deprecated config file /etc/modprobe.conf, all config files belong into /etc/modprobe.d/.
WARNING: All config files need .conf: /etc/modprobe.d/ath_pci, it will be ignored in a future release.
klauncher(7755) kdemain: No DBUS session-bus found. Check if you have started the DBUS server.
kdeinit4: Communication error with launcher. Exiting!
kdmgreet(7749)/kdecore (K*TimeZone*): KSystemTimeZones: ktimezoned initialize() D-Bus call failed: "Not connected to D-Bus server"
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Fatal server error:
no screens found
for help.
klauncher(15548) kdemain: No DBUS session-bus found. Check if you have started the DBUS server.
kdmgreet(15542)/kdecore (K*TimeZone*): KSystemTimeZones: ktimezoned initialize() D-Bus call failed: "Not connected to D-Bus server"
Could that be related to dbus?
