Can't install xsane [Solved]
Postby peispud » Fri Jun 24, 2011 23:46
Help anyone, while trying to install hplip, it appears xsane is required and listed in the package manager, but not in the reops
>> [F]: 0.0/0.0 kB <-> 0% [> ] => 0.0b/sec : ETA: 0s
## ( mirror #40 ) Error downloading from: http://pkg.sabayon.org - not found.
## Package cannot be fetched. Try to update repositories. Error: 3
## An error occured. Action aborted.
peispud
Re: Can't install xsane
Postby Fitzcarraldo » Sun Jun 26, 2011 17:24
What happens if you do it separately?:
equo install xsane
Sabayon Entropy Store: xsane
Postby peispud » Sun Jun 26, 2011 21:04
Same result, xsane is not in the repos, so no printer drivers in Sabayon for a wide range of HP printers.
peispud
Postby peispud » Sun Jun 26, 2011 21:14
Ahh, the package manager has finally picked up xsane, but the mirrors are crawling. My printer is now set-up successfully. I do think that the hplip drivers should be part of the default install :)
peispud
Re: Can't install xsane "[Solved]"
Postby peispud » Sun Jun 26, 2011 22:11
good idea, thanks
peispud
