when I open my encrypted partition (located on logical volume) I always get following
- Code: Select all
aruba ~ # cryptsetup luksOpen /dev/vg_acer/lv_encrypted lv_decrypted
Enter passphrase for /dev/vg_acer/lv_encrypted:
semid 393216: semop failed for cookie 0xd4d7c5d: incorrect semaphore state
Failed to set a proper state for notification semaphore identified by cookie value 223181917 (0xd4d7c5d) to initialize waiting for incoming notifications.
The partitions seams to work fine.
I've found similar problem is risen on Gentoo forum:
http://forums.gentoo.org/viewtopic-t-859013.html
Is this a bug/should I report it?
Thanks
