Firefox and Google+ [Solved]
Postby ddeimeke » Sat Aug 06, 2011 11:22
in case I call https://plus.google.com/ I get the message that plugins are missing.
Which one is needed to abandon this message? Do you know any possibility to use Hangouts in G+?
Thanks for any support
Dirk
Worth a visit: Taskwarrior - What's next?
ddeimeke
Re: Firefox and Google+
Postby joost » Sat Aug 06, 2011 12:38
I think this one: www-plugins/google-talkplugin
Postby ddeimeke » Sat Aug 06, 2011 12:54
joost wrote:I think this one: www-plugins/google-talkplugin
Half way done. Thank you! Hangouts are working.
The message about missing plugins still persists.
Thanks Joost!
Cheers
Dirk
ddeimeke
Postby DHalens » Sat Aug 06, 2011 15:09
www-plugins/adobe-flash may be needed too.
DHalens
Postby ddeimeke » Sat Aug 06, 2011 18:24
DHalens wrote:www-plugins/adobe-flash may be needed too.
Yes, you are right. I installed it and www-plugins/gecko-mediaplayer as well, but there is still a plugin missing. It would be nice if Firefox would tell me which one ...
Thanks for your support!
Cheers
Dirk
ddeimeke
Postby Thev00d00 » Sun Aug 07, 2011 21:44
That message should be disabled....
In about:config set "plugins.hide_infobar_for_missing_plugin" to true.
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Thev00d00
Generally Awesome (tm)
Postby ddeimeke » Mon Aug 08, 2011 4:36
Thev00d00 wrote:In about:config set "plugins.hide_infobar_for_missing_plugin" to true.
Since I do not miss anything, this is a valid possibility.
Will do that.
Thanks!
Dirk
ddeimeke
