I'm trying to add an entry into /etc/crypttab. The problem is Sabayon seams to ignore my change and appropriate device is not available in /dev/mapper. The entry itself is fine - I can open the encrypted partition in terminal with cruptsetup luksOpen.
I've also noticed that /etc/crypttab and /etc/fstab are working differently on Sabayon comparing to Fedora/Ubuntu.
My /etc/crypttab in Fedora:
- Code: Select all
aruba etc # cat /etc/crypttab
luks-d57e1ed1-2f1a-4852-99e4-9c2106209ec1 UUID=d57e1ed1-2f1a-4852-99e4-9c2106209ec1 none
vg_acer-lv_encrypted /dev/mapper/vg_acer-lv_decrypted /path/luks.key luks
and /etc/fstab (comments removed):
- Code: Select all
aruba etc # cat /etc/fstab
/dev/mapper/luks-d57e1ed1-2f1a-4852-99e4-9c2106209ec1 / ext4 defaults 1 1
UUID=7b054c32-9a50-48b5-89b9-203c7bb0984f /boot ext3 defaults 1 2
tmpfs /dev/shm tmpfs defaults 0 0
devpts /dev/pts devpts gid=5,mode=620 0 0
sysfs /sys sysfs defaults 0 0
proc /proc proc defaults 0 0
/dev/mapper/vg_acer-lv_decrypted /mnt/decrypted ext3 defaults 0 1
In Sabayon /etc/crypttab:
- Code: Select all
aruba / # cat /etc/crypttab
luks-7c70b28a-e765-405d-8701-8d8f5488d93a UUID=7c70b28a-e765-405d-8701-8d8f5488d93a none
and /etc/fstab (the last row is commented out because Sabayon does not create /dev/mapper/vg_acer-lv_decrypted):
- Code: Select all
UUID=b64600a3-394f-4cfa-8361-c06b4b7d9d29 / btrfs defaults 1 1
UUID=6de2df91-f287-401b-b13f-0ac17491bd6d /boot ext3 defaults 1 2
#/dev/mapper/vg_acer-lv_decrypted /mnt/decrypted ext3 defaults 0 1
Please, notice the root partition UUID differs in crypttab and fstab in Sabayon. In Fedora they are the same. In fact Sabayon is not using /dev/mapper for the root partition in fstab.
In short. I want my encrypted partition to be opened by /etc/crypttab and mounted by /etc/fstab.
Any tips how can I achieve this?
Thanks in advance
