Backup solution for home [Solved] (but more ideas welcome)
Postby Raghav_K » Sat Aug 27, 2011 12:51
okay i have a 1 tb internal hd and a 500gb internal hd.
i need a backup solution to copy the /home directory and a 400 gb /media/collection partition from the 1 tb internal HD to the 500gb one once a week, and to a 500gb external one, once a month..
i tried a few luckybackup, areca.... i found areca too slow n luckybackup confusing..
so i just made a initial backup with rsync via commandline
rsync -avh /home /media/backup_drive/backups
rsybc -avh /media/collections /media/backup_drive/backups1
any suggestions to automate the process?? and to make the backup recursive or differential when it runs the second time...
and any other gui suggestions?
thanks...
:alien:
aaaaaaaaaahhhhhhhh open source goodnessssss!!!!!!!!!!
Raghav_K
Re: Backup solution for home....
Postby micia » Sat Aug 27, 2011 13:37
Have you tried deja-dup?
(as root)
equo install --ask deja-dup
It is mainly a Gnome application, but I don't think it has many dependencies on it (obviously if you are already using Gnome or XFCE, this is not a problem).
micia
Postby sabayonino » Sat Aug 27, 2011 13:45
Raghav_K wrote:okay i have a 1 tb internal hd and a 500gb internal hd.
:alien:
Try crontab to automate the process or other scripts
see http://www.gentoo-wiki.info/Cron http://www.gentoo-wiki.info/Crontab http://www.gentoo-wiki.info/HOWTO_use_cron
An example to backup using rsync : http://en.gentoo-wiki.com/wiki/Backup_Using_Rsync
if you don't know how works dd command skip Backing-up the boot sector using dd article
see also
man crontab
man cron
man rsync
Postby Raghav_K » Sat Aug 27, 2011 14:27
thanks a lot guys :)
Raghav_K
Re: Backup solution for home [Solved] (but more ideas welcom
Postby Fitzcarraldo » Sat Aug 27, 2011 19:01
In case it's of any interest, you could modify the backup script I use: My personal backup strategy. And, as for automating it, you could even use KAlarm to do it if you find the idea of setting up a cronjob daunting.
Postby albfneto » Sun Aug 28, 2011 0:20
if you want to copy some files, music, videos to an DVD or pendrive, or other directory etc...
you may try the Kbackup package, is very easy to use.
albfneto@fcfrp.usp.br
Favorite Distros: Sabayon, Gentoo, Mandriva and OpenSUSE
Postby Raghav_K » Sun Aug 28, 2011 6:32
Fitzcarraldo, loved ur idea... gonna copy it... :mrgreen:
Raghav_K
Postby Gordon » Sun Aug 28, 2011 9:31
It might be an idea to bring in a rotation system. Using rsync and Linux this is really not that difficult and doesn't even require a lot of additional disk space (unless of course you change a lot of data each day)
Essentially, take the rsync backup scheme but let it copy the data to a folder that is based on the day of the week (e.g. insert `date +%w` in the destination path. Now the trick is to prefill the destination folder with a copy of yesterdays content without actually copying it. This is done by using the command `cp -al`, which just copies the directory entries pointing to the already existing files. Running rsync will then copy in al the changes without actually touching the files that are still occupied by directory entries from the previous day.
I use such a scheme for backups at work, running differentials from monday to thursday and a full backup (i.e. towards an empty directory tree) on fridays.
Gordon
