MySQL Workbench Segmentation fault [Solved]
Postby udiljak » Tue Aug 16, 2011 17:28
Hi.
Since the last upgrade the MySQL Workbench is not starting any more. I receive an output if I try to start it from console which I will attach to this message.
The version of MySQL Workbench is 5.2.34 7780.
Thanks in advance for any reply!
Ben
Edit: I can't upload an attachment. (Message: "Sorry, the board attachment quota has been reached.")
Here's the beginning of the output:
*** Segmentation fault
Register dump:
 EAX: 00000000   EBX: b710cff4   ECX: bfcfa92f   EDX: bfcfa928
 ESI: 089ab248   EDI: bfcfa9ec   EBP: bfcfa948   ESP: bfcfa8f0
 EIP: b7058bee   EFLAGS: 00210293
 CS: 0073   DS: 007b   ES: 007b   FS: 0000   GS: 0033   SS: 007b
 Trap: 0000000e   Error: 00000004   OldMask: 00000000
 ESP/signal: bfcfa8f0   CR2: 00000008
 FPUCW: ffff037f   FPUSW: ffff4022   TAG: ffffffff
 IPOFF: 00000000   CSSEL: 0000   DATAOFF: 00000000   DATASEL: 0000
 ST(0) 0000 0000000000000000   ST(1) 0000 0000000000000000
 ST(2) 0000 0000000000000000   ST(3) 0000 a600000000000000
 ST(4) 0000 8000000000000000   ST(5) 0000 8000000000000000
 ST(6) 0000 a600000000000000   ST(7) 0000 0000000000000000
Backtrace:
/lib/libSegFault.so(+0x2323)[0xb78c0323]
??:0(??)[0xffffe400]
/usr/lib/mysql-workbench/libwbpublic.so.0(_ZN3bec10GRTManagerC1Ebb+0x5ca)[0xb7265cba]
/usr/bin/mysql-workbench-bin(_ZN2wb9WBContextC2EPNS_11WBContextUIEb+0x25d)[0x83699ad]
/usr/bin/mysql-workbench-bin(_ZN2wb11WBContextUIC2Eb+0x48)[0x8335958]
/usr/bin/mysql-workbench-bin(_ZN7ProgramC2EN2wb9WBOptionsE+0x47)[0x81cbaf7]
/usr/bin/mysql-workbench-bin(main+0x972)[0x81c3da2]
/lib/libc.so.6(__libc_start_main+0xe6)[0xb5d3fcc6]
??:0(??)[0x81c3301]
Memory map:
08048000-08674000 r-xp 00000000 08:11 8926560 /usr/bin/mysql-workbench-bin
08674000-08675000 r--p 0062b000 08:11 8926560 /usr/bin/mysql-workbench-bin
08675000-08678000 rw-p 0062c000 08:11 8926560 /usr/bin/mysql-workbench-bin
08678000-0867b000 rw-p 00000000 00:00 0
udiljak
Re: MySQL Workbench Segmentation fault [Solved]
Postby udiljak » Wed Aug 24, 2011 22:48
Hi.
The problem vanished with the latest update.
Cheers,
Ben
udiljak
Postby sqlpython » Thu Aug 25, 2011 3:03
In my case I just uninstalled Workbench and reinstalled Workbench then all was right again.. :)
Criticism accepted for Solutions that work. ;^)
Sabayon 11-DEBIAN 7-#Sid-Slackware 14-Calculate 13-
sqlpython
