Keepassx has super micro small fonts under XFCE [Solved]
Postby HolgiB » Mon Aug 01, 2011 19:24
Hi all,
after setting up a fresh XFCE 6.0 Sabayon system I installed Keepassx (which is my mayor password administration tool on all Linux systems).
Strangely enough when launching Keepassx all fonts are super small (less than 4 pixel I guess). Some google-fu revealed that I have to launch qtconfig to adjust the font-size and this should fix the issue.
Unfortunately the qtconfig has the same super small font size which makes any configuration close to impossible.
Acknowledged, the fact that the system is connected to a 32 Inch flat TV doesn't enhance the legibility but I doubt that I would be able to read any part of qtconfig if I attach my 1080p capable monitor.
Does someone know I workaround ? I am close to install the Windows version of Keepassx under WINE to see if the problem is gone.
Using another password manager is not really an option because of the sheer amnount of passwords I keep inside Keepassx.
Any ideas ?
TIA,
Holger
My Sabayon Box:
Sabayon x64, XFCE
Intel Core2 Duo Processor E4500 (2x2.2GHz)
3GB DDR2 RAM
ATI HD4670
Open your source, open your mind
HolgiB
Re: Keepassx has super micro small fonts under XFCE
Postby micia » Tue Aug 02, 2011 13:04
Hi, welcome to the Sabayon Linux Community :mrgreen:
Check the file:
.config/Trolltech.conf
in your home directory, I think that editing the line:
font="some font entry"
should solve your issue.
for example, you could replace it with:
font="Verdana,16,-1,5,50,0,0,0,0,0"
the number after:
Verdana,
is the font size.
micia
Postby HolgiB » Wed Aug 03, 2011 18:20
Hi there,
thanks for your help ! Changing the value helped and now the keepassx menu entries are readable :alien:
I am not shure what value this is. I had to crank it up to something like 42 and now the font size looks simiar to the system setting of 12 pixel (?).
Thanks again,
Holger
My Sabayon Box:
Sabayon x64, XFCE
3GB DDR2 RAM
ATI HD4670
HolgiB
Re: Keepassx has super micro small fonts under XFCE [Solved]
Postby micia » Wed Aug 03, 2011 21:43
That number should be the point size. However the "impact" of that parameter depends on which font you are using and on the desktop resolution, are you using Verdana or other fonts in that line?
micia
Postby HolgiB » Thu Aug 04, 2011 9:46
I am using Verdana or I should rather say Verdana is pre-configured.
My desktop resolution is set to 1360x768.
My Sabayon Box:
Sabayon x64, XFCE
3GB DDR2 RAM
ATI HD4670
HolgiB
