I am trying to run httrack from the main repository, Sabayon6 G 64bit. Is the version compiled to make use of the gui or strictly command line? I can get at least the help file to display using the terminal. Running from the Applications menu opens a new Firefox tab pointed to
http://sabayon:8080/
with the error - The connection has timed out. The server at http://www.sabayon.com is taking too long to respond.
Is this a firewall issue? or something else?
